Peugeot 307 SW - Secondary Air Pump Pipe Replacement: Find Plastic Tube with 3 Cracks
obadaw 8550 2
  • #1 16631785
    obadaw
    Rate: 18
    Is there anyone able to track me such a plastic tube as in the picture? It is from the pneumothorax to the secondary air pump.
    I have 3 cracks on it, gluing does not help it anymore and I cannot locate it anywhere. Only the website, and on the website they cost as much as PLN 280: /
  • #2 16639022
    andrzej lukaszewicz
    Help: 626
    Rate: 2122
    Stimulants will probably be in a similar condition to yours. Sticking with sackcloth insulation also makes no sense (photo). If you do not want to throw away the 280 PLN, buy the appropriate RPK heat-shrinkable T-shirt (the one with glue inside - for cable repairs, for forging in any electrical store) and stretch the appropriate section on this damaged pipe and heat it with a heat gun or over the gas cooker "take off" the T-shirt keeping the original shape of the pipe during this operation.
    Before that, of course, wash well with the oil with a suitable degreaser (degreaser, breakclean, etc.)
  • #3 16976943
    obadaw
    Rate: 18
    Okay, thanks for the advice that helped :)
