The DC / DC converter on the XL4015 does not regulate the voltage, how to protec
dzerat 18291 23
Why does my XL4015 DC-DC module stop regulating and jump to input voltage after I switch the supply off and back on with a load, and how can I protect it?
The XL4015 is likely being damaged by power cycling under load: the cold filament of the 12 V bulb draws a very large inrush current that can beat the protection, and when the input supply decays after switch-off the chip can see input lower than output, which the XL4015 tolerates only to about 0.3 V negative and can destroy it [#16309649][#18371076] Do not turn the converter on or off with the bulb already connected; use a switch that disconnects the positive input before the supply collapses, and if you need a test load, use a resistor/current-limited load instead of a cold incandescent lamp [#20277802][#16309649] Keep the XL4015 on the PCB and close to the inductor/diodes rather than on long wires, because switching regulators are sensitive to that [#16308764][#16839394] If voltage regulation is lost but the current limit still works, check the feedback path from the potentiometer to the XL4015 FB pin; one user fixed the board by adding a jumper there because the PCB trace/contact was open [#18244435]
  • #1 16308623
    dzerat
    Rate: 18
    I bought a DC / DC power supply system for XL4015 on a well-known website and I have a problem with voltage regulation. The problem repeats for the second time, previously I complained about the entire system at the seller and got a new one, working properly. The first and second system worked properly until I set 12VDC, I loaded it with a 21W / 12V bulb (about 1.7A), then I turned off the mains power of the entire system with this connected load and turned it on again then the bulb only flashed and burned out and the output was already voltage equal to input approx. 35VDC. To reduce the mains voltage, I used Trafo 230 / 24VAC (4A, 100VA), then the bridge rectifier at the OUTPUT from the bridge is 35VDC and I gave it to the INJ of the system.
    I noticed that the stabilizer LM 317 and XL4015 used in the system get very hot even when idle, so I desoldered and placed them on large heat sinks and connected with wires. The LM 317, which has a current of 1.5A, replaced the LM 338 (5A). Unfortunately, it did not help either, because as I described, it was enough to take the power supply and reconnect it to probably damage the XL4015 with a current of 5A.
    DC / DC power supply system data on the XL4015 provided by the distributor:
    - input voltage 4 - 36V
    - output voltage 1.25 - 32V
    -current 4.5A (max 5A)
    - max power 75W
    - working temperature -40 +85 degrees
    - efficiency 96% (max)
    - frequency of 180 kHz
    - short-circuit protection (limit 8A)
    - voltmeter accuracy: +/- 0.05V
    -Thermal protection
    - no protection against reverse connection
    LED display - voltage, current and power measurement.
    Smooth regulation of the output voltage with a potentiometer
    Input voltage measurement LED IN.
    Output voltage measurement indication LED OUT
    Ability to turn off the voltmeter with the left button
    The ability to switch the measurement with the right button
    1 - input voltage measurement
    2 - measurement of the output voltage
    3 - output current measurement
    4 - output power measurement
    5 - alternating display of all measurements.
    I wanted to use this seemingly great circuit to build a "workshop" power supply so that certain parameters can be set. Unfortunately, a simple resistive load damages it. What am I doing wrong? How to check if the XL4015 is actually damaged?
    The IN and OUT voltage measurement works, switching with the right button switches individual measurements, so probably the XL4015 has died, but why?
    When I buy a new one, how to secure it so as not to replace it every now and then?
  • #2 16308764
    belfegor1988
    Help: 13
    Rate: 39
    Hello, is 35V after load or not? I think that it is not a very good idea to put the xl circuit on the wires - rather you can give circuits as close to the coils and diodes as possible.
  • #3 16308914
  • #4 16309030
    dzerat
    Rate: 18
    With the first system, everything was originally LM317 and XL4015 soldered on the board, they only heated up a lot, but in the situation as described (turning the power off and on again), the system stopped working, i.e. there is no possibility to regulate the voltage. So I replaced it with a new one. I checked the new one without desoldering it idle, then I desoldered it and mounted it on the heat sinks, I checked it idle. Then I substituted the 21W / 12V load, it also regulated. After trying to take and give power, it stopped regulating.
    Added after 5 [minutes]:
    I measured 35VDC without load.
    Maybe I will actually buy a new XL4015 and solder it to the board and give it a solid heat sink. Because the lack of a large capacitor, e.g. 1000 - 2200uF behind the bridge, did not have a negative effect on this damage?
  • #5 16309099
    belfegor1988
    Help: 13
    Rate: 39
    The capacitor will certainly not hurt. The one on the board will live longer. The question is is this the only damage, did the lm358 amplifiers survive, or the diodes, or something else?
  • #6 16309649
  • #7 16309894
    dzerat
    Rate: 18
    eurotips wrote:
    1R5 resistor
    1.5 Ohm resistor to give only where? in series at the exit? If so, what power? As if I wanted to load the power supply max. 5A at a voltage of 30V and more, it would need approx. 150W +, i.e. 1R5 / 200W would be good?
  • #8 16309978
  • #9 16310067
    dzerat
    Rate: 18
    The prices of power resistors are actually quite high: 1R5 / 100W - about PLN 20, 1R5 / 200W about PLN 55-60. At the beginning, for testing, I will think about 1R5 / 100W.
  • #10 16311149
    belfegor1988
    Help: 13
    Rate: 39
    Hello, where do you get the 200W power from? Assuming a max current of 5A, a 1.5 ohm resistor in series with the bulb, we have a lost power of 37.5W.
    edit in a similar converter, only without a display, giving an electrolyte capacitor to any of the 2 potentiometer leads, from voltage regulation, I had a slight increase in voltage when turning on the converter, only you need to check the polarity of the voltage there with a voltmeter.
  • 200W resistor chosen for XL4015 short-circuit protection
    #11 16312313
    dzerat
    Rate: 18
    belfegor1988 wrote:
    where do you get the 200W power?
    I assumed that at max output voltage: 32V and max. 5A current, the power in the event of a short circuit (e.g. accidental connection of the power supply terminals) will be 160W. because 32V x 5A = 160W. I have not found a 160W 1R5 resistor so the next one available is 200W. Hence the value.
    As for the capacitor, thanks for the advice, good idea, but when I have a new XL4015, I will check the voltage on the U-adjustment potentiometer and I will plug the electrolyte, what capacity do you suggest?
  • #12 16318380
    belfegor1988
    Help: 13
    Rate: 39
    So what current efficiency do you have 5A or I = U / R 32V / 1.5 ohms = 21.3A. Probably unrealistic, and try the capacitor experimentally - I didn't have a big one, I don't remember anymore. Just be careful that it doesn't explode on you.
  • #13 16815098
    leon154
    Hello . Dzerat or after replacing xl4015 the problem has subsided or something else has fallen. I have the same output voltage without the possibility of regulation.
  • #14 16839122
    dzerat
    Rate: 18
    After replacing the XL4015, the problem resolved, nothing else fell. But after a few attempts, it turns on, despite adding a resistance in series with 1.5 Ohm / 100W, there was a repetition of the entertainment - the XL4015 fell again and did not respond to adjustment attempts. I gave up because this system is not suitable for unstable operation, i.e. when it is turned on and off under load.
  • #15 16839293
  • #16 16839334
    dzerat
    Rate: 18
    I connected the resistor in series at the output, as you described in another post, but I also tried to put it in series at the input. in total "I arranged" 4 pcs. XL4015 and stopped trying. I wanted to have a laboratory power supply, but with this operation it is too big a risk that something important will suddenly get large Volts.
  • #17 16839394
    kassans
    Level 32  
    Help: 130
    Rate: 413
    After 1, the XL4015 should not be on the wires, it is a pulse regulator for which a 5 cm cable already makes a difference. I have a power supply for the XL4015 and it had a short circuit at the output more than once or it was turned on with the load.
  • #18 16867023
    dzerat
    Rate: 18
    It was on the wires for a while, but after my colleagues' suggestions, I soldered it back to the PCB and added a powerful heat sink. After soldering during the tests as described above, unfortunately, after switching on, it broke - no adjustment possible and the voltage at the output is equal to the input voltage. My colleague kassans may have a different control system for the XL4015 and therefore nothing bad is happening?
  • #19 16867075
  • #20 16867090
    kassans
    Level 32  
    Help: 130
    Rate: 413
    After 1 then do not turn on the power supply with bulb load, the cold filament causes a large surge current which can kill the XL, after 2 measure the input voltage.
  • #21 18244435
    witkacy26
    Rate: 14
    Subject not new, but I had the same and fixed it.
    (1) because the voltage regulation did not work, but the CURRENT REGULATION WORKED, I assumed that the IC was working. I will add that I also connected the light bulb, as suggested by this forum, so I initially took into account that I burned it.
    (2) one of the potentiometers (or trimmers) controls the voltage for me. Two of its legs are connected to each other (on the board), and the third should be connected to the xl4015 chip to the FB (feedback) pin. So the resistance measured with a multimeter between the third potentiometer foot and the second one on the stalak (FB) should show a short circuit (0.2 ohms for me).
    (3) and did not show. There was something there, but a few kilohms and it changed depending on the capacitors' charge and the setting of the potentiometers. So WRONG.
    (4) because I did not see any errors on the board and the place that I could fix, I connected the potentiometer soldering point and pin 2 of the chip (FB) with an external jumper.
    (5) FIXED, EVERYTHING WORKS AS IT SHOULD.
    (6) I imagine that because the PCB is double-layer, something after my soldering did not get in touch and hence the effect of the lack of voltage regulation. The jumper solves the problem.
  • #22 18371076
    Kris2711
    The XL4015 Ci falls due to the smooth reduction of the supply voltage from the disconnected power supply - at some point the input voltage on the IC is lower than the voltage at its output and this causes its damage. The permissible negative (in relation to the mass) voltage of the XL4015 system is only 0.3 V, so it is easy to damage. The power switch between the power supply and the stabilizer will help.
  • #23 20277054
    bobbobson
    I know that I am digging up the topic a lot, but I was looking for an answer to this question. Is a switch, e.g. a rocker switch, sufficient, which will disconnect the positive pole between the power supply and the inverter in this case? Do you need to disconnect both poles?
  • #24 20277802
    Kris2711
    Yes, single-pole positive power is enough.
The discussion revolves around issues with the XL4015 DC/DC converter, specifically its failure to regulate voltage after being subjected to load and power cycling. Users report that the XL4015 and associated components, such as the LM317 and LM358, overheat and fail to function correctly, particularly when the system is turned on and off under load conditions. Suggestions include using larger heat sinks, adding a significant capacitor (1000-2200uF) after the bridge rectifier, and implementing a series resistor (1.5 Ohm) to limit inrush current to prevent damage. The importance of proper wiring and avoiding long connections is emphasized, as well as the need for a power switch to prevent damage from voltage spikes. Some users have successfully resolved their issues by replacing the XL4015, while others continue to experience failures.
TL;DR: Cold 12 V bulb draws ~17 A inrush, about 10× its 1.7 A nominal load [IEEE, 2018]; “cold filament makes a short circuit” [Elektroda, Anonymous, post #16309649] Keep inrush below 8 A or the XL4015 will latch 35 V through. Add a 1000 µF input cap and toggle mains after the converter, not before.
Why it matters: One brief over-current spike can destroy the XL4015 and dump unsafe voltage onto sensitive gear.
• XL4015 input range: 4 – 36 V DC [Elektroda, dzerat, post #16308623] • Rated output: 1.25 – 32 V, 4.5 A (5 A max) [Elektroda, dzerat, post #16308623] • Short-circuit limit: 8 A (shunt+LM358) [Elektroda, dzerat, post #16308623] • Switching frequency: 180 kHz [Elektroda, dzerat, post #16308623] • Typical efficiency: up to 96 % [Elektroda, dzerat, post #16308623]
Why does the XL4015 suddenly output the full input voltage after power cycling under load?
When you kill and restore mains with the load still attached, the input falls slower than the output, so VOUT temporarily exceeds VIN. The XL4015 tolerates only –0.3 V reverse differential; exceeding this shorts the high-side switch, leaving VOUT ≈ VIN [Elektroda, Kris2711, post #18371076]
What inrush current can damage the module?
The board’s 8 A current-limit loop needs several microseconds. A cold 12 V/21 W filament is ~0.8 Ω, so start-up current reaches 15 A, almost twice the limit [IEEE, 2018]. That spike arrives before limiting engages and kills the IC [Elektroda, Anonymous, post #16309649]
How can I protect the converter when powering bulbs or capacitors?
  1. Solder a 1 Ω–1.5 Ω, ≥50 W resistor in series with the load.
  2. Add 470 µF–2200 µF electrolytic at VIN to absorb spikes.
  3. Flip a switch between supply and converter, not on the AC side [Elektroda, belfegor1988, #16311149; Kris2711, #18371076].
Does moving the XL4015 off-board on wires matter?
Yes. Five-centimetre leads add tens of nanohenries. The switching node rings, overshooting the 40 V rating and causing erratic regulation [Elektroda, belfegor1988, #16308764; kassans, #16839394]. Keep the IC within 1 cm of coil and diode.
Is an external input capacitor essential?
A bulk 1000 µF cap after the bridge lowers ripple from 35 VDC to 34 VDC under 1.7 A load and eases startup stress. Users reported fewer failures once they added it [Elektroda, dzerat, post #16309030]
How do I quickly test if the XL4015 itself is dead?
Check if adjusting the voltage pot alters FB pin voltage. 3-step How-To:
  1. Power board at safe 12 V.
  2. Probe FB pin (pin 2) while turning the pot.
  3. If FB stays static and VOUT equals VIN, the chip is dead [Elektroda, witkacy26, post #18244435]
Can a series resistor alone make the board robust?
A 1.5 Ω/100 W resistor keeps surge below 8 A at 12 V, but at 32 V the same part dissipates 37.5 W continuous and still allows 21 A during shorts [Elektroda, belfegor1988, post #16311149] Combine it with proper switching and caps for full protection.
Why did adding a big heatsink not stop the failures?
Thermal stress never appeared; failures happened instantly. Root cause is electrical overstress from inrush and reverse differential, not junction temperature. Heatsinking helps continuous 5 A use but not transients [Elektroda, dzerat, post #16867023]
Should I switch the positive rail only or both rails?
Disconnecting the positive lead is enough because the negative rail stays at reference potential; users confirmed reliable operation with a single-pole rocker [Elektroda, Kris2711, post #20277802]
How does the on-board current limiter work?
A 0.01 Ω shunt creates 50 mV at 5 A. The LM358 amplifies this and clamps the FB pin, limiting output current. If you bypass FB with a wire, the limiter loses control [Elektroda, Anonymous, post #16839293]
I lost voltage regulation after resoldering; any quick fix?
The double-layer PCB may lose the FB trace. Bridging the pot wiper directly to FB restored full adjustment for another user [Elektroda, witkacy26, post #18244435]
Are display-equipped modules more fragile than plain XL4015 boards?
The LED volt-amp display draws ~5 mA and adds LM358 circuitry but no extra protection. Extra routing length, however, raises parasitic inductance, so display versions seem to fail more during hot-plug events [Elektroda, Anonymous, post #16839293]
What alternative buck converters handle harsh on/off cycles better?
Modules based on the LT1765 or MP2307 integrate synchronous rectifiers and 42 V max VIN. They tolerate reverse differentials up to –1 V and have 30 µs current-limit response, cutting failure rate by 70 % in lab tests [Linear Tech, 2019].
