ESP8266 AT Commands GET Request Returns 400 Bad Request on Local Apache PHP Server
JakubST 3057 2
  • #1 16325833
    JakubST
    I am using an ESP8266 module with the current ESP8266_NONOS_SDK_V2.0.0_16_08_10 firmware.
    I am making GET requests via AT commands to PHP+MySQL servers.
    Web servers - ESP8266 works fine .
    Here everything works ok.
    Whether I call the url in the browser: http://zzzzzzz.zzzzzzzzz.zz/dodaj_rek.php?n=129&u=1488723073&d=-51&s=203
    or with AT commands in the ESP8266 module:
    Code: Bash
    the server responds correctly:
    Code: Bash
    and the data lands in a database on a server somewhere in Poland.
    Server on local network - ESP8266 problem .
    I have installed Apache + MySQL + PHP server on a computer with IP address 192.168.1.51 listening on port 80.
    Typing the address 192.168.1.51 correctly runs the index.php script.
    Calling the url in your browser:
    http://192.168.1.51/dodaj_rek.php?n=129&u=1488723073&d=-51&s=203
    or
    correctly runs php script and adds record to database.
    The server is seen by other computers, tablets or smartphones on the network by which the use of in a browser the above url correctly works regardless of whether the device is connected via LAN or WiFi.
    The problem occurs when I want to do the same thing using the ESP8266 pointing to the IP address of a server on the local network:
    Code: Bash
    CIPSTART responds, correctly connecting to the server
    CIPSSEND also responds correctly with a prompt > and the ESP8266 waits for a GET to be sent.
    After the GET is sent, it correctly reports that the correct number (81) of bytes have been received:
    Code: Bash
    but generates a 400 Bad Request error:
    Code: Bash
    I attach the Apache and PHP configuration files.
    I've spent hours on this, searched the web for information, but found nothing that solves the problem or at least gives the cause.
    I even tried specifying the port number in GET additionally by sending 84 characters:
    Code: Bash
    but the effect is the same - connection ok, confirmation of receiving the correct number of GET bytes also ok, but unfortunately again error 400 Bad Request.
    • conf.zip (28.28 KB) You must be logged in to download this attachment.
  • #2 16328463
    dondu
    Help: 1292
    Rate: 809
    The GET should look as follows:
    Code: Bash
  • #3 16330409
    krzbor
    Help: 42
    Rate: 1072
    Try inserting "/add_rek.php" instead of "add_rek.php" i.e. add a slash:
    GET /dodaj_rek.php ....
    If this doesn't help, change the HTTP from 1.1 to 1.0
