Samsung Note 4 - Motherboard with N910C mounted in N910F does not work with S-pe
83cichy 5595 2
  • #1 16405717
    83cichy
    Rate: 29
    I switched the motherboard as in the topic, and the stylus, i.e. the AirView function, does not work, the flesh is full, the stylus and the model C and F, neither reacts.
    Maybe someone has an idea what else you can attach to.
    Regards Cichy
    kamilek1307
    Help: 5
    Rate: 19
    You probably didn't have a single ribbon attached. It's terribly hard to connect. I put a piece of 4-fold card under the tape connector and then the connector clicked.
    Moderated By nutergsm:
    We do not tolerate profanity in any form on the forum. I corrected the post.
  • #3 16561609
    Lamberda
    Silent and how did this S pen and other functions get started? How do these motherboards in these models fit easily? everything works?
