Beater Mill Pulley Diameter: Hammer Mill with 17mm Belts, 24cm Engine & 10cm Grinding Mill
AudiS6C4V8 10098 6
  • #1 16386653
    AudiS6C4V8
    Will anyone tell me what the diameter of the pulley should be on the hammer mill
    On the engine I have 17mm belts with a pulley diameter of 24cm on a grinding mill I put on 17mm belts with a diameter of 10cm
    I think the speed on the grinding mill is too high for my ear because it almost fell apart
    Please reply to meila auto001(_at_)o2.pl
  • #3 16388973
    AudiS6C4V8
    there is no sign, but the father-in-law says it is 7kw
  • #5 16390092
    jurtur
    Help: 26
    Rate: 81
    Such "Bąk" type grinders had motors mounted in a "rigid" vertical position. So the turnover was 1400 / min.
  • #6 16390120
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1132
    Rather not, the rotation in such a grinding mill (Bąk type) was about 3 x 1400 rpm. They were driven mostly by 5.5 KW motors and the motor had a pulley about three times as large as the pulley on the axis of the grinding rotor. The wheel had three V-belts, it looked something like this:
  • #7 16898749
    AudiS6C4V8
    I bought it ready
The discussion revolves around determining the appropriate pulley diameter for a hammer mill, specifically one equipped with 17mm belts, a 24cm engine pulley, and a 10cm grinding mill pulley. Concerns were raised about the high speed of the grinding mill, which may lead to operational issues. Participants noted that the engine's power is likely around 7kW, and the typical rotation speed for similar machines is approximately 1400 RPM. It was suggested that the grinding mill's pulley should be larger than the engine's to reduce speed, with references to the "Bąk" type grinders and their configurations.
