VW passat B7 - Since the visit in the website, I have lighted ESP controls etc .
Rav5ooo 17976 4
  • Engine wash likely caused moisture-related electrical faults
    #1 16344374
    Rav5ooo
    Hello ,
    About two weeks ago I was at the VW service. After the review they cleaned my engine in the car, strange things with the car have happened since then. The next day, after the review, he did not fire. It was only when I warmed up that the webasto engine reacted. Under the service, he did not fire so they dragged him in and dried it all night. Now he fires and drives but the controls light up, not always, sometimes. The steering wheel lights up then directions, wipers, cruise control and no steering wheel controls and power steering do not work. The lamp indicator lights, from ESP and generally from errors. The meter displays information: ACC error, APP error, Start stop system error. On the main screen, the parking system is unavailable. I think that somewhere something is damp and that is why every now and then everything is happening. I do not have a garage to dry it myself. Maybe someone had such a problem? What to do in this case?
    Rafal VW passat B7 - Since the visit in the website, I have lighted ESP controls etc .
  • #2 16344405
    szymitsu21
    Help: 343
    Rate: 1300
    Normal drying is not enough if this is the problem
    You will need to unplug the plug and look in the middle
    In my opinion, you should try to ask the service for some help, in the end it looks like it's going wrong with washing the engine.
    and make diagnostics
  • #3 16344408
    leonov
    Help: 1039
    Rate: 2248
    Give back to the site, as they have corrupted, let them repair it now.
  • #4 16344668
    Rav5ooo
    Now, I will not give it because today in the morning there is no electricity, there is everywhere, and there is nothing on the meter that does not ignite only that there is an open door. on the second day after washing the engine it was. Later they dried it up and a few days it was ok. I do not know he will be heated up by webasto and then he will try.
  • #5 16344690
    leonov
    Help: 1039
    Rate: 2248
    You are flooded and it is specifically the installation, as they will start to corrode the connector joints then you will only have "crayons".
