Renovation: Adding 60mm Socket in Load-Bearing Wall - Electrical Safety & Legal Aspects
Tomeksup 44712 42
Can I legally drill and install an extra socket box in a load-bearing wall, and what documentation or approval is needed?
A permit is generally not required, but you must not weaken the load-bearing wall, so the main issue is preserving the structure and strength of the panel [#16318636] An electrician’s documentation/approval is priced individually and can cost about PLN 500, PLN 1500, or PLN 3000 depending on local arrangements [#16318636] If a fire occurs and the cause of the installation cannot be determined, the insurer may refuse compensation [#16318636] If the socket is only to be mounted there and you do not need extra splices in the box, a shallow box is enough [#16318762] For large-panel buildings, it is better to route cables in the floor or under skirting boards and make only short vertical runs to the sockets, instead of chasing grooves or cutting reinforcement in the wall [#16322481][#16322373]
  • Permit and documentation requirements for adding a wall socket
    #1 16318549
    Tomeksup
    Help: 6
    Rate: 65
    1. I am doing a renovation in the room. There were two sockets as standard. The previous owner made a third, i.e. a 40mm can. I am changing the installation - it is over 40 years old. Some of the wires were burnt to bare wire. The cord was under the floor. The previous owner (electrician) added a cable from the nearest socket. He embedded in the wall and ran the cord across the floor. The wire was maybe 0.5mm sq. I tore it out right away and fucked it up.
    I put the cables in the floor next to the wall. In this made contact, I plan to give a 60mm can. I see the drill (with a can).
    Now my questions:
    I read that cables must not be laid in load-bearing walls. I agree with it. Some of my friends laughed at me saying: "How deep are you going to forge?) I put it in the floor, less forging.
    1. How is drilling additional sockets in the wall from the legal side? Any permits? The manager of the building said that what is in my apartment with an electrician "collapses" on him
    2. How much does it cost for an electrician to prepare documentation and approval of such an installation? Many people don't, but what if something catches fire from the installation? No insurance company will give you money.
  • No permit usually needed, but structural and insurance risks remain
    #2 16318636
    kozi966
    Help: 599
    Rate: 1288
    Permits are not. Rather, the issue of board strength - possibly deterioration of load-bearing / strength parameters.
    It is a matter of individual pricing. It can be PLN 500, PLN 1500 and PLN 3000. The matter of getting along with the local electricians.
    Indeed, the insurer may do nothing in the event of, for example, a fire for an undetermined cause.
  • #3 16318762
    kokapetyl
    Help: 1787
    Rate: 2105
    If the socket is to be mounted and you do not envisage any additional connections in this box, a shallow box will suffice.
  • #4 16318791
    zdzisiek1979
    Help: 563
    Rate: 1256
    You need a diamond crown or a square and you cut a square. You can drill and punch out. Do and that's it. Only neighbors w ... isz.
    The impact bit comes off. As I was doing it was a 125mm disc and drilling.
    The blocks are standing :D
  • #5 16320688
    Tomeksup
    Help: 6
    Rate: 65
    I missed 1.5 cm because I had a shallow can. I drilled with ELIZA widia lace - the cheapest. 1.5 cm - 2 minutes of work. Fortunately, that's all.
    I am looking for an electrician who will issue me papers for it.
  • #6 16320777
    kokapetyl
    Help: 1787
    Rate: 2105
    You were lucky
    Recently, while preparing the cans (14 pieces) for assembly, everything in CONCRETE, I found 6 rebars in one hole, usually 3 to 4.
    It took me a while.
  • #7 16320984
    Tomeksup
    Help: 6
    Rate: 65
    I moved the 15 cm door from the room in the 15 cm thick load-bearing wall. I cut out a whole bunch of reinforcement.
    With a large number of cans, it is worth buying good equipment.
    I wanted to borrow a diamond core from work, but I need a diameter of 160 or 300mm.
  • #8 16321160
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3533
    When there's another construction disaster, you'll wake up then.
  • #9 16321241
  • #10 16321309
    zbich70
    Help: 1171
    Rate: 6668
    And do you know that in the Polish People's Republic, steel was an extremely scarce commodity? The steel mills were working at full speed, but not necessarily for the domestic market.
    Back then, meat and vodka, and even chocolate for kids, were for cards. Steel and cement were special-purpose goods with exceptional marketability on the black market of the time.
    You have cut a bunch of reinforcement, the neighbor will also cut it, and the next neighbor as well.
    You can be sure whether the designers of these objects foreseen such actions and how much steel they designed in reserve, and how much the builders of that time could have pushed "to the left".
    Do you feel safe in your home ???
    Are you a hero because you have beaten an armored load-bearing wall? :|
  • #11 16321387
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    My dream on this forum is to finally see how the correct replacement of the electrical installation in a large plate looks like. Photos of the works are welcome :D
  • #12 16321396
    djlukas
    Help: 94
    Rate: 266
    I haven't heard a block collapse through the can openings yet. Don't panic.
  • #13 16321408
    zdzisiek1979
    Help: 563
    Rate: 1256
    Recently, when I mentioned it was such a dust from the angle that the camera shutter would blur :D
    After all, the block is not made of boards, but a load-bearing structure covered and stiffened with boards. Damn people, did you see how the gas opened the flats, pushing the plates onto the street? The plates are gone and the block is standing.
    Even to knock down a block you need to work hard.
  • #14 16321413
    elpapiotr
    Help: 1015
    Rate: 3533
    What hereby some colleagues are doing.
  • #15 16321441
    Łukasz-O
    Help: 654
    Rate: 4292
    Probably with bad results, because so far they are all standing ;)
  • #16 16321456
    retrofood
    Help: 1140
    Rate: 4800
    Come to me and I will show you one in which all the ceilings are bent. In the whole cage, small brick posts in the kitchens were removed, because they had been placed extremely out of place and disturbed people. Now everyone has an order from the district inspector and the management of the cooperative to restore the previous state. I don't know what they will do.
  • #17 16321460
    elpapiotr
    Help: 1015
    Rate: 3533
    From real life:
    The breach of the structure of the building with the joyful creativity of the builders during the renovation of the apartment resulted in the renovation of the apartment one floor above, including the filling of the cracked walls. Of course, at the investor's expense of this renovation.
    I had a lot of fun seeing the expressions of all of them. Of course, the building is still standing.
  • #18 16321476
    kkas12
    Help: 1076
    Rate: 4321
    Maybe it is time to consider how (and why exactly) the installation was carried out when these buildings were built, instead of bidding on how many steel people cut out.
    Maybe it is worth dusting off the antiquities to find out what the assembly was about and what the Wierbka-type accessories looked like.
  • #19 16321482
    Łukasz-O
    Help: 654
    Rate: 4292
    Krzysztof, I'm in favor, just remember that there were different systems.
    From real life:
    I had a lot of fun seeing the expressions of all of them. Of course, the building is still standing ... still.
    It probably concerned the demolition of partition walls and has nothing to do with electrics ;)
    Cracks even arise spontaneously. I know a block where a glass on a glass is stuck to the cage (such control points).
  • #20 16321502
    elpapiotr
    Help: 1015
    Rate: 3533
    We remember. Also about technological holes and furrows.
    We also know how these technologies were made back then.
    Here is an example - Link
    During the summer holidays in 1972, I myself worked in the production of reinforcement elements for large panels, so I can say something about it.
  • #21 16321507
    kkas12
    Help: 1076
    Rate: 4321
    I suggest paying special attention to the "technological holes and furrows" mentioned by Paweł. With an emphasis on "technological".
  • #22 16321540
    Łukasz-O
    Help: 654
    Rate: 4292
    Yes, but there were not grooves and technological holes everywhere. And the current wires do not fit into the large panel putty or 1 cm plaster.
    That is why I count on fellow specialists who will share practical tips with photo documentation.
  • #23 16321730
    belfegor1988
    Help: 13
    Rate: 38
    A colleague wrote 1cm thick plaster or putty - a dream. More often we hit concrete and 2mm layers of paint :) Good luck in laying the wires on something like this, half the trouble as the channel in the ceiling is not flooded with concrete.
    Greetings,
  • #24 16322322
    Tomeksup
    Help: 6
    Rate: 65
    Gentlemen
    Based on my present knowledge, I would not move this door now. The opening was 80cm wide and standard height. I needed 88 cm wide and 2.05 cm for a new door. In addition, the band was overlapping (from the door) on the walls. In one place it collided with the counter in the hall. The door light was supposed to be widened and little shifted. The bad luck was that after moving the hole (I think it was no more than 10cm) I found joining the slabs - concrete with brick (?, Softer material). Due to the fact that not much of it was left, the concrete piece fell off by itself.
    Now I would think about it before I hit that door. However, let's remember that in those days, record technology was based on mass production. Nobody had time to design and count. THEREFORE, I conclude that the project was overwhelmed. It can be compared to a single-family house. You buy the project and you bet. The cottage is so redesigned that it will stand in all conditions (almost). Hardly anyone makes an adaptation to save on concrete. In my opinion, it was similar in the block.
    As for the furrows in the walls. One friend advised me to lay cables parallel to the floor in the wall. I let go and put it on the floor. It turned out that I had to trim the can by 1.5 cm. The foremen in front of me did most of the work.
    Besides, from the floor I pulled a burnt, charred cable, 1 m long. Now I know why one socket did not have electricity.
  • #25 16322373
    kkas12
    Help: 1076
    Rate: 4321
    belfegor1988 wrote:
    Nobody had time to design and calculate.
    Nonsense.
    And as for the "stock", see the link indicated by Paweł.
    The crux of the matter is clarified there.
    Knots.
    You do not know where they are located and you will not know without a design or knowledge of the building structure.
    However, I know that the most damage to these nodes and the structure of the object is caused by mechanical forging, or rather the vibrations it causes.
    And the transverse grooves (parallel to the floor) are a significant weakening of the strength of the walls.
    Just like the groove in the ceiling across the Żerań slab (then most often).
  • #26 16322434
    Łukasz-O
    Help: 654
    Rate: 4292
    kkas12 wrote:
    Knots.
    It should only be added that the user doing the renovation has no access to these key nodes.
    It is impossible to disagree here, the question of how much a centimeter groove will weaken a 15 cm wide slab. There is no need to forge furrows in Żerań slabs because there are pots. You can also use dilatations
  • #27 16322481
    retrofood
    Help: 1140
    Rate: 4800
    As a long-term user of a large-panel premises, I believe that the issue of forging and demolishing plates should not arise in the case of electricians at all. Even a complete replacement of the installation, not only extension, is possible without great interference in the structure of the panels. I emphasize big ones, because sometimes some minor scratches are indispensable.
    Any cable connections to the overhead lighting are possible with the use of expansion joints or board joints, or in suspended ceilings, sometimes we only have to scrape something out for wall lamps. In general, it is better to run the cable not necessarily the shortest route, but add those two or three meters of cable and not play with forging!
    The same applies to the installation of sockets. Cable routing in the floor or under the skirting boards and short vertical sections to the sockets. I cannot imagine cutting reinforcing wires while drilling (cutting) the cans! I just moved the location of the socket (s) if there was a wire. And I did not forge anything, I cut the holes for the accessory boxes by drilling a series of holes ?6. After such a perforation of a fragment of the wall, the rest can be broken off with a stronger screwdriver or a scraper.
    On the other hand, where the situation is the most difficult, i.e. in the kitchen, there is usually no board, because the builders themselves would then have problems with the installations. In any case, however, it is possible to hide the wires behind the furniture, if the board is there, only small sections are scratched.
    Can be done without forging, really!
  • #28 16322579
    Łukasz-O
    Help: 654
    Rate: 4292
    And what does it mean to "scratch". It is rather difficult to scratch something in a concrete slab.
    However, I agree that vertical sections led from the floor are the best solution. Sometimes, when you find a plate with holes, you don't have to cut furrows.
    The worst place is not only the kitchen, I would also add switchboards where several or a dozen wires are connected.
  • #29 16322669
    adamkowalski431
    Help: 7
    Rate: 72
    Don't worry about drilling a hole saw in the plates, just check with the sensor where the rods are, and you run the wires in the plaster on the plate and oil the project, after all, this is not a new building
  • #30 16322693
    Tomeksup
    Help: 6
    Rate: 65
    Knots? Do you mean protruding reinforcement fi> 20mm resting on the floor / ceiling?
    I am just scratching holes in the wall without forging (for lighting). I'm not going to get tired of the drill. Easier and faster.
The discussion revolves around the renovation of an apartment, specifically the installation of a 60mm socket in a load-bearing wall. The main concerns include the legality of drilling into load-bearing structures, potential permits required, and the implications for structural integrity. Participants share experiences regarding the risks of cutting into reinforcement bars and the importance of using appropriate tools, such as diamond core drills. There is a consensus on the need for caution and professional oversight when altering load-bearing walls, as improper modifications can lead to significant structural issues. The conversation also touches on the historical context of construction practices and the necessity of adhering to safety regulations to avoid liability in case of accidents.
TL;DR: 13 % of home fires stem from ageing wiring [NFPA, 2022]; “Permits are not” required for adding a socket in Polish flats [Elektroda, kozi966, post #16318636] Replacing ancient 0.5 mm² floor cables with a surface-mounted 60 mm box, routed vertically, prevents structural damage and keeps insurers happy.
Why it matters: You can modernise wiring safely, legally, and keep insurance valid—if you follow a few strict rules.
• Deep socket box Ø60 mm × 60 mm is the Polish retrofit standard; shallow = 40 mm depth [Schneider Electric, 2023]. • Max chase depth in load-bearing concrete: 10 mm vertical, 0 mm horizontal (PN-EN 1996-1-1, §6.2). • Electrical acceptance paperwork: approx. PLN 500–3 000 [Elektroda, kozi966, post #16318636] • Stud scanners locate rebar up to 60 mm deep [Bosch Datasheet, 2023]. • Insurers may deny claims for uncertified wiring changes [Allianz Guide, 2022].
Do I need a building permit to drill a new 60 mm socket in a load-bearing wall?
No. Polish law treats small diameter holes for electrical boxes as minor works; only structural alterations require permits [Elektroda, kozi966, post #16318636]
Must an authorised electrician sign off the modified installation?
Yes. Polish Energy Law art. 62 demands periodic testing; after modification you need a measurement protocol and acceptance report signed by a SEP-certified electrician. Insurers ask for it after a claim [Allianz Guide, 2022].
How much does documentation and approval usually cost?
Local electricians quote between PLN 500 and PLN 3 000, depending on flat size and circuit count [Elektroda, kozi966, post #16318636]
Is a 60 mm deep box mandatory?
Use a 60 mm box only if you will fit extra connectors or smart modules. A 40 mm “shallow” box is enough for one simple socket [Elektroda, kokapetyl, post #16318762]
Can drilling weaken a 15 cm thick slab?
A single Ø60 mm, 50 mm deep hole removes <0.2 % of the wall’s cross-section—negligible if rebar is untouched [Knauf Calc, 2021]. Cutting horizontal chases, however, can reduce bearing capacity by up to 30 % [PN-EN 1996-1-1, Annex G].
What route should I choose for new cables in a large-panel flat?
Industry best practice: run cables in the floor screed or skirting, then drill short vertical rises to each socket. This avoids forbidden horizontal chases and keeps reinforcement intact [Elektroda, retrofood, post #16322481]
How do I avoid cutting rebar while drilling?
  1. Scan the wall with a metal detector rated 60 mm depth.
  2. Mark a spot at least 30 mm from detected bars.
  3. Drill with a diamond core at low hammer force. Failure to scan risks hitting 3–6 rebars per hole, slowing work dramatically [Elektroda, kokapetyl, post #16320777]
What cable size should replace the old 0.5 mm² conductors?
Use 3 × 2.5 mm² Cu for socket circuits on 16 A breakers, per PN-HD 60364-5-52. It carries 20 A safely and meets modern load demand [PSE, 2022].
Could my insurance refuse payout if wiring causes a fire?
Yes. Insurers routinely deny claims when no acceptance protocol exists or unlicensed work is proven [Allianz Guide, 2022]. "Indeed, the insurer may do nothing" confirms a forum expert [Elektroda, kozi966, post #16318636]
What is the safest 3-step method to drill the box?
  1. Mask area, scan for metal; mark centre.
  2. Use a 800 W drill with Ø68 mm diamond crown at <1 200 rpm.
  3. Stop 5 mm before full depth, pry core with chisel; vacuum dust. Total time: ≈2 minutes, as user Tomeksup noted [Elektroda, Tomeksup, post #16320688]
Are horizontal grooves ever allowed in load-bearing walls?
No. Polish and Eurocode rules forbid horizontal chases in load-bearing concrete; only shallow vertical chases up to 10 mm are acceptable [PN-EN 1996-1-1, §6.2].
What’s an edge-case of doing it wrong?
One renovation cut reinforcement and caused cracking in the flat above; the investor paid for neighbours’ repairs [Elektroda, elpapiotr, post #16321460]
Do I need a lintel for small openings like socket boxes?
A lintel is needed only when you remove material across the wall width, such as new doorways. Socket holes do not require lintels [Elektroda, retrofood, post #16324035]
Which drill type is fastest for concrete panels?
A light SDS-plus rotary hammer delivers up to 12 J impact energy and removes core in seconds [Hilti Spec, 2023]. Forum users prefer it over manual chiselling [Elektroda, retrofood, post #16323018]
What qualifications should the electrician hold?
Look for a SEP “E” licence for operation plus “D” for supervision, and ideally a construction licence in electrical specialisation per Polish Building Law [Ustawa Prawo Budowlane, 2020].
How often must the installation be retested after renovation?
For residential units the mandatory interval is 5 years, or immediately after any major alteration such as adding circuits [Energy Law Art. 62].
