VW Passat B7 - Wheel Pressure Monitoring System: Disabling & Replacing Broken Sensor
mateuszwys 16500 4
  • #1 16398820
    mateuszwys
    Rate: 12
    Hello colleagues,
    I have a problem with the wheel pressure control system - broken sensor. I would like to know if anyone knows how to disable ??
  • #2 16399154
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1424
    You can turn off using vag or vcds. I can not do it in the audi because I did. Vintage in the same way.
  • #3 16399393
    mateuszwys
    Rate: 12
    I know so much, buddy, I have a specific hint on how to do it.
  • #4 16405771
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1424
    How did you feel these sensors ??? Go to block 17 meters and read block 61.
  • #5 16461244
    mateuszwys
    Rate: 12
    Thank you for your help. topic covered, system off.
