Best Double-Sided Tape for Wall: Secure Power Strips & Organizers (30x30mm, Inline)
szymon1051 32721 16
What proven double-sided tape or mounting tape can securely hold a power strip and small wall organizers, and still be practical to remove from the wall?
Use a high-bond mounting tape, preferably 3M or Tesa UHB/VHB, or Pattex FIX 120 kg, and degrease the surfaces well before sticking it on [#16359512][#16360599][#16361216] Ordinary double-sided tapes are described as suitable mainly for very light, low-profile objects; anything that creates leverage can eventually fall off [#16360871] One reply recommends checking the technical data for UHB/VHB tapes in a specialist store so you can choose by adhesion rating instead of by reviews [#16361216] Be aware that on wallpaper or paint these tapes can remove the finish when peeled off, while tiles or glass are much safer [#16361188]
  • #1 16359496
    szymon1051
    Help: 5
    Rate: 67
    I am looking for a proven double-sided tape that can handle something there. For now, it is a power strip. I do not want to test myself because it is difficult to remove such tape from the wall.
    I know that such tapes hold well, because I have a similar organizer: https://www.morele.net/organizer-inline-samop...a-kable-30x30mm-czarne-10-sztuk-59965i-872088 /
    I have a cable tie attached to it, which in turn goes to the strip and for a moment the strip hung only on this cable and it managed :) . For now, I have several such stuck organizers and a strip on bands to them. Once, it does not look like it, two, the bands interfere with connecting the cables :) that's why the tape would be a better solution.
    sosarek
    Help: 9321
    Rate: 15543
    Tesa, 3M - roll cost approx. PLN 50, before gluing, degrease surfaces well.
    Z
    Pka, Poznań, 60-850
  • #3 16360599
    RADU23
    Help: 2428
    Rate: 1732
    Mounting tape FIX 120 kg - Pattex
  • #4 16360796
  • #5 16360871
    thor_
    Rate: 13
    From experience, all these tapes are suitable only for holding very light and to the least "protruding" objects from the wall. I tested various tapes from no-names after 3M and Tese and other and the only heavier things that managed to match mirrors. Any objects generating any "lever" and no load "on the wall" sooner or later landed on the floor.
  • #6 16361140
    szymon1051
    Help: 5
    Rate: 67
    I do not know what the organizers are in this case, because when I tried to force the metal "wichajstrem" from https://botland.com.pl/lutowanie/631-zestaw-do-serwisu-plytek-drukowanych.html to się " wichajster "began to bend and the organizer was in place :) , I have made three attempts :) .
    101pawel wrote:
    here you have a choice and you can compare:
    http://tinyurl.com/l36tqn3
    In every shop you have opinions only the most often are people who do not know anything about the topic and there is no point system under the word to know if others agree with the statement. The moderator of such statements is also often lacking.
    By the way, what is the good tape removed from the wall? A wide knife as for stickers?
  • #7 16361188
    RADU23
    Help: 2428
    Rate: 1732
    If you're asking about Tesa or Pattex, unfortunately it is removed along with the wallpaper or paint, depending on what you put on the wall. Only tiles / glass, etc. can be removed without household losses.
  • #8 16361216
  • #9 16366470
    szymon1051
    Help: 5
    Rate: 67
    101pawel wrote:
    szymon1051 wrote:
    In every shop you have opinions only the most often are people who do not know anything about the topic and there is no point system under the word to know if others agree with the statement. Moderator of such statements is also often missing.
    I gave you a link to the store, not to read reviews there, but to look into the technical documentation of these tapes. In addition, you have the option of comparing their parameters. It is a specialist store and at the same time a mine of knowledge about self-adhesive tapes. not enough, you can set a filter so that you do not read descriptions for hours after the other, and choose a group of tapes that are potentially meeting your needs. If you set "Ultra-High Bond Tapes (UHB / VHB)", you have the choice of the adhesion criterion right away. In 15 minutes you will find a product on which you hang not only the organizer, but the kicking pig, with the capacity guaranteed by the manufacturer. 5 years ago, I glued pine boards to the tiles in the garage - 20 mm high side. there are cans of paint on shelves and everything that is stored in the garage. I even forgot that they are glued on a double-sided tape.
    I tried to find eg FIX 120 kg - Pattex or tesa ultra strong and I could not.
  • #10 16369922
    qr
    Rate: 28
    maybe it's a matter of price, see in castorama
  • Reusable adhesive for removable ceiling-mounted AP
    #11 17174168
    alvaro99
    Help: 34
    Rate: 47
    Hello, I will join the topic because I do not want to start a new one.
    I need something to glue light plastic to the ceiling, namely it is such a UniFi access point. It may be a tape or an elastic glue, so that it can be broken off if it is not disturbed by the painting. Alternatively, you can take off the AP sometimes and then attach it again (so that the tape does not lose after 1 detachment of its properties).
    There used to be such elastic adhesives, added to computer newspapers, or cosmetics samples.
  • #12 17174202
    keseszel
    Help: 54
    Rate: 558
    I was gluing different things to the wall. Most fell off, despite a well-defatted surface. The patent with a double sided tape and additionally silicone proved to be the best. In the past, the tiles were sticky with osakryl. Maybe it's worth going back to old methods.
  • #13 17174433
  • #14 17174473
    alvaro99
    Help: 34
    Rate: 47
    I guess it's just a command ... but honestly I do not know if it will pass the exam because the two pictures have already fallen off ... In addition, there will also be a gap between the plastic and the wall, because the commands are quite thick.
  • #15 17811935
    hhreth71
    Rate: 8
    @ alvaro99
    If the gluing force does not have to be maximum, but the tape is to be easily removable, I recommend Tesa Indoor, banal removal, just pull one end and the whole goes down
    If there is no access, you can turn the device in accordance with the clock directions or use a dental thread (then you can easily remove the residue as described above)
    The manufacturer claims that it is indelible, but it is not true
  • #16 19108415
    Wujass84
    The power strip can be attached to the mounting mushroom tape, something like Velcro. The durability is enormous, and you can detach such a strip and attach it again if necessary. The glue is strong, but you can pull it off non-invasively, there is a lot to grab for, as opposed to using only double-sided tape. I have it at home and there is a git.
  • Mount power strip with mushroom tape
    #17 19158001
    alvaro99
    Help: 34
    Rate: 47
    Wujass84 wrote:
    The power strip can be attached to the mounting mushroom tape, something like Velcro. The durability is enormous, and you can detach such a strip and attach it again if necessary. The glue is strong, but you can pull it off non-invasively, there is a lot to catch, as opposed to using only double-sided tape. I have it at home and it is git.
    It is better than those market "commandos", because my mother-in-law recommended them to me, but everything is fine with them .... Maybe it's her charm that works for them ;)
The discussion centers around finding a reliable double-sided tape suitable for securing power strips and organizers on walls. Users recommend various brands and types of tape, including Tesa and 3M, noting the importance of surface preparation for optimal adhesion. Pattex's FIX 120 kg tape is mentioned for its strength. Some users express concerns about the removability of these tapes, indicating that they can damage wall surfaces like paint or wallpaper upon removal. Alternatives such as Velcro and mounting mushroom tape are suggested for their strong yet removable properties. The conversation highlights the need for a balance between adhesion strength and ease of removal, especially for heavier objects.
