Modifying Einhell BT-GW-150 H8513 PCB for Better Speed Control
jtrybul111 16608 8
  • #1 16302931
    jtrybul111
    I need advice on how to modify the H8513 plate of the Einhell BT-GW150 migomat feeder. As the wire feeder was dead in my blink, I needed to replace it with a new one. After the replacement, it turned out that the new wire feeds too quickly and despite the speed control on the potentiometer, it is difficult to weld only in the lower range. Of course, the feeder is some standard 12V plastic, but the motor is kind of a bit bigger. The control board is standard as in the BT-GW-190 with the symbol H8513 and it is certainly functional, because I checked it on another twin Powermat3 and the operation is completely similar. I am asking for advice on what and how to convert on the PCB (which resistors should be replaced) in order to obtain a larger adjustment range (of course with an indication of low speed, which may even be close to zero).
    I will be grateful for your help.
    • Modifying Einhell BT-GW-150 H8513 PCB for Better Speed Control bt-gw190d_1e5c937.jpg (386.64 KB) You must be logged in to download this attachment.
  • #2 16303443
    SQ5AZP
    Help: 238
    Rate: 477
    You bought a 12V feeder instead of 24V - and here's the whole problem. The thyristor regulator will be difficult to adapt to work with such a large delay angle. (he can "break off the fire").
  • #3 16304944
    jtrybul111
    Well, it can be like that, but it was already equipped with 12V and it worked somehow. In addition, somewhere on the forum I read the theory that the drive should be for the same voltage as the PCB, and mine is supposed to be 12V. Today I "played" for a while and checked the feeding speed of the feeders. It turned out that the old feeder feeds about 30-35% slower than the new one. Perhaps it would be enough for the correct operation of the migomat. However, the feeder is already there and it would be the cheapest to convert the plate (if it is relatively easy).
  • #4 16305621
    SQ5AZP
    Help: 238
    Rate: 477
    Add 1k? in series with the potentiometer and check.
    Depending on which end you turn it on, you will get a shift of the RPM range up or down.
  • Testing parallel 10 kΩ resistor to reduce R10 value
    #5 16305770
    jtrybul111
    I thought about a solution like this, but I couldn't do it yesterday. But I wanted to replace the potentiometer with another to maintain the control characteristics, and if I add resistance in series, I do not know how it will react. Of course, I will try to do this - it may just work correctly. Before that, I will try to change the R10 value to a smaller one (I will add a second 10k? to it, because it's the easiest way without removing the plate) and I'll see.
    But yesterday I connected another feeder (probably from Kabit na 24V, at least such a shallow one) and it behaved very much like the old one, i.e. a bit slower. And does anyone know at what speeds such a wire in a migomat should run at all?
  • #6 16306064
    SQ5AZP
    Help: 238
    Rate: 477
    The wire speed of the standard Bester 1800 turbo feeder is from 0 to 18 m / min.
  • #7 16326285
    jtrybul111
    Hello after the break.
    I did not manage to do much on the subject, because the feeder motor must actually be 24V and the lower revs are not necessarily satisfactory. As for the changes in the values of the elements on the controller board, only the replacement of R14 from 430 ? to 1.5 k? introduces some improvement in the lower range. Engine operation is still uneven. The engine works like "jerks". In addition, what I thought when analyzing the diagram, the regulation is not in the full range of the potentiometer. In extreme it is slow, then as if it slows down a little more and only then accelerates to high speed. So for now "kiszka". The next step is to control the circuit from an external transformer, maybe it will be better.
  • #8 16326329
    SQ5AZP
    Help: 238
    Rate: 477
    Or build a layout like the US-25 straight on Ne555.
    link
  • #9 16405245
    jtrybul111
    As I wrote it and did it, that is, I powered the circuit from an external transformer and it's ok. Maybe it's an easy way, but it's effective. I consider the topic closed.
The discussion revolves around modifying the H8513 PCB of the Einhell BT-GW-150 migomat feeder to improve wire feed speed control. The original poster replaced a faulty 12V wire feeder but found that the new feeder operates too quickly, making it difficult to weld at lower speeds. Suggestions include adding resistance in series with the potentiometer and changing resistor values on the PCB to achieve a broader adjustment range. The user experimented with different configurations, including using a 24V feeder, and ultimately found success by powering the circuit with an external transformer, which resolved the speed control issues.
