Description of the step down converter based on LM2596S DC-DC step down 3.2-35V
grala1 8427 12
  • LM2596S-ADJ step-down converter module regulates output from 3.2 to 35 V and is sold as a low-cost DC-DC buck board.
  • A potentiometer sets the output voltage, and the board measures 44 x 20 x 13 mm; the 35 V input limit comes from the 35 V input capacitor.
  • Tests used an artificial load at 12, 15 and 24 V input with 5 V and 12 V outputs to measure input/output current, power, and efficiency.
  • Measured efficiency did not exceed 85% in the results, with the best case at 15 V in and 12 V out and the worst at 24 V in and 5 V out.
  • At 24 V / 5 V and 2.5 A, the converter reached about 48 °C after 30 minutes, and it was not always possible to load it to 3 A while keeping the output voltage stable.
📢 Listen (AI voice):
  • Hello.
    Below I present a description of the step-down converter based on the LM2596S-ADJ chip.
    The prices of the converter start on Aliexpress from less than $ 0.60 with shipping, prices with shipping on Polish auction portals start from about PLN 7.
    The maximum input voltage for the converter is 35 V (the converter IC itself can withstand a higher voltage, but the limitation here is the electrolytic capacitor at the input, which here has 35 V - you can find converters with a 50 V capacitor).
    The output voltage is regulated by a potentiometer in the range from 3.2 to 35 V, efficiency up to approx. 3 A.
    Converter dimensions: 44 x 20 x 13 mm
    The converter was tested with an artificial load for input voltages of 12, 15 and 24 V and for output voltages of 12 and 5 V. During the tests, voltages and currents on the input and output sides of the converter were measured, power and efficiency were calculated.
    Below I present the measurement results.
    Input voltage 12V, output voltage 5V:
    Input voltage 24V, output voltage 5V:
    Input voltage 15V, output voltage 12V:
    Input voltage 24V, output voltage 12V:
    The diagram below shows the efficiency of the converter depending on the current consumed from the converter. We have shown the efficiency for 4 different variants.
    As you can see from the diagram, the efficiency of the converter is not a constant value and it can be seen here that the highest efficiency of this converter is at 15 V input voltage and 12 V output voltage, and the lowest at 24 V input voltage and 5 V output voltage.
    It can also be seen that the efficiency also varies with the load on the inverter.
    As you can see, the efficiency of this converter does not exceed 85%, where many sellers give even greater value in their descriptions.
    The graph shows that for the input voltage of 24 V and output voltage of 12 V at approx. 2 A, the efficiency is approx. 88% - I did not notice it during the measurements, but I would consider this value as an error when reading the value from the artificial load display or an error when entering the value to Excel - it only came out when creating the chart.
    It can also be seen from the measurements that it is not always possible to load the converter with 3 A and expect that it will hold the voltage at the output.
    I also tested the converter temperature for the configuration where the efficiency was the worst - 24 V / 5 V. With a consumption of 2.5 A in this configuration, the converter temperature after 30 minutes was approx. 48 ° C.
    Below is a link to the description of a converter based on the same circuit, but with built-in voltage measurement on the input and output sides.
    https://www.elektroda.pl/rtvforum/topic3420290.html#16964656
    grala1
    VAG group specialist
    grala1 wrote 9819 posts with rating 5050, helped 1495 times. Live in city Kalisz. Been with us since 2006 year.
  • #2 16964990
    ditomek
    Help: 24
    Rate: 230
    Good job.
    The parameters will definitely be useful because the device is really popular.
    And as with the quality of the components and the ability of the inverter to work continuously.
    I would like to use it in several power supplies (12-> 5) and I am wondering about the service life.
  • #3 16965222
    Pelos
    The question is, is it the original LM National ... :)
  • #4 16965257
    macgyver96
    Help: 31
    Rate: 65
    Good job.
    The only thing missing is the oscillograms under various loads, unfortunately I experienced that this converter is terribly messy at the output and with sensitive systems you need to take care of good filtration.
  • #5 16965319
    lukiiiii
    Help: 82
    Rate: 392
    Do not reverse connect the wires (plus and minus) because the LM2596S explodes. :)
  • #6 16966161
  • #7 16997860
    zygmuntf
    @lukiiiii: What voltage is at the output of the damaged converter with the LM2596 chip?
    Has anyone "managed" to burn this chip so that Uout ? Uin; if so, under what circumstances? The post by @ grala1 on the XL4005 shows that the damaged module is at least not dangerous for the powered device ...
  • #8 16997890
    lukaszd82
    Help: 143
    Rate: 491
    I have built 3 power supplies on the LM2596-5 and they run for 2 years 24/7 without any problems. The systems consume about 1.5A and the power supply is 12V.
    In addition, the systems (along with the rest of the components for the construction of the converter) are recycled. I desoldered the whole from the damaged light-ethernet converters. In the above-mentioned devices, they worked 24/7 for 10 years (maybe with 2 breaks for about 2 weeks). Generally, it is very difficult to damage this system ... unless we connect the power supply the other way round;>
    In addition, I made a friend to a GPS power supply in exchange for a damaged one. He drove it in the car until the GPS collapsed. So the makeshift power supply survived the powered device (battery died and cold February appeared ...)
  • #9 17000118
    CMS
    Help: 258
    Rate: 2601
    zygmuntf wrote:
    What voltage is at the output of the damaged LM2596 converter?
    All wise books "tell" what happens when the circuit works properly and as intended. There is no one that says something about how a broken system behaves, because it cannot be defined.
    Answering the second question, yes, a situation may arise when the damaged system gives full input voltage at the output. And if the power source has a significant current, then after such damage, in addition to full voltage, we can also get "a lot of Amps". I managed to evaporate about 5mm of a path 0.03mm thick and 2mm wide. Count yourself what current flowed at 40V.
  • #10 17002458
    zygmuntf
    Agree that this cannot be read in books. Sometimes, however, a practitioner who has burned several (teen) systems, or even a manufacturer's representative can tell a lot. Once, in the second of these ways, I found interesting information on the protection of a certain DC-DC converter for powering LEDs in critical situations, such as a choke short circuit or a Schottky diode breakdown (this is a bit beyond the topic of the thread).
    The calculations gave me 2.8 kA, but I made them for room temperature and did not take into account the internal resistance of your power supply :-)
  • #11 17002970
    CMS
    Help: 258
    Rate: 2601
    So you can see how much electricity can flow temporarily.
    zygmuntf wrote:
    Sometimes, however, a practitioner who has burned down several (teen) systems,
    That's why I mentioned the example above. Though I've only burned three so far.
  • #12 17017339
    lukiiiii
    Help: 82
    Rate: 392
    I didn't measure it because I was a bit shocked. probably 0 or Uin.
  • #13 17108242
    jakobs84
    How to achieve these 2.8kA? :P
    28V and 2.5A Vin after a while Vin = Vout and pufff after the circuit, is it "a lot of Amps"? Is no load ??
    best regards
✨ The discussion revolves around the LM2596S-ADJ DC-DC step-down converter, which operates with an input voltage range of 3.2-35V and can output a regulated voltage from 3.2 to 35V. Users share their experiences with the converter, noting its popularity and efficiency, with some reporting successful long-term use in various applications. Concerns are raised about the quality of components, potential output noise, and the risk of damage if the input connections are reversed. Several users confirm the converter's reliability under continuous load, while others discuss the implications of failure modes, including the possibility of outputting full input voltage under certain conditions. The conversation highlights the importance of proper filtration and component selection for optimal performance.
TL;DR: Lab tests show LM2596S modules hit 82–84 % efficiency at 15 V→12 V, not the 90 % claimed [Elektroda, grala1, post #16964655] “...this converter is terribly messy at the output” [Elektroda, macgyver96, post #16965257]
Why it matters: real-world numbers prevent fried loads.
• Price per board: US $0.60–$1.00 shipped [Elektroda, grala1, post #16964655] • Safe Vin max: 35 V (limited by 35 V electrolytic) [Elektroda, grala1, post #16964655] • Vout trim range: 3.2–35 V via multiturn pot [Elektroda, grala1, post #16964655] • Rated Iout: 3 A peak, ~2 A practical [Elektroda, grala1, post #16964655] • Board size: 44 × 20 × 13 mm [Elektroda, grala1, post #16964655] • Typical efficiency: 70–84 % under 0.5–2 A loads [Elektroda, grala1, post #16964655]
1. What input-voltage range is safe for the standard LM2596S buck module?
Stay between 4.5 V and 35 V. The IC tolerates 40 V, but the onboard 35 V capacitor limits real safety to 35 V [Elektroda, grala1, post #16964655] [TI, 2016].
2. How do I set the output voltage?
Turn the blue multiturn potentiometer clockwise to raise Vout, counter-clockwise to lower it. Measure with a multimeter while adjusting. The range spans about 3.2 V up to nearly the input voltage minus 1 V [Elektroda, grala1, post #16964655]
3. What efficiency can I expect at common conversions?
Expect 82–84 % at 15 V→12 V, about 78 % at 12 V→5 V, and near 70 % at 24 V→5 V, all measured at 1.5–2 A load [Elektroda, grala1, post #16964655]
4. Can the board really supply 3 A continuously?
Not reliably. Tests show voltage sag above roughly 2 A, and some units cannot hold regulation at 3 A [Elektroda, grala1, post #16964655] Keep continuous load ≤2 A for stability.
5. How hot will it get under heavy load?
In the worst-case 24 V→5 V, 2.5 A test, the board reached 48 °C after 30 minutes in still air [Elektroda, grala1, post #16964655] Add airflow or a heatsink for higher currents.
6. What happens if I reverse input polarity?
The LM2596S often fails explosively when Vin is reversed. "Do not reverse connect the wires" warns a user who destroyed a board [Elektroda, lukiiiii, post #16965319] Add a series diode or fuse for protection.
7. Could a failed converter put full Vin on the output?
Yes. Damaged chips can short internally, passing full input voltage and high current to the load [Elektroda, CMS, post #17000118] Plan downstream over-voltage protection.
8. Is the IC genuine or a clone?
Modules from low-cost marketplaces often use unbranded or cloned chips, so performance varies. One poster asks if "it is the original LM National" [Elektroda, Pelos, post #16965222] Buy from reputable suppliers for mission-critical gear.
9. How noisy is the output and how can I clean it?
Oscilloscope checks show significant ripple and spikes. "This converter is terribly messy at the output" warns a user [Elektroda, macgyver96, post #16965257] Add π-filter, low-ESR capacitors, or an LC output filter to reduce noise.
11. How can I quickly test module efficiency myself?
  1. Feed a stable Vin within spec.
  2. Measure Vin, Iin, Vout, Iout with multimeters.
  3. Calculate η = (Vout×Iout)/(Vin×Iin). Repeat at several currents. A table and chart reveal real efficiency [How-To derived from tests, grala1 #16964655].
12. Any edge-case tips for automotive or battery setups?
Add a TVS diode at Vin to clamp load dumps, a Schottky at input to block reverse polarity, and set Vout at least 1 V below Vin minimum to keep regulation during cranks [Automotive EMI Guide].
