ASUS A555L/X555LJ - RAM Upgrade: Available Slots, 4GB RAM Compatibility & Purchase Guide
Yeazay 6660 9
How can I check whether an ASUS A555L/X555LJ has a free RAM slot, and what exact 4 GB RAM module should I buy for it?
The only reliable way to confirm a free RAM slot is to open the bottom cover and check physically; CPU-Z’s SPD tab can show both slots empty even when that is not true [#16389784] [#16389809] One user also reported that an identical laptop does have a free RAM slot [#16389836] If you are worried about warranty, check the ASUS warranty card first, because there was concern that removing screws or the flap could void it [#16389829] [#16389833] The thread does not name the exact RAM module to buy; it points to the linked earlier topic for those details [#16389849]
  • #1 16389768
    Yeazay
    Hello, I am going to buy the ASUS A555L / X555LJ RAM laptop, I hope for some 4GB, I would like to first find out if I have a free slot in this laptop, and what RAM exactly to buy.
  • #3 16389796
    Yeazay
    If I remove the flap, I will void my warranty. :D
  • #5 16389809
    Yeazay
    If everything is buttoned up and the memory is purchased, then I will open the flap. Also the problem is that when I check the SPD tab in the CPU-Z program, both slots are empty, even if I run it in administrator mode ..
  • #6 16389825
    sosarek
    Help: 9320
    Rate: 15532
    Do you have seals on the caps underneath? What exactly does the warranty say about this?
    Z
    Pka, Poznań, 60-850
  • #7 16389829
    Yeazay
    I have it, I don't know exactly, but I was aware when I bought it that unscrewing any screw would void the warranty.
  • #8 16389833
    sosarek
    Help: 9320
    Rate: 15532
    By whom - the seller in the store? Read Asus warranty card.
    Z
    Pka, Poznań, 60-850
  • #9 16389836
    Yeazay
    Okay, no matter what, I asked my friend who has an identical laptop and he has a free RAM slot, also this problem is solved, now what exactly RAM model I need to buy, and I do not know when I have empty both slots in the SPD tab. .
  • #10 16389849
    sosarek
    Help: 9320
    Rate: 15532
    Read the topic I linked at the very beginning - you have everything explained there.
    Z
    Pka, Poznań, 60-850
The discussion revolves around upgrading the RAM in the ASUS A555L/X555LJ laptop. The user inquires about the availability of free RAM slots and the compatibility of 4GB RAM modules. Responses indicate concerns about warranty voiding when accessing the RAM slots, with suggestions to check for seals and warranty terms. The user confirms that a friend with the same model has a free slot, but is uncertain about the specific RAM model to purchase, especially since both slots appear empty in the CPU-Z SPD tab. Participants recommend referring to linked resources for detailed guidance on compatible RAM specifications.
