Grande Punto - Central locking does not open the driver's door.
skaktus 9525 4
  • Clarifying Grande Punto lock and cylinder replacement options
    #1 16289192
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Grande Punto, year 2006, equipment version Emotion, three doors. The central locking closes and opens only the passenger door, the driver's door does not respond. Opening and closing possible only with the key. The question for you - the replacement in this case is the cylinder itself, or are the lock and the cylinder integrated? If the lock and actuator were integrated and replaced, could the door still be unlocked with the key? Currently, I have not tried to do anything in this direction.
    Thanks in advance for all tips.
    bula17
    Help: 52
    Rate: 295
    The lock is integrated but before replacing, review the door - post installations.
  • #3 16289263
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Thanks for the info about the zip. Can you tell what the lock - key case looks like? The key lock is a separate element, or when replacing the lock with an actuator, we also lose the ability to open the door with the existing key?
    bula17
    Help: 52
    Rate: 295
    Replacing the lock does not involve a new key.
  • #5 16290552
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Thanks for the info and tips.
    I will ask - locks from the 3D version are interchangeable with locks from the 5D version?
