How to disassemble the Zelmer voyager twix 2000 vacuum cleaner
Woszczyń 12471 3
  • #1 16356124
    Woszczyń
    Rate: 20
    Gentlemen, I cut all my hair and I still can't, because I can undress. The vacuum cleaner pulls poorly, so the turbine is probably dirty. Unfortunately I can't get inside.
    • How to disassemble the Zelmer voyager twix 2000 vacuum cleaner f0.jpg (72.59 KB) You must be logged in to download this attachment.
  • #3 19926785
    emit1962
    Rate: 37
    This is a description of the Jupiter and it is quite different from the Voyager
  • #4 19926803
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2658
    In the back there are security on the bolts of the cover. You take it off, you take out the pins. Then it is only from the top, bottom and center of the screw bag compartment.
