Samsung Note 4: Kernel Warranty Bit Set, Now Unresponsive - Possible Fixes?
kloon 3426 3
  • #1 16508939
    kloon
    Some time ago on my Note 4 appeared: set warrannty bit kernel. The phone was lying around for some time so I decided to turn it on. I connected to the charger and it started displaying the battery charging. But after a while it went blank (normal) but stopped responding (no reaction - no vibration, black screen). Help me if I can do something else with it or only spare parts (the screen worked so it should be good) Thank you in advance for your help and best regards.
  • #2 16509001
    nutergsm
    Help: 1034
    Rate: 1665
    Try to upload new firmware to him.
  • #3 16509443
    kloon
    Only that I can't fire. It won't even vibrate, and the computer can't see it now. So Odin will also have a problem. Tomorrow I will try to contact a friend who has a Samsung box.
  • #4 16509747
    nutergsm
    Help: 1034
    Rate: 1665
    Have you tried running it in download mode? I would check the battery voltage.
