[Solved] Bosch GWS Grinder Damaged Transmission: Repair, Replace or Buy Original?
elektronikq 12624 18
Can the loose Bosch grinder transmission/head be repaired, or do I need to replace the whole unit with an original part?
Yes — if the gear teeth are intact, you usually do not need to replace the entire transmission; replace the gear flange/collar and, if needed, the plain bearing or head bearings instead [#16600838] For this model, the Bosch flange part number given was 1 607 000 936, and it can be ordered from Bosch central service or a power-tool service shop; one reply also mentions a complete head replacement 1605805079 if the damage is beyond repair [#16606149][#16609282] A press is recommended for disassembly/assembly, and you should not use a hammer [#16600838][#16606881] The thread also notes that the correct spindle bearing may be a C3-clearance bearing such as 6201RSC3, so some play can be normal depending on the bearing specification [#16612815] If you are unsure about the exact damage, Bosch service can quote the repair first and arrange courier pickup at Bosch’s expense [#16667524]
  • #1 16600693
    elektronikq
    Help: 70
    Rate: 614
    This item:
    Bosch GWS Grinder Damaged Transmission: Repair, Replace or Buy Original? Bosch GWS Grinder Damaged Transmission: Repair, Replace or Buy Original?
    It has slack, as a result of which the grinder shakes and the wheel shakes. Can this item be repaired or do you have to buy the whole item?
    Replacement, original?
  • #2 16600789
    brofran
    Help: 650
    Rate: 1406
    elektronikq wrote:
    Can this element be repaired?
    No chance, just a new complete transmission. However, there may be a problem buying a replacement.
    TomekB123
    Help: 43
    Rate: 146
    If the teeth on the wheel are not damaged, all you have to do is replace the gear flange and possibly also the plain bearing in the head.
    Press recommended for wheel dismounting. Do not use a hammer.
  • #4 16601504
    elektronikq
    Help: 70
    Rate: 614
    Teeth are in very good condition. How to remove this wheel with teeth? Bearing puller?
  • #5 16605859
    elektronikq
    Help: 70
    Rate: 614
    I downloaded the gear.
    The placenta was crumbling.
    And I have something like this:
    And you can't pull it out, can you? This bearing is as if embedded in plastic.
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1620
    You have to buy a collar. It is a good habit to specify a model - this is a technical forum.
  • #7 16606142
    elektronikq
    Help: 70
    Rate: 614
    GWS 9-125 CE. 90s grinder. Where can I buy this flange?
    Topolski Mirosław
    Help: 355
    Rate: 1620
    If you can provide the catalog number starting with 0 60 ......... and I will give you the part number. Flange number: 1 607 000 936 price PLN 67 net, and you will buy at Bosch central service in Warsaw or at any power tool service.
  • #9 16606534
    elektronikq
    Help: 70
    Rate: 614
    link
    here I have a diagram but that doesn't agree with my grinder.
    > PA66-GF35
    Topolski Mirosław
    Help: 355
    Rate: 1620
    Everything is correct you are looking for by model and then enter the catalog number starting with 0 60 .............. is on the company plate. Order the part with the number I gave and it will be ok. You live in Warsaw so go to the Bosch central service and you will get it there easily and when you take the gear and spindle with you, they will put them on the press right away.
    Here you have a link to the Bosch: http://www.powertools-aftersalesservice.com/p...wa213S0VrcFhMZ3NRVUhsXzd5NC12VFVYaVljUVVIbDg9 click on the product number corresponding to your device ( all models produced for the European market have a bearing flange with the same number that I gave you).
    PtasiorWro
    Help: 111
    Rate: 544
    Just roll the collar and replace the 6201RS bearing and you have a problem with your head or replacement for a new 1605805079 price of the new PLN 41 + V catalog price for a street customer.
    aha, and be sure to replace the slide bearing 1 600 200 029 or you can insert a bearing KH0810. This is the support on the other side of the spindle axis where you have a dimension of 8mm.
    Added after 8 [minutes]:
    Here you have the bosch documentation, entry GWS9-125 and look for the model corresponding to your grinder
    http://www.powertools-aftersalesservice.com/p...bxp/SPSEARCH?lgRedirect=true&lg=pl&country=pl
  • #12 16610370
    elektronikq
    Help: 70
    Rate: 614
    I just solved the problem as a colleague wrote above. Let's see how it works. If not, you will buy an original collar. I do not see this Pan in the list.
    PtasiorWro
    Help: 111
    Rate: 544
    This bushing has a sliding bearing in the head, supports the lower part of the spindle, at the top you have support on the replaced 6201 bearing and at the bottom is the bearing or HK0810 bearing. And you can't see it because it appears as a whole head in some drawings, but when you open another GWS drawing, you'll have it listed. And check it out because if the bearing fell apart, there is definitely looseness in the bearing, replace it because the gear is too bad.
  • #14 16611486
    elektronikq
    Help: 70
    Rate: 614
    1600910018 do you mean this part?
    For me, the acetabulum was not bearing. The acetabulum is ok after folding, there is no slack. But the bearings make it crap. 20 PLN bearing and after inserting the roller is loose.
    Thank you all for your help.
    PtasiorWro
    Help: 111
    Rate: 544
    It is supposed to be "crap" :D there is supposed to be a bearing with C3 clearance, which is exactly 6201RSC3, it is a special technological clearance, the bearings are manufactured with different applications, one will be rigid and the other will look like it would have LUZ but that's how it should be. Write what bearing you put in, I will tell you if it will be ok. As for the bearing, depending on the number 10 digit were used HK bearings or needle bearings. If there is no clearance on the folded one, you will not check it, you need to insert the spindle without a rack and a bearing plate and check that there is no play. With such damage to the bearing as you had it is very likely that you have it.
  • #16 16630967
    elektronikq
    Help: 70
    Rate: 614
    Fag 6203 2rs such a bearing or more or less this type.
  • #17 16667524
    Narzędzia Bosch
    Rate: 32
    In this situation, it is safest to send the tool to the site. It is possible to quote the repair before sending the product. The courier, at Bosch's expense, receives the tools and delivers the repaired back to their own hands.
  • #18 17124153
    elektronikq
    Help: 70
    Rate: 614
    After this treatment, the sander grinds. Thank you for your help.
  • #19 17124156
    elektronikq
    Help: 70
    Rate: 614
    Added after 37 [seconds]:
    As in the subject.
The discussion revolves around a Bosch GWS 9-125 CE grinder experiencing transmission issues, specifically slack causing shaking of the grinder and wheel. Users suggest that while a complete transmission replacement may be necessary, it is possible to repair by replacing the gear flange and bearings if the teeth are intact. Recommendations include using a bearing puller for wheel removal and sourcing parts from Bosch service centers. Specific part numbers and prices for replacement components are provided, along with advice on ensuring proper bearing clearance to avoid future issues. Some users opted for professional repair services to ensure quality fixes.
