ESP Light On: Passat B5 FL 2001 2.0 Gasoline (Restart Issues, Solutions, & Control Burning)
Lulo44 5055 2
  • #1 16325715
    Lulo44
    While driving, the esp light comes on in my passat b5 fl 2001 2.0 gasoline, after turning off the car and trying again, the car does not start, it only starts after another attempt. I do not want to fire and this control is burning all the time.
  • #2 16325817
    Józef18
    Level 32  
    Help: 168
    Rate: 165
    First, computer diagnostics
  • #3 16326239
    Lulo44
    I know that it will not do without it But I thought that someone had already had a similar case, because there is a lot of it on the Internet about diesel and not about gasoline
    Added after 5 [hours] 53 [minutes]:
    If someone had such symptoms in the passat 2.0 gasoline, it turned out that it was the fault of the engine temperature sensor which is located at the back of the engine and you can see it after removing the pipe that goes from the air filter and the replacement takes 10 minutes
