The circulating pump runs loudly (clicks) in Termet minimax plus
robe2710 9900 3
  • Axial rotor play and loose plate in pump housing
    #1 16751543
    robe2710
    Rate: 73
    After switching on every boiler Termet minimax plus, I heard that the water pump is working too loudly (clicking noise). After unscrewing the housing wilo rst 15 / 6.7-1, I checked that the rotor has a slight sideways play, but greater play occurs axially. In addition, in one part of the pump casing, which I have not removed from the furnace, there is such a loose plate having a round shape. I will add that after turning the pump and turning on the pump worked quietly until the boiler reached the correct pressure. I am still thinking about descaling the exchangers, maybe it has an impact.
    Please help. Greetings!
  • #2 16751768
    D214d3k
    Help: 543
    Rate: 633
    There should be a filter before the pump. You need to close 2 valves and clean it.
  • #3 16752418
    robe2710
    Rate: 73
    I already closed 2 valves, drained the boiler and cleaned the filter between the distributor and the pump. But it didn't help. The stove heats the central heating water, but you can still hear the clicking noise in the pump.
  • #4 16759670
    robe2710
    Rate: 73
    I am closing the topic, problem solved.
