Bosch PIE631FB1E Induction Cooker - Assembly Instructions, L1, L2, L3, N, PE Wire Connection
berrrcik21 61545 8
  • #1 16308124
    berrrcik21
    I equip the kitchen, I chose the Bosch PIE631FB1E induction cooker. I'm looking at the assembly / connection instructions and I am a bit puzzled about connecting. I had a little to do with motors and 3-phase inverters (fact - with heating or induction elements), but I did not see such a 3-phase connection ...
    How do I have 5 wires, i.e. L1, L2, L3, N, PE are L1 and L2 to connect and connect to one connector ??? Should not it be that L1 to 1, L2 to 2, L3 to 3, N to N and PE to PE?
    Thank you in advance for your help :)
  • #2 16308171
    guciq
    Help: 24
    Rate: 134
    Connect as reported by the producer. The auction works on 1 phase or 2. On 3 probably never, or at least I have not encountered.
  • #3 16308172
    kkas12
    Help: 1076
    Rate: 4312
    As you can see, the third phase is unnecessary.
    So do not just make the most of what the producer wrote.
    At home I would use the method shown in the third drawing.
  • #4 16309199
    berrrcik21
    Ok, I think it will be necessary to do so, although it still seems strange to me ... One phase will be more heavily loaded than the other ... I do not have a good deal ...
    Below is an example diagram of the first whirpool board where all the phases are connected
    kkas12 wrote:
    As you can see, the third phase is unnecessary. So do not just make the most of what the producer wrote. At home I would use the method shown in the third drawing.
    Only method No. 3 requires two independent neutral wires, I have only one in the installation ... So there remains only method 1.
  • #5 16309214
    kkas12
    Help: 1076
    Rate: 4312
    Not true.
    These two connected wires N These are the wires in the cable connecting the cooker to the installation.
    Do not be offended, but you will see that it will be better for you and for the CD if you entrust the oven to a competent person.
    She also initiates the joining. This parcel is a condition for accepting the warranty in the event of a subsequent damage to the disc.
    And do not give instructions from the first edge of the disc, only read the one that the producer has joined.
  • #6 16309244
    qadam12
    Help: 62
    Rate: 254
    On the terminal board from post 4, terminal L3 is a dummy. So that the cable from L3 does not "wander" on the record. :)
  • #7 16309270
    kkas12
    Help: 1076
    Rate: 4312
    The drawing from post no. 4 does not concern the title disc, so it makes no sense to deal with it.
  • #8 16309359
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1623
    When it comes to connecting the plate, an electrician with a valid qualification or authorized service should do it (see how you have in the manual, warranty - in addition they will know how to connect), otherwise you lose the guarantee.
  • #9 16309494
    berrrcik21
    I think I will have to do it, the cost of the connection will be small, and there will be paper on it if something goes wrong with the disc. Thank you all for your help :)
The discussion revolves around the assembly and connection instructions for the Bosch PIE631FB1E induction cooker. The user is confused about the wiring, specifically the connection of five wires: L1, L2, L3, N, and PE. Responses clarify that the cooker operates on one or two phases, with L3 being a dummy terminal. It is advised to follow the manufacturer's instructions and consult a qualified electrician for proper installation to avoid warranty issues. The user acknowledges the need for professional help to ensure correct wiring and documentation.
