Best External Antenna for Truck Drivers: Boost Wi-Fi Range with USB 3.0 & TP-Link TL-WN722N Modem
krzychsolt 6618 18
What external Wi‑Fi solution should I buy to improve my laptop’s range for connecting to public hotspots from a truck?
For the kind of range you want, a normal omnidirectional antenna will not get you anywhere near several kilometers; if you want the best chance of long range, you need a directional device and you must aim it carefully [#16325326][#16325320] A specific suggestion from the thread is the TP-Link TL-WA7210N or the Ubiquiti locoM2, both of which are meant for this kind of directional use [#16327673] If you just want better reception than the laptop’s built-in Wi‑Fi, a USB adapter like the TP-Link TL-WN822N or the newer Archer T4UH was recommended [#16325320] Keep in mind that hotspot links are local and can disappear if another truck blocks the path, so even a better antenna will not magically make the hotspot transmit farther [#16327806][#16328961] The thread also notes that Wi‑Fi antenna power cannot exceed 100 mW, so claims of huge ranges from cheap “2000 mW / 36 dBi” products should be treated skeptically [#16327806]
  • #1 16324960
    krzychsolt
    Hello, I am a truck driver and I travel internationally most of the time. Therefore, in order to increase the effectiveness of the Wi-Fi card in my laptop, I want to buy an external antenna to easily download the Wi-Fi signal from free hotspots in parking lots, ports or from nearby restaurants. The Allegro is full of some Chinese inventions with descriptions of 10km ranges, etc., in which I do not believe.
    What to buy to increase and improve the range in my laptop, I will add that I have USB 3.0 connectors in my laptop, if it was to be via a USB cable (if it is important) and possibly if it was to be the antenna for the modem itself, I have a modem that is not used by me tp link tl-wn722n (so in case of W)
    Budget, about PLN 150-250 to make it fun, it is known that sometimes 200 or 500 meters is enough, but if it could do it sometimes with 2 or 3 km, it would be great. So I thought that if I only needed to amplify the signal that I already download with the flap, the antenna would be plugged in, but it was lying in the cabin and if there was a greater need, the antenna would go to the cabin through the sunroof.
    I am waiting for specific hints on what to buy in my case.
    Best wishes :)
  • Recommends TP-Link adapters and directional antennas for range
    #2 16325320
    xxl245
    Help: 17
    Rate: 39
    Personally, I recommend TP-Link TL-WN822N, drivers often buy this model from me. They claim that the range is much better than that of the cards built into laptops.
    Alternatively, you can try a new model in the ac TP-Link Archer T4UH standard. I have not had contact with the new model yet, but it should be even better than in the previous model
    To obtain a range of several km, you would need to use a directional antenna, which unfortunately has a very small operating radius, which will probably preclude its use in such conditions.
  • Directional antenna and exterior mounting improve range
    #3 16325326
    JacekCz
    Help: 760
    Rate: 1464
    Omnidirectional no chance, it won't give you even a fraction of that range.
    A directional is a mill with aim, direction etc (and fully shows the claw when the other end is directional)
    Cheap advice: take the antenna out of the cabin plate, it will do a little, you don't know how much.
    by the way, beyond the Oder River, the state services are not so careless about violating radio regulations, various spells with extraordinary power, etc.
  • #4 16325339
    bogiebog
    Help: 2569
    Rate: 1530
    Panel antennas are directional "like binoculars" in order to catch something you have to look for it, once you point it, they give better effects / signal amplification.
    Omni-directional antennas (stick) work around but in a limited beam, like a fast rotating lighthouse, you collect everything around, you do not need to turn / search, e.g. 12dbi gain is 1m height of the antenna, shorter range than the panel.
    They are also parabolic / spherical, even more directional "like a telescope", it is even more difficult to find a signal, they give the greatest amplification.
  • #5 16325347
    JacekCz
    Help: 760
    Rate: 1464
    bogiebog wrote:
    Panel antennas are directional "like a telescope" to catch something you have to look for it, once you point it, they give better effects / signal amplification.
    Omni-directional antennas (stick) work around but in a limited beam, like a fast rotating lighthouse, you collect everything around, you do not need to turn / search, e.g. 12dbi gain is 1m height of the antenna.
    Add that many "panel" antennas on the market should be accused of fraud.
  • #6 16325353
    bogiebog
    Help: 2569
    Rate: 1530
    If they are made of old laminate flooring, it will be hard to find fault.
  • #7 16325890
    krzychsolt
    Ok, at the beginning, in order to avoid unnecessary polemics about regulations, etc., I will write that I do not go to kindergarten and that everything would be ok and for my and your conscience, we write here purely theoretically and only for educational purposes ;)
    Apart from the fact that what is in the descriptions and what in fact when it comes to parameters, powers are two different things.
    An example of my friend, he bought a directional antenna there for about PLN 100 from the Allegro and says that the improvement is mega, he just connects it often, but it is in the cabin and it's cool, and if he needs more then on the roof. A colleague is pleased with the improved coverage. And taking shortcuts, I could ask him what exactly he bought and that's it, but I prefer to ask you what is the best for my budget.
    So I would be interested in a panel with a relatively large viewing angle (if there are such parameters at all) of decent quality with quite a lot of power (if it exceeds the standards, see the beginning of the post ;) I know that then I will have to play and look for the right setting so that the result is satisfactory.
    Any specific suggestions?
  • #8 16326119
    kiko80
    Help: 67
    Rate: 163
    It would be best if you ask your friend what he has and you can choose something based on it. It's not an art to spend money on something that may not work for you.
  • #9 16326208
    bogiebog
    Help: 2569
    Rate: 1530
    2Ghz or dual band (2 and 5 GHz) should it be?
    I do not see CPE dual band devices too much, a single device is only 2.4Ghz, most hotspots on this band.
  • #10 16326577
    krzychsolt
    And I could ask about the advantages and disadvantages of such solutions, because I have little knowledge about it. By peasant reason in dual I will catch more hot spots, although there are more at 2.4, but what are the disadvantages if you do not see it in my case?
  • #11 16326663
    bogiebog
    Help: 2569
    Rate: 1530
    kiko80 wrote:
    It would be best if you ask your friend what he has and you can choose something based on that
    Find it out first
    For two 2/5 bands, two devices would be needed, separate for each band.
  • #12 16327629
    krzychsolt
    So yes, my friend has a pannel with Allegro, some wifi sky, with nonsense on the box 2000mW +36 dbi
    Żegocinie, what I was looking at now on the allegro is below 50, so I can't do madness
    Well, I talked a bit with my friend and he says it's not perfect but it does the job. Virtually all the time it does not leave it behind the cabin because it has not yet made any handle and places it on the windshield. He sets his eye once at a gas station and where his range was negligible or almost always full.
    And I would like something like that, but maybe a little better quality. I have already learned that it boils better, sometimes more expensive and desire.
    If two devices were to be in dual, it should be for the 2.4.
    ps fota
  • #13 16327673
    bogiebog
    Help: 2569
    Rate: 1530
    TL-WA7210N
    Ubiquiti locoM2
  • #14 16327789
    krzychsolt
    With a predominance of one of them, doesn't it matter?
  • #15 16327806
    KOCUREK1970
    Help: 3861
    Rate: 5489
    A colleague thinks that if he puts on a "bull" in his cabin, the wifi will "fly" 2 km away.
    With wifi, it will work in one place, not in another - these are hotspots, so the range is not great (only within a given facility), it is enough for another truck to stand in front of your truck and you do not have any wifi anymore.
    And please remember that the power radiated by the wifi antennas cannot exceed 100 mW.
  • #16 16328876
    krzychsolt
    It is true that I am quite green on this subject, although I know that for full happiness you also need a good transmitted signal, but it cannot be denied that compared to a standard antenna in a laptop the difference will be enormous.
    If I cover the truck, the antenna will go above the roof.
    I see that the antennas that were recommended to me need an external power supply, it's not a problem because I use converters anyway, but always additional cables. Thank you for all your help, unless someone else has something to add.
  • #17 16328961
    KOCUREK1970
    Help: 3861
    Rate: 5489
    But that won't make the signal from the wifi antenna transmitting stronger - it's still just a local hotspot.
    Also remember that the speeds on hotspots are not in the order of 200/500 Mb - when it is 10/20 Mb, it is good, but it's for all users. And you will count the number of users and instead of wifi you will have "blood from your nose" (no antenna for any money will change anything here).
    Unfortunately, this is how it looks real.
  • #18 17253965
    krzychsolt
    Hello after a long time. Due to the "abolition" of roaming, I abandoned the topic of buying an external Wi-Fi antenna. Unfortunately, the Fair Use Policy makes it less fun and again the problem with the Internet abroad.
    Anyway, as instructed, I bought a similar TpLink product, exactly the CPE210 model.
    Now I have a problem with how to configure this device to work as a wi-fi antenna.
    Can anyone help?
Truck drivers seeking to enhance Wi-Fi connectivity while on the road can consider various external antennas to improve the range of their TP-Link TL-WN722N modem. Recommendations include the TP-Link TL-WN822N and the TP-Link Archer T4UH, with directional antennas suggested for longer ranges, albeit with limitations in operational radius. Users emphasize the importance of signal quality and the limitations of omnidirectional antennas, which may not achieve the desired range. Panel antennas are noted for their directional capabilities, while concerns about the reliability of advertised ranges on cheaper models are raised. The discussion also touches on dual-band devices and the necessity of good signal sources for effective performance. A user later reports purchasing a TP-Link CPE210 and seeks configuration assistance.
