Best Graphics Card for i5 4440: ASUS Radeon R9 270 OC to GTX 1060 Upgrade, Corsair VS550, 8GB RAM
lukasbiggie 5175 13
What graphics card should I buy to improve gaming performance on an i5-4440 with a Corsair VS550 PSU?
A GTX 1060 6GB is the most commonly recommended upgrade for your i5-4440 and Corsair VS550 setup, and it fits your budget [#16293450][#16295583] If you want a better-cooled version, users suggested the Gigabyte WindForce II OC or Asus Strix model [#16295583][#16293773] One reply also said the RX 480 is a valid alternative: cheaper, a bit stronger in DX12, while the GTX 1060 is better in DX11 and uses less power [#16293451][#16293992] Before or alongside the GPU swap, adding RAM was recommended because it noticeably improves game comfort [#16293297][#16293376]
  • Seeking a GTX 1060 upgrade for i5-4440 gaming
    #1 16293273
    lukasbiggie
    Hello, what graphics card to buy for this processor to improve gaming performance? Currently my graphics card is:
    Asus Radeon R9 270 OC 2GB DDR5
    The power supply is: Corsair VS550
    RAM:
    https://www.morele.net/pamiec-crucial-ballist...-non-ecc-1-5v-bls2cp4g3d1609ds1s00ceu-472804/
    I was thinking about the GTX 1060
    https://www.morele.net/karta-graficzna-gigaby...92-bit-2xdvi-d-hdmi-dp-box-gv-n1060wf2oc-6gd- 974808 /
    The maximum budget is PLN 1,300.
    I had to edit, gave the wrong ram memory.
  • #2 16293297
    sosarek
    Help: 9320
    Rate: 15532
    Start with adding RAM - then the comfort of the game will increase.
    Z
    Pka, Poznań, 60-850
  • #3 16293370
    lukasbiggie
    ok, I will increase to 16GB, but what graphics card should I buy? Because the frames will not help me much in Just Cause 3 or BF1
  • #4 16293376
    sosarek
    Help: 9320
    Rate: 15532
    Well, you're in a BIG mistake, even with the GTX1070 and 4GB RAM you won't play comfortably - the card is not everything, the operating memory is also important.
    Even adding another 4GB will improve the performance of the set.
    Z
    Pka, Poznań, 60-850
  • Recommend RX 480 over GTX 1060 for future games
    #7 16293451
    cxzcxz123
    Level 32  
    Help: 140
    Rate: 284
    With current games, 8GB is enough, so you can buy 4GB for now and it will be enough.
    As for the card, there are two proposals in your budget that are noteworthy. GTX 1060 and RX 480. Radeon is a cheaper option so far, but it does not mean that it is worse. GTX 1060 is better in DX11 games and RX 480 better in DX12 games. In my opinion, Radeons can handle the passage of time better and newer games will probably perform better on Radeon. Therefore, and also because of the price difference, I would take the RX.
  • Choosing GTX 1060 for Windows 7 compatibility and game performance
    #8 16293469
    lukasbiggie
    I thought about Radeon, but I'm afraid that again when a new game comes out, it will be a situation like with "GTA 5", where AMD graphics cards "clashed" with Intel processors, I have never achieved such performance as with, for example:
    i5 4440 and GTX750
    and apparently they are very similar graphics cards, the GTX was much cheaper when I was buying my R9 270.
    I think I will decide on the GTX 1060, because the DX 12 only works on the W10, and I use the W7 myself and I have no intention of changing the system.
  • #10 16293860
    n.vision
    Help: 108
    Rate: 260
    The Gtx 1060 is no better choice. Half a year ago, RXs were weaker in older games, usually stronger in newer ones. At the moment the situation has changed because AMD has released a lot of patches for bad drivers. For proof, I suggest you watch the tests of these cards not older than two months
  • #11 16293940
    lukasbiggie
    but how will it work on dx11? because dx12 will not install on Windows 7.
  • GTX 1060 efficiency versus RX 480 memory longevity
    #12 16293992
    n.vision
    Help: 108
    Rate: 260
    You have an original system and you don't want to slim down? Well, the matter is debatable, it's best to look at the reviews yourself. But as I say, those from two months ago, others are out of date. Both cards are similar, in such a situation I wouldn't know what to choose. The GTX has a lower power consumption and is probably a bit more efficient, depending on the title, but the RX has 8GB of RAM and will probably be supported longer by well-optimized drivers. That's my opinion, I would hesitate. Btw, think about it Windows 10, because Microsoft is putting a heavy pressure on the market and more and more games are supported only on this system
  • #13 16294028
    lukasbiggie
    I used to be used to XP, when the "seven" went cheaper, I bought "7", now I feel good on it, if none of my favorite games come out on W7, then I will buy updates.
The discussion revolves around selecting a suitable graphics card to upgrade from an ASUS Radeon R9 270 OC for improved gaming performance with an Intel i5 4440 processor. The user is considering the GTX 1060, with a budget of PLN 1,300, and has been advised to also consider increasing RAM to 16GB for better overall performance. Responses highlight the importance of both the graphics card and RAM, with suggestions for alternatives like the RX 480, which may perform better in newer games. The GTX 1060 is generally recommended for its efficiency and compatibility, although concerns about driver support and performance in older games are noted. The user expresses a preference for staying on Windows 7, which limits options for utilizing DirectX 12.
