Fiat Freemont 2.0 Multijet AWD 62ET Transmission: Persistent Emergency Mode Despite Repairs
damianos98110 32193 6
  • Persistent P0732/P0735 ratio faults after transmission rebuild
    #1 16396967
    damianos98110
    Rate: 16
    Hello, I have a problem with the transmission in the Fiat Freemont 2.0 Multijet with AWD drive, the transmission is 62ET. The car caught the emergency mode the day after a long route. The multiecuscan program showed errors:
    P1790 - Fault Immediately after shift
    P0735 - Check gear ratio V gear
    P0792 - Excessive change in output speed
    P0732 - Check gear ratio II
    An attempt was made to regenerate the chest. When dismantling the box, worn OD / UD friction discs were found. The ordered repair kit for the box (set of friction plates, set of O-rings, set of seals outside the set of repair of solenoids). After assembling the crate, mounting in the car, pouring oil (ATF 4+), the errors were cleared. After starting the car and trying on the lift, the car threw back the same mistakes. As I have a second box for this, I have replaced the solenoid valve assembly, but it did nothing.
    I would like to ask more experienced colleagues for some advice where I could still look for problems, because this was my first adventure with the automatic transmission and I just lack ideas.
    Below are screenshots from the multi-task scan and a photo of damaged discs with spacers:
    Fiat Freemont 2.0 Multijet AWD 62ET Transmission: Persistent Emergency Mode Despite Repairs Fiat Freemont 2.0 Multijet AWD 62ET Transmission: Persistent Emergency Mode Despite Repairs Fiat Freemont 2.0 Multijet AWD 62ET Transmission: Persistent Emergency Mode Despite Repairs
    Thank you in advance for any advice, best regards Damian.
  • #2 16399116
    romuald-f
    A/T specialist
    Help: 407
    Rate: 1551
    Have you replaced the output speed sensor (error P0792)?
  • #3 16400908
    damianos98110
    Rate: 16
    Yes, the sensors were swapped, nothing changed
  • #4 19545080
    lukas198436
    Rate: 12
    Hello, And you dealt with this problem because I have the same and I don't know what to do anymore
  • #5 20197867
    Bogdan007
    Rate: 159
    I raise the topic
  • #6 20870378
    zibiblok
    How are you guys? Have you figured out the issue with these errors? Because I have the same problem... Regards
  • #7 20927439
    dczarnota1kel
    Have you replaced/checked the gearbox block and solenoid valve? We also had other errors, including 0868, after replacement the problem disappeared.
The discussion revolves around a persistent emergency mode issue in a Fiat Freemont 2.0 Multijet AWD with a 62ET transmission. The user reports multiple error codes, including P1790, P0735, P0792, and P0732, indicating problems with gear ratios and output speed. Despite replacing worn friction discs and solenoid valve assembly, the errors reoccurred. Other participants inquire about the status of the issue and suggest checking the output speed sensor and gearbox block, as similar problems were resolved by addressing these components.
