Peugeot 5008 Leaking FAP Tank: Can It Be Repaired with Hot Soldering Iron or Do I Need a New One?
yaro30 7575 3
  • #1 16411070
    yaro30
    Rate: 10
    The mechanic stated that I have an empty fap tank and the reason is that it is leaking. The tank was refilled a year ago. At that time I was told that it is leaking slightly, so it looks like a small leak, since it has passed for over a year. The question now is whether such tanks can be repaired because looking at the Allegro it looks like plastic, so for example a hot soldering iron should seem to do the job at a negligible cost. Can he do it or not because the new tank is terribly expensive?
  • #2 16411473
  • #3 16411595
    yaro30
    Rate: 10
    I was told on the website that 1300 will be. The liquid itself is said to be around 500 because 3l of it comes in. On the alegro, such a new tank is over 700. Where the price is 270, I would gladly take it :) ?
  • #4 16411662
