[Solved] WSK 125 - Tips & Techniques for Mounting Bearings on Shaft: Cold-Warm Method & Tools Used
smootny 13629 15
How do I mount the second bearings on the shaft in a WSK engine without damaging them?
Mount the second bearings warm, not by hammering them in cold: cool the shaft/bearing, heat the bearing or crankcase, and let the parts slide together [#17063545] In practice, the thread recommends assembling the engine warm because it releases bearing mounting stress; at home you can use an electric cooker, preheated oven, or heat gun instead of a burner [#17063524] For the temperatures mentioned, keep bearings up to about 120°C and the crankcase around 120–150°C, with one reply saying the crankcase can go up to 160°C [#17063577] Another practical tip was to put the whole assembly into one crankcase half first, then fit the heated other half on top and tighten/tap it into place with a wooden hammer [#17060800] If you need to fit a bearing onto the shaft, use proper tools/discs that act on the inner ring rather than striking the bearing directly [#17063524]
  • Asking how to mount the second bearing on the shaft
    #1 17060756
    smootny
    Help: 6
    Rate: 79
    When mounting bearings in the WSK engine I use a cold-warm patent.
    1st stage both crankcase warm and bearings cold (both halves),
    2. in the second stage, the cold shaft and the bearing in the crankcase are heated.
    Every time everything goes smoothly. However, I always have a zagwozdko with subsequent bearings on the shaft.
    How to mount them .. Cold - hammer in with some extra spindle so that it grasps both raceways of the bearing and does not damage anything in it. ???
    It is a pity, however, then plugs and cranksets .. 100% will get a smoke.
    I am asking for your opinion (maybe some videos) - how do you mount "second" bearings on the shaft in this engine.
    Greetings.
  • #2 17060800
    jack63
    Help: 851
    Rate: 2822
    Look for ETZ or Simson service in the network.
    This is all well described. You just need to modify the method to WSK
    Generally, "put everything in one half of the crankcase, and then put the heated other half on top. Then the screws and tapping with a wooden hammer to form.
    You could write a lot. You just have to ... think.
  • Bearing installation advice for oil-lubricated shafts
    #3 17060824
    mladenick
    Help: 14
    Rate: 90
    I do not know exactly how to mount bearings in this WSCe, if it is self-lubricating it will be hard with the temperature, you can not go crazy better, if it is oil lubricated, you heat it to about 110 ° C, if you do not want to heat, you can drive it, to hammering you use e.g. a copper or brass hammer (so that it is e.g. 30 mm thick and flat from below) and you can hit with a hammer, aluminum is not recommended, it will be too soft.
  • #5 17060894
    smootny
    Help: 6
    Rate: 79
    Tommy82 wrote:
    https://www.elektroda.pl/rtvforum/topic532585.html
    Look: cross section of the engine.
    in the S-01 engine, the shaft has 4 bearings.
    Exactly :]
    And that's what I'm thinking ...
    How to assemble it to do it professionally ...
  • #6 17063372
    E8600
    Help: 529
    Rate: 2520
    People used to nobody play in the cold / heat just the press. The method with thermal expansion must be used but for large elements, e.g. bearing 20 cm in diameter, otherwise it would not have come in.
    If I understood in some high-speed engine, but the WSKi engine has such vibrations that the screws themselves are unscrewing. Form overgrowth and additionally if you heat up too much aluminum with a gas burner, it will become plasticized (the crystal mesh will change). Heating aluminum above 500 degrees removes dispersion curing; it is very easy to achieve so much with the burner despite the rapid heat dissipation through the aluminum.
  • #7 17063524
    jack63
    Help: 851
    Rate: 2822
    What quirks are you writing?
    What burner? What press
    And very large bearings are cold assembled with loose and anaerobic adhesive.
    In the factory and decent service, the engines are assembled "warm", because this allows the bearing mounting stress to be released.
    Heating plates and special discs for the inner rings of bearings are used for heating. At home, all you need is an electric cooker and a wedged finger as a temperature meter.
    No burners !!!
    Folding as above is no overgrowth, only normal operation. In the cold, you can only break the engine. And screwing / screwing cold is the pinnacle of Januszowski.
  • #8 17063545
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    You don't need to heat that much, just heat up 120 - 150 degrees with a heat gun, or crankcase to a preheated oven and it's enough. Such temperatures (or even higher) the engine reaches during operation and nothing happens with aluminum. For this mounted bearings for the freezer for an hour ... and what a pleasure to assemble, the hammer does not need to be used. Known from own practice, repairs of combustion saws, also WSK, Komar, Romet engines. These hammers were used when there was no such tools available (e.g. so-called "electric" heat guns). Now that there is a possibility, why not use it is easier and safer for repaired components, of course, everything with thoughtful sense and in accordance with "art".
  • #9 17063577
    jack63
    Help: 851
    Rate: 2822
    Bearings max 120 oC. Karter up to 160 and nothing bad happens. Just check the temp as you used to control your iron, after a hissing sound applied to a split second of a wedged finger. With a certain dose of accuracy + - 5 oC
  • #10 17063683
    E8600
    Help: 529
    Rate: 2520
    I'm writing a burner because I've already seen those who heard something about heating (9 minutes of the film).
    There are many more similar films with a burner (people think that they do better than others because they heat and they actually do worse than if someone skillfully hammers it without heating).
    Large bearings are cooled with liquid nitrogen (due to size and fit tolerance).
    Unfortunately, in large factories it heats only where it is necessary (e.g. shaft bearings) and the rest goes to the press.
    Here a movie for the author if he wants to do better than others.
    At this temperature I would be careful with Chinese "shit" engines.
  • #11 17063749
    jack63
    Help: 851
    Rate: 2822
    And they will melt like soldering .... ???
    In addition, cranksets are not oversaturated, such as rims.
    Most do not speak English, and at the beginning of the film was:
    ... All parts should be ABSOLUTELY CLEAN ...
    What most ... forget about.
  • #12 17063848
    andrzej20001
    Help: 1578
    Rate: 6669
    You put it in the oven and the finito ..
  • #13 17063878
    jack63
    Help: 851
    Rate: 2822
    An oven, or a quarrel with you: what's that stinking here?
    Why risk it for about PLN 50 you can buy an electric stove and use it in the workshop and not in the kitchen.
  • #14 17063903
    andrzej20001
    Help: 1578
    Rate: 6669
    jack63 wrote:
    what stinks here?
    ?? eeeeee, the eggs popped out of the pot :) ?
  • #15 17063929
    jack63
    Help: 851
    Rate: 2822
    Were the eggs part of the engine?
    In addition, the heating device must be close to the table on which the motor is being assembled. Especially cranksets cool down very quickly and then sneeze from correct assembly ...
    Therefore, you need to heat them a little higher and ... pegs into the teeth tempo 22 ...
  • #16 20007928
    smootny
    Help: 6
    Rate: 79
    Heat/cold method - that's where I'll stay.
The discussion focuses on techniques for mounting bearings in the WSK engine using a cold-warm method. Users share their experiences and methods, emphasizing the importance of heating the crankcase and cooling the bearings for proper assembly. Various tools and techniques are suggested, including the use of a copper or brass hammer for driving bearings, and the recommendation to avoid excessive heating that could damage aluminum components. Some participants advocate for using a heat gun or oven for controlled heating, while others caution against using gas burners due to the risk of overheating. The conversation also touches on the use of adhesives for larger bearings and the necessity of cleanliness during assembly.
TL;DR: For WSK/S‑01 engines, use warm–cold assembly: bearings ≤120°C, cases 120–160°C. "Bearings max 120 oC." For home mechanics mounting crankshaft bearings cleanly without presses or torches. [Elektroda, jack63, post #17063577]
Why it matters: Correct temperatures and sequence prevent damage, misalignment, and early bearing failure while simplifying assembly.
What’s the best way to install the "second" bearing on the WSK shaft?
Use the all‑in‑one‑half method. Fit the crankshaft with all bearings into one crankcase half. Heat the other half and place it over the assembly. Install screws and tap lightly with a wooden mallet to seat. This avoids forcing the second bearing onto the shaft. [Elektroda, jack63, post #17060800]
What temperatures should I use for bearings and crankcase?
Limit bearings to 120°C. Heat the crankcase up to about 160°C. Check temperature with a quick “hissing finger” test if needed. Expect roughly ±5°C accuracy with that method. This combo enables smooth assembly without over‑stressing parts. [Elektroda, jack63, post #17063577]
What’s a minimal tool list to do this at home?
Use a heat gun or a preheated oven to warm crankcases. Chill bearings in a freezer for about an hour. Parts will slide together and you won’t need a hammer. This approach works for WSK, Komar, Romet, and small saw engines. [Elektroda, wojtek1234321, post #17063545]
Is it okay to use a gas burner on the crankcase?
Avoid torches on aluminum. Overheating risks softening and dimensional change. "Heating aluminum above 500 degrees removes dispersion curing." It’s easy to overshoot with a burner. Use controlled heating instead to protect the alloy and bearings. [Elektroda, E8600, post #17063372]
Press vs heat: which method is better for WSK?
Use warm assembly for engines. "In the factory and decent service, the engines are assembled 'warm'." Heating relieves mounting stresses and reduces damage risk. The same source’s warning stands: "No burners !!!" Choose controlled electric heat, not open flame. [Elektroda, jack63, post #17063524]
How do I close the cases without misalignment?
Place the crankshaft and all bearings in one crankcase half. Heat the other half and set it on top. Install the screws, then tap gently with a wooden hammer to align and seat. This centers components without shock loads. [Elektroda, jack63, post #17060800]
How fast must I work after heating?
Work quickly because crankcases cool fast. Keep the heating source near your bench. Heat slightly higher, then assemble at speed to maintain clearance. "... pegs into the teeth tempo 22 ..." captures the needed pace. [Elektroda, jack63, post #17063929]
How clean must components be before assembly?
Very clean. Degrease, remove chips, and keep grit away from rolling elements. "All parts should be ABSOLUTELY CLEAN ..." Cleanliness prevents scoring, misalignment, and premature wear. Prepare a clean bench and lint‑free wipes. [Elektroda, jack63, post #17063749]
Can I use my kitchen oven for heating cases?
Avoid the kitchen oven. Buy a cheap electric stove for the workshop, around PLN 50. Use it in the workshop, not in the kitchen. It’s safer, cleaner, and more convenient for repetitive heating. [Elektroda, jack63, post #17063878]
What if my engine uses self‑lubricating bearings or bushings?
Avoid aggressive heating on self‑lubricating parts. For oil‑lubricated elements, about 110°C is appropriate. If you must drive cold, use a copper or brass hammer or drift. Aluminum tooling is too soft and deforms. [Elektroda, mladenick, post #17060824]
How many bearings does the S‑01 crankshaft use?
Four bearings. That influences your setup, supports, and heating plan. Review a cross‑section and stage all four in one half before closing cases. [Elektroda, Tommy82, post #17060880]
Should I use retaining compounds to seat bearings?
Large bearings can be cold‑assembled with a loose fit and anaerobic adhesive. For small motorcycle engines, warm assembly is preferred to manage stress. Use heating plates or an electric cooker on inner rings if needed. "No burners !!!" [Elektroda, jack63, post #17063524]
Any cautions for lower‑grade or "Chinese" cases?
Be cautious at the upper 160°C range on lower‑grade castings. Monitor temperature closely and avoid overshoot. If uncertain, reduce the target temperature and reheat as needed. This minimizes risk of material degradation. [Elektroda, E8600, post #17063683]
How do I assemble the crank using the warm–cold method? (3 steps)
  1. Place the crankshaft with all bearings into one crankcase half.
  2. Heat the other half evenly, then set it over the assembly.
  3. Install screws and tap lightly with a wooden mallet to seat and align. [Elektroda, jack63, post #17060800]
