[Solved] I am looking for a quiet pressure booster pump - a replacement for Grudziądz
jalop 10740 9
What quieter replacement pump can I use for a noisy Grudziądz SKA 4.02 booster in a 22 m well with a 5/4" pipe, and will a self-priming pump still draw water in this setup?
For this setup, the thread does not identify a clearly better quiet self-priming replacement, and one reply says you will not find anything better than the SK; instead, soundproof it with OSB and glued mineral wool [#16340764] A quieter alternative would be a submersible pump in the well, but the thread notes that your 5/4" pipe leaves no room to lower a pump into it [#16341390][#16341414][#16341810] If you can build a pit in the boiler room, that should reduce noise, and one user later reported solving the problem with a 2.5 kW multistage monoblock pump [#16340980][#17015469]
  • #1 16340168
    jalop
    Help: 40
    Rate: 204
    I have a pressure booster pump Ska 4.02 installed in the house + 300l galvanized tank. The whole is mounted in the boiler room, but above it I have a kitchen and a bedroom behind the wall. Hydrofor generates very high noise, despite the installation of plastic and the installation of damping rubber. There is nothing to hide, the pump from Grudziądz is very loud. I am looking for a replacement, provided that it must be a self-priming pump, because at the very end of the well the check valve in the basket does not hold a water column, hence the valve is installed in front of the pump and in front of the tank. Access to damaged valve not possible. 5/4 '' pipe without cover at a depth of 22 meters. Access to this well is difficult because it is located in the gazebo.
    I found several, self-priming pumps:
    1. Grundfos JP-5 or JP-6.
    2. Wilo Jet pump wj 202
    3. OMNIGENA MH 2500 / 230V INOX pump
    My question, if any of these pumps, after previous flooding will be able to suck water in my case? Let me remind you that ska 4.02 has no problem.
    There is one more way out. I thought that in the boiler room, where the pump stands, dig a well and let it in, and then cover with a wool cover and ventilate outside the building. Only, will the vibration not transfer to the foundations? And will this silence do anything at all?
  • #2 16340764
    jerry1960
    Level 37  
    Help: 284
    Rate: 1556
    You won't find better than SK. If you care about soundproofing, encase it with e.g. OSB with glued mineral wool.
  • #3 16340963
    jalop
    Help: 40
    Rate: 204
    And what do you think to dig a well in the boiler room and put a pump there? It would be at a distance of about 40 cm from the foundations.
  • #4 16340980
    stanislaw1954
    Help: 2013
    Rate: 4663
    If the conditions allow it, you would definitely get some peace and quiet.
  • #5 16341390
    wiesiekmisiek
    Help: 259
    Rate: 524
    Throw this pump, let the submersible pump into the well, supply it with a pressure switch located on the hydrophore tank and I say that standing even at this tank you will hear only the sound of water and the silence will be complete above the ceiling.
  • #6 16341414
    stanislaw1954
    Help: 2013
    Rate: 4663
    Only the pump that could fit into a 5/4 "pipe has not been invented yet
  • #7 16341467
    wiesiekmisiek
    Help: 259
    Rate: 524
    Reading the post I understood that the 5/4 inch pipe is on the supply of the hydrophore and not the diameter of the well.
  • #8 16341486
    stanislaw1954
    Help: 2013
    Rate: 4663
  • #9 16341810
    jalop
    Help: 40
    Rate: 204
    5/4 '' comes out of the ground and that's how the pump is powered. Hence, I have no way to put anything into this pipe, only what I can connect a self-priming pump. I don't even know if there was a check valve there originally - a well made in 1987, I have a bill somewhere for 16 thousand then.
    Do you know any quiet pump that will meet my expectations?
    As quiet, I mean one that works quieter than Grudziądz.
  • #10 17015469
    jalop
    Help: 40
    Rate: 204
    I solved the problem in the summer by installing a 2.5kW multi-stage, monoblock pump. It works great.
✨ The discussion revolves around finding a quieter replacement for a Grudziądz pressure booster pump (Ska 4.02) installed in a residential setting, which generates excessive noise. The user seeks a self-priming pump due to installation constraints, including a 5/4" pipe connected to a 300l galvanized tank. Several potential replacements are considered, including Grundfos JP-5, JP-6, Wilo Jet pump wj 202, and OMNIGENA MH 2500/230V INOX. Suggestions include relocating the pump to a well or using a submersible pump to minimize noise. The user emphasizes the need for a pump that operates quieter than the current model.
