Concrete Nail Gun for Metal Sheets: Ceiling Attachment, Best Models & Brands
elektryk83 8895 11
Can a concrete nail gun be used to attach metal sheets to a ceiling or similar concrete surfaces?
Yes, concrete nail guns are used for fixing items to concrete ceilings and similar surfaces, especially if you do this kind of work often on concrete ceilings or Silka walls [#16338394] They are also used for attaching fire-protection cables [#16338371] As model suggestions, one reply recommends the Hilti DX2 powder-actuated nailer or the Hilti BX3 mechanical nailer because of their system and availability [#16338450] Another recommends choosing the nailer type and brand first, then matching the magazine/fasteners to it, with Rawlplug SC40 mentioned as an example [#16338464] If you are unsure, it may be worth renting one for a job and testing whether it suits your needs [#16338497]
  • #1 16338313
    elektryk83
    Help: 8
    Rate: 38
    Hello, I have a small question. Does anyone use a concrete nail gun to nail the metal sheets to the ceiling or similar things?
  • #2 16338330
    kokapetyl
    Help: 1787
    Rate: 2102
    Yes he uses / used.
  • #3 16338354
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3532
    It used to be used, but it's the 70's and the "gun" Grom. :D
  • #4 16338371
    qadam12
    Help: 62
    Rate: 254
    Yes . Now also for attaching fire protection cables.
  • #5 16338372
    elektryk83
    Help: 8
    Rate: 38
    Hello, is it a useful tool worth buying or donating this tool?
  • #6 16338394
    qadam12
    Help: 62
    Rate: 254
    If you do a lot on concrete ceilings or in "silka" then yes. I often use photo pins.
  • #7 16338426
    elektryk83
    Help: 8
    Rate: 38
    Thanks with the reply. You can, buddy, write what the symbol of these nails are and if they fit all models of the nailers. best regards
  • #8 16338450
    pol102
    Help: 163
    Rate: 369
    I suggest the powder DX2 or the mechanical BX3 from Hilti. It is not even a matter of advertising, but systematicity and availability.
    qadam12
    Help: 62
    Rate: 254
    Choose a nailer / type, brand / and then look for a magazine for it.
    type RAWL SC40
  • #10 16338480
    elektryk83
    Help: 8
    Rate: 38
    I was just thinking about the Rawlplug sc40. Do you have such a fastener, my friend qadam12, and how does it work? best regards
    qadam12
    Help: 62
    Rate: 254
    I don't, but the company does. Nobody's complaining. Rentals also have, you can rent for a job and try if it fits.
  • #12 16338500
    elektryk83
    Help: 8
    Rate: 38
    Thank you for your answer and I close the topic.
The discussion revolves around the use of concrete nail guns for attaching metal sheets to ceilings. Participants confirm that such tools can be effective, especially for tasks involving concrete ceilings or specific materials like "silka." Recommendations include the Hilti powder DX2 and mechanical BX3 models, noted for their systematic availability. Users also mention the Rawlplug SC40 as a viable option, with suggestions to rent tools for trial purposes before purchase. The conversation emphasizes the importance of selecting the right type of nailer and corresponding fasteners for optimal performance.
