MAN L2000 8.140: EDC Light On, Loss of Power, Engine Heating Indicator Blinking - Possible Causes
kopytko686 15561 15
What can cause the EDC light, temporary loss of power, and blinking glow-plug lamp on a MAN L2000 8.140, and how do I read the fault code?
Read the flash codes first: connect a bulb to X201/X210 near the diagnostic socket in the fuse box, then count the flashes [#16477921] The EDC light means there is an ECU fault, and the uneven running with a 1700 rpm limit until restart suggests the controller is entering a fault mode [#16480461] In this thread, flash code 58 was decoded as a fuel pump driver error [#16499497] If the wiring is OK, the injection pump should be repaired or checked on the bench [#16499497] One reply also suggested checking the control injection resistance, if your engine has that component [#16480415]
  • #1 16477557
    kopytko686
    Rate: 27
    I bought a mana L2000 8.140 a few days ago and yesterday the edc light came on while driving, and as if the car lost a little power (I was going empty so it's hard to tell), after turning off the car and restarting it was ok today I was driving and it turned on again while driving. I was looking on the internet for information on how to read error codes but I did not find exact information, I only know that you need to connect a light bulb somewhere ...
    PS. from the moment the EDC lights up, I noticed that when firing even a hot car, the engine heating indicator blinks (this spiral) and stops flashing only after a few seconds after starting the car, I don't know if it has anything to do with it ...?
    best regards
  • #2 16477725
    mariomalinie
    Level 19  
    Help: 32
    Rate: 166
    Hello!
    Provide more information about the car and I will try to help. This is the motor on the vp44 pump?
  • #3 16477838
    kopytko686
    Rate: 27
    I'm not sure what pump the car is on, it is exactly the LE 8.140C man from 2002.
  • #4 16477900
    darfur5
    Help: 267
    Rate: 1716
    Since you have recently had the car, you must have changed the oil and filters? This man is on the rotary injection pump.
  • #5 16477921
    mariomalinie
    Level 19  
    Help: 32
    Rate: 166
    Here is a diagram where to connect a light bulb to read flash codes. Cubes X201 and X210 are next to the diagnostic socket in the fuse box.
  • #6 16480415
    Cobrat
    Help: 35
    Rate: 502
    Check the control injection resistance.
  • #7 16480446
    kopytko686
    Rate: 27
    I haven't had time to read the code ... but a new symptom has appeared
    when firing for the first time, the EDC lights up, the engine runs unevenly (gently) and has a maximum of 1700 rpm.
    after extinguishing and restarting it, everything is fine ...
  • #8 16480461
    saron22
    Trucks specialist
    Help: 308
    Rate: 1604
    Since the EDC lights up, there will be an error in the controller. Read this error or errors and think about what to do about it later.
  • #9 16480466
    darfur5
    Help: 267
    Rate: 1716
    And start with this item.
  • #10 16480508
    mariomalinie
    Level 19  
    Help: 32
    Rate: 166
    As long as there is a control injector. Not all motors on the VP44 pump have it.
  • #11 16480514
    darfur5
    Help: 267
    Rate: 1716
    So you have to check it out.
  • #12 16498811
    kopytko686
    Rate: 27
    I read errors ... Only in a strange way the bulb shines in the opposite way than it should, ie when it should not shine, it shines ... and according to Flash codes come out 5 long and 8 short. No other error after it appears ... I will try to add a video, maybe you can decode something more ..
  • #13 16499497
    mariomalinie
    Level 19  
    Help: 32
    Rate: 166
    Code 58 indicates a fuel pump driver error. If the wires are okay, then the pump to the repairman on the table.
  • #14 20511546
    andr3utz
    Hello, have you solved your problem with EDC ?
  • #15 20842237
    dakki82
    I have the same problem with my 25.284. I changed the pump vp44 and the injector.... please help.
  • #16 20843999
    ROKADI
    Help: 43
    Rate: 194
    Do computer diagnostics or, as the colleagues above, write flash codes, then we can help
    ROKADI - MAN
    Kętrzyńskiego 8, Olsztyn, 10-506 | Tel.: 660-XXX-XXX (Show)
The discussion revolves around issues with a MAN L2000 8.140 vehicle, specifically concerning the EDC (Electronic Diesel Control) light activation, loss of power, and blinking engine heating indicator. The user reports intermittent EDC light activation while driving, accompanied by a temporary loss of power and engine irregularities. Responses suggest checking the rotary injection pump, reading error codes via a diagnostic light bulb connection, and examining the control injection resistance. A specific error code (58) indicating a fuel pump driver issue is mentioned, prompting further investigation into wiring and potential repairs. The user also notes unusual behavior in the diagnostic light, complicating error code interpretation.
