Opel frontera 2.0 petrol 1993 - Does not start, check does not light.
Wojtek854 8436 5
  • #1 16314182
    Wojtek854
    Hello, I have a problem with the Opel fronterom 2.0 petrol, 1993. It does not start, the check does not light, the computer has not detected any errors. Please help. What could be happening?
  • #2 16314224
    magir
    Help: 128
    Rate: 379
    For me, such a problem concerned damage to the shaft position sensor. The error was not displayed when trying to start, the starter spun but did not ignite. He lit it was ok. Enthusiasm and nothing, and then problems again. After the exchange, calm.
  • #4 16320276
    Wojtek854
    Thank you for your help. It turned out to be a shaft position sensor :-)
  • #5 20334560
    huckberry88
    Welcome to the 2.0i frontera I have a problem the car has LPG the gas indicator light on petrol does not start the starter turns, I removed the clamp I moved the cables the engine was already cold and started please give me some info what it could be 666273347
  • #6 20334661
    michal_rybka
    Help: 283
    Rate: 771
    it is very possible that this double relay, as Col. Ociz wrote, one section turns on the fuel pump and the other plus on the coil and maybe the injection / sensors too, often there are cold February in it
