[Solved] Intermittent Internet Connection on ASUS UX410UA Laptop Despite Stable WiFi
kluivert_9 10476 20
Why does my ASUS UX410UA on Windows 10 intermittently lose internet access over Wi‑Fi even though the Wi‑Fi signal is stable, and how can I fix it?
The issue was ultimately fixed by installing a Windows update [#19093638] Before that, the strongest diagnosis pointed to Wi‑Fi interference rather than the ISP: an InSSIDer scan showed crowded 2.4 GHz channels, so changing the router’s Wi‑Fi channel, moving the router or laptop, or switching to 5 GHz was recommended [#16495269][#16495398][#16496058] A good test was to connect the laptop by cable (or a USB‑RJ45 adapter) and see whether the dropouts disappear; if they do, the problem is in the laptop’s Wi‑Fi path, not the Internet connection itself [#16495652] It was also suggested to temporarily uninstall Avast, because antivirus software can sometimes slow the system or interfere with connectivity [#16496566] If the problem persisted, replacing the Wi‑Fi card or using a router with a different chipset was also suggested [#16495398][#16495652]
  • #1 16493842
    kluivert_9
    Hello, I recently acquired a new ASUS UX410UA laptop, and a problem arose immediately. Namely, when browsing websites, he sometimes loses access to the Internet. As if every now and then something "broke". There were no suspects diagnosed on the computer. Of course, access to the Internet after a few minutes returns, but it irritates me. I contacted the Asus service, they recommended it in the device manager / network cards / disconnect the WAN Miniport (because apparently it has been released with the Windows 10 update and something is blocking), but it did not help. Then they recommended to reinstall the drivers for the network card, but it also did not help. Then I tried to update the drivers for the card, but nothing like that. I read that antiviruses can mix .... On the previous laptop I did not have such shares, the internet is also on the phone. From what I've noticed, it's usually the net on Facebook, but maybe it's a coincidence (unless it's about the amount of data to display-if I am). I will not check the cable because this jack does not have such a way out, but I would not focus on the router because it's rather a paw fault.
    To sum up the computer data:
    System: Windows 10 64bit
    Network card: Intel (R) Dual Band Wireless-AC 8260
    Router: CISCO EPC3925
    Internet services: Multimedia Polska
    Antivirus: free Avast
    Thanks in advance for your help
  • #2 16493870
    VooVoo
    Help: 215
    Rate: 266
    From another post, but still valid:
    1. console and IP address control
    2. ping -t gateway address
    3. another console ij / w but the address is e.g. wp.pl
    4. if you are pinging the gate, are the drivers ?? win10 or better?
    5. start the system in safe mode with network support and repeat the above mentioned activities
  • #3 16493905
    kluivert_9
    Is there a chance to write down these points a little more accurately ??
    Because I am a little layman in this field.
  • #4 16494437
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Modemorouter (because I'm talking about it here from the operator) has no external antennas, so it's also a bit "guilty" here.
    kluivert_9 wrote:
    I will not check the cable because this jack has no such exit
    But does it have USB ports? - you can buy a USB-RJ45 network card.
    And now the most important thing - if my first post explains something, install InSSIDer v2 / Home on the computer and insert the result of the network signal here - we will see the signal strength from this modemorouter and the wifi network congestion.
  • Suggests checking Wi‑Fi signal with InSSIDer and using USB‑RJ45 adapter
    #5 16495186
    kluivert_9
    Screen from the program:
    https://obrazki.elektroda.pl/5455487900_1495722191.jpg
  • #6 16495269
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Well, now you know why there is a problem - wifi network probably from 50 to 2.4 GHz where there are only 13 channels, so another network on the same channel disturbs your network.
  • Default gateway unavailable during Wi‑Fi dropouts
    #7 16495360
    kluivert_9
    As far as the channel is concerned, I am only on 8. As for the disturbances, it never happened on an older laptop (at the same time on a different stand, nothing like this happens). It is strange that now it suddenly began to happen. Maybe this is due to newer hardware .....? (as if you could explain the matter a bit more clearly). What should I do now ????
    (during the writing of the answer, the connection was broken again and only after I clicked to solve the problem, the message "The default gateway is unavailable" pops up, and then the internet has returned.)
  • Wi-fi channel overlap and Windows 10 driver issues
    #8 16495398
    KOCUREK1970
    Help: 3860
    Rate: 5488
    kluivert_9 wrote:
    As far as the channel is concerned, only I am at 8
    At this point - but there are other networks very close (the interval between one network and the other should be at least 2 channels)
    Rather, the sensitivity of the wireless card itself - some are doing better with others worse.
    Change the channel number of the wifi to a different one, change the location of the operator modemorouter, change the location of your computer, replace the network card in the computer with another one.
    Well, W10 - this one can have permanent problems with the Internet, "dump" drivers and hardware.
  • Suggesting Wi‑Fi channel, placement, and adapter checks
    #9 16495613
    kluivert_9
    So in general everything is to blame Windows 10 ......, because I would not change the network card in my computer because I just bought it, so it's a bit of a mistake. And as for changing the network channel, it's hard to choose something since in the block on each channel someone is sitting with the network. And I would rather have to call a technician from the multimedia, because I will not do it myself ?????
    And how do you relate to the statements of the VooVoo user?
    Do you think that reworking these points can help?
  • Suggesting wired test, USB-Ethernet, or router swap
    #10 16495652
    KOCUREK1970
    Help: 3860
    Rate: 5488
    kluivert_9 wrote:
    everything is guilty of Windows 10 ......,
    All do not - but you can not hide that it has a part in it and it is not at all significant.
    kluivert_9 wrote:
    I will not change the network card in my computer because I just bought it, so it's a bit misguided.
    Sometimes it is not possible and change is necessary.
    The hardware manufacturer has somewhere that he mounts in his equipment.
    Can you do it?
    Connect during the test to the modemorouter with a cable - if all will be ok - then the instructions of the colleague @VooVoo they do not bring much here - everything is ok with the net, and the problem is already the wifi itself in this particular computer.
    You say that the computer does not have a LAN card - you would have to buy a USB-RJ45 network card.
    You can also try to install your own router and connect it to this operator modem, the situation may improve, because your own router will have a different chipset chip and your card will like it more.
    You can also uninstall this Avast - the free version does not meet any assumptions of computer protection.
  • #11 16495983
    jprzedworski
    Help: 758
    Rate: 828
    With that I would argue. What - without protection at all? Suicide! Avast is quite good:
    https://www.youtube.com/watch?v=G0NKV-aGOo0
    https://www.youtube.com/watch?v=1JcUZNub_ts
    https://www.av-test.org/en/antivirus/home-windows/
  • #12 16495984
    kluivert_9
    Is there any other free anti-virus that meets any requirements ???? (Avira)
  • #13 16496021
    KOCUREK1970
    Help: 3860
    Rate: 5488
    jprzedworski wrote:
    no protection at all? Suicide!
    I used the term "free".
    Compared to what?
    kluivert_9 wrote:
    is there any other free antivirus that meets any requirements ???? (Avira)
    You bought a new computer and you can not afford a paid anti-virus?
    My offers of paid versions:
    BitDefender, AVG, F-Secure
  • #14 16496029
    jprzedworski
    Help: 758
    Rate: 828
    I know. And I'm still saying that free does not mean bad. I will repeat this link:
    Usually free versions have limited functions, but the same signatures and the same engine.
  • Free antivirus argued to be useless
    #15 16496040
    KOCUREK1970
    Help: 3860
    Rate: 5488
    jprzedworski wrote:
    I still say that free does not mean bad.
    What interest would the author of the program have in order to give me the best protection possible for free, since he has the same version of the same paid program?
    Probably the free and paid versions have differences - and these are probably the differences that are important for the protection of the computer (if it were not, who would pay the money for only e-mail or www protection).
    Everyone thinks differently - I have such an opinion and I will not change it.
    For me, free software is completely useless.
  • Avast test results and version comparison link
    #16 16496046
    jprzedworski
    Help: 758
    Rate: 828
    You can have your opinion. I rely on tests (I have no technical possibilities to do it myself):
    https://www.av-test.org/en/antivirus/home-win...-2017/avast-free-antivirus-17.2--17.3-171413/
    If you show me other tests proving that this is a hopeless program ( "completely useless" ), then I will change my mind. The entire internet is available.
    And the version differences are:
    https://www.avast.com/pl-pl/index
    You need to click: "Compare products"
  • #17 16496058
    kiss39
    Help: 397
    Rate: 636
    If you want stability, you may want to consider changing the band from 2.4GHz to 5GHz as you have 2.4Ghz network. This may involve the replacement of devices at 5Ghz
  • #18 16496081
    KOCUREK1970
    Help: 3860
    Rate: 5488
    And me too:
    https://www.virustotal.com/pl/file/c7eccf0369...ec5a5d2726a6fe137e1343c72dd43ec7516/analysis/
    jprzedworski wrote:
    If you show me other tests proving that this is a hopeless program ("completely useless"),
    Only with this term I summarized this program.
    Defense of Avast as a reasonable antivirus choice
    #19 16496234
    jprzedworski
    Help: 758
    Rate: 828
    Did he let anything go? He is not one - he is in well-known company. That is why Virustotal was born that nobody is perfect.
    I did not write that it is the best. I wrote "nice". I agree with one. It's better to match up than down.
    I reacted because the sentence "uninstall Avasta" someone treats so that if so miserable, then maybe nothing at all ... Many people do that, they have nothing. "Because it will not do anything."
    KOCUREK1970
    Help: 3860
    Rate: 5488
    jprzedworski wrote:
    I reacted, because the phrase "uninstall Avasta" someone treats so that if so miserable, then maybe nothing at all ...
    Very often (do not know why) the antivirus program "slows down" the computer, slows down its work, or even makes it impossible to connect to the Internet - it is worth uninstalling it to check (confirm / reject) or actually he did not become the culprit here.
    Using the free Avasta, you can successfully opt out of it and replace it with applications (Defender or Microsoft Security Essentials) - some of them even implemented in the system - and it seems to me that they work much better, more efficiently and without load than the program external. The end result is the same but more benefits for us.
    Use the Internet with your head, because even an antivirus for PLN 500 a month does not absolve us from thinking and is not in a position to make decisions for us and respond to threats resulting from our ill-considered actions.
    In addition, some "friendly" DNS (eg Symantec) and we are somehow protected - but it still does not absolve us from thinking instead of blindly clicking on everything.
  • #21 19093638
    kluivert_9
    Windows update solved the problem
The discussion revolves around intermittent internet connectivity issues experienced on an ASUS UX410UA laptop, despite a stable WiFi connection. The user reports frequent disconnections while browsing, with suggestions from ASUS support including disabling the WAN Miniport and reinstalling network drivers, which proved ineffective. Participants in the forum recommend various troubleshooting steps such as checking the signal strength using InSSIDer, changing the WiFi channel to reduce interference, and testing the connection via Ethernet to isolate the problem. The impact of antivirus software on connectivity is also debated, with suggestions to consider alternatives like Windows Defender. The conversation highlights the potential influence of Windows 10 on network performance and the need for hardware adjustments or replacements to improve stability.
