Peugeot 207 1.6VTI 5FS thermostat - Low engine temperature thermostat
nikkos 10290 6
  • Low engine temperature persists after thermostat replacement
    #1 16357611
    nikkos
    Rate: 117
    Hello everyone,
    I have a problem with the peugeot 207 1.6vti 5fs 120km 150,000 mileage.
    In sequence:
    Problem: The engine temperature rises and decreases after driving about 20 km, it reaches the value of 90C and it stays like that at higher revs sometimes it drops. Burning unchanged.
    Replaced phase thermostat with sensor.
    Now:
    Engine does not heat up engine temperature is still 60 degrees. Burning unchanged.
    The temperature read by the diagnostic device fluctuates between 58-65C. Phase thermostat control 0% pump actuator is still on (pump is running).
    Everything points to the still open thermostat. (Of course the whole system is vented etc.) But would really 2 be defective? The cost of the next one is again PLN 420
    Has anyone ever encountered such a problem?
  • #2 16357651
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    How warm the cooler is, the thermostat lets go.
  • #3 16358772
    nikkos
    Rate: 117
    That's it and I know the question, but why?
    Two broken thermostats that behave the same?
    It is a phase thermostat, it can have problems with its control only what and on what basis it controls it
  • #4 18080026
    Colinn2111
    I am curious if the problem has been solved. I have a similar problem in the mini, the engine after renovation with a new thermostat (probably phase) does not keep the temperature, on average 70 degrees.
  • #5 20556837
    polo1995
    Hello, I'm wondering if anyone can answer, did you manage to solve the problem?
  • #6 20570369
    zi.ko
    Help: 86
    Rate: 336
    The small fluid circuit, most commonly in the heater, may be clogged. In this case, the pressure of the coolant produced by the water pump overcomes the resistance of the spring in the thermostat and forces the coolant into the large circuit.
  • #7 20570983
    Help: 1405
    Rate: 6430
    What exact engine code?
The discussion revolves around a Peugeot 207 1.6VTI 5FS experiencing inconsistent engine temperatures, where the engine fails to reach optimal operating temperature, remaining around 60 degrees Celsius despite replacing the phase thermostat. Users speculate on potential causes, including the possibility of a second faulty thermostat, issues with the thermostat's control mechanism, and potential blockages in the coolant circuit affecting temperature regulation. One user also shares a similar experience with a Mini, indicating a broader issue with thermostatic control in similar engines.
