dell inspiron 15 5567 - Start only when I push power for a longer time
procsa 1905 5
  • #1 16381956
    procsa
    Help: 173
    Rate: 364
    Hello, problem as in the subject, dell inspiron 15 5567 with i5 7-generation, rozbierałem to clean, detached batteries and battery from bios, from this moment the laptop does not respond to the power button, means reacts go it turn on but only holding pressed power pair second, the same with switching off, I searched the bios and I do not see any option from the type of operation of the power button.
    And one more thing, all the time you hear how the disk works, even after firing only the bios, constantly sighs as "moves", the first I meet with something like that ...
  • #2 16381993
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    Check again if everything is well connected.
    Measure, you can do disc diagnostics?
  • #3 16382004
    procsa
    Help: 173
    Rate: 364
    Plate diagnostics, software from della? Do you measure voltages yourself?
    I checked the connections twice, unless some ribbon was damaged, I'm sure it's a problem with setups, and here the possibility of damage?
  • #4 16382080
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    procsa wrote:
    Do you
    procsa wrote:
    voltages yourself?
    Measurement.
    procsa wrote:
    checked the connections twice, unless some ribbon was damaged, I'm sure it is a problem with settings, and here the possibility of damage?
    If you ruled out errors in the assembly, RAM, processor properly mounted, you have damaged something.
  • #5 16382193
    procsa
    Help: 173
    Rate: 364
    And if such a brand new delle can have such a security system, that if something is wrong with the hard disk, then normally it will not fire? Because I connected a different drive and normally started, just press the power button, and do not stay long, is it possible?
    I am currently researching a laptop drive.
  • #6 16382349
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    procsa wrote:
    I
    procsa wrote:
    currently
    procsa wrote:
    a laptop drive.
    A damaged disk can cause various anomalies in the operation of the equipment.
    Have you had problems before with the disc?
    Upload the test results.
