Choosing the Right Antenna for ODU IDU 200 Plus Set in Forest Areas: Rozgarty, 53.049272, 18.499112
Boszal 2358 8
  • #1 18578408
    Boszal
    I have a set of odu idu 200, I live in a clearing - around a tree, could I ask for help in choosing an antenna for this set or help in determining in what network in my location, with which modem and antenna would be a good transfer?
    Rozgarty, ul. Mushroom Latitude: 53.049272 | Longitude: 18.499112
  • #2 18578953
    matek451
    Help: 4352
    Rate: 5808
    And what are your problems with Plus on this chassis, show LTE status after logging in to IDU, you are probably using LTE1800 on Plus BTS in Przysiek on the church. What is your DL / UL in the evenings?
  • #3 18580986
    Boszal
    I'll check tonight and let you know
  • #4 18584802
    Boszal
    Status two lines out of five, LTE 1800, DL / UL around 0.5 / 0.5, I tried the ground antenna but it fails, everywhere around the tree
  • #5 18585147
    matek451
    Help: 4352
    Rate: 5808
    I didn't ask about the lines, only about the screen with LTE status on IDU and what is the antenna, reachable? And such speeds look like a 0.5Mb / s funnel under FUP, always show a screen from the speed test.
  • #6 18585350
    Boszal
    Panel antenna Cybertech LTE C.
    trl 15
  • #7 18585452
    matek451
    Help: 4352
    Rate: 5808
    On LTE1800 signal very weak so tragic speeds but is the norm for Plus in most locations, the same at night? To check which BTS you are using, if you have a Plus card in your phone, check the signal parameters outside using https://play.google.com/store/apps/details?id=cz.mroczis.netmonster and show screen and speedtest.
  • #8 18590039
    Boszal
  • #9 18590088
    matek451
    Help: 4352
    Rate: 5808
    The phone logs on to BTS-Górsk on LTE900 range, very weak signal, LTE1800 also works on it. In general, in this location you won't do much on this equipment anyway, if you own it, you would have to install the 1800MHz antenna yourself and connect instead of the trash that is in the ODU https://www.cybertech.com.pl/ p185, dual-antenna-lte-4g-15dbi-to-odu-200-odu-100.html, 1m cables and two connectors with ufl included to connect the antenna, interference in ODU required. But if the LTE1800 band on the surrounding Plus BTS is clogged, this is a doubtful investment.
The discussion revolves around selecting an appropriate antenna for the ODU IDU 200 Plus set in a forested area near Rozgarty, where the user experiences poor LTE connectivity. The user reports a weak LTE1800 signal with download/upload speeds around 0.5 Mbps. Recommendations include using a Cybertech LTE panel antenna to improve signal strength, as the existing setup is inadequate. Users suggest checking the signal parameters using a mobile app and consider the possibility of interference affecting performance. The conversation highlights the challenges of achieving reliable connectivity in areas with obstructive foliage and the need for better antenna solutions.
