The Milwaukee M12-18C charger is flashing and the red LED is not charging.
rsv6 13707 6
  • #1 16859494
    rsv6
    Rate: 285
    I have a problem with the Milwaukee M12-18C charger namely the flashing red LED does not want to charge. I will add that it is not the fault of the battery because the M12-18FC works without a problem ..
  • Check charger and battery series compatibility
    #2 16861550
    aaanteka
    Help: 729
    Rate: 1193
    And whether there is a problem in switching chargers. What series is it or not by accident with a battery charging processor (as in laptops). It's worth reading the instructions carefully. I suggest asking the producer or local distributor. The tools we use have such a problem - they are not compatible with other series:
    "Intelligent Milwaukee(R) REDLINK (TM) electronics
    Overload Protection: Protects the user against damage to the cordless power tool in improper situations
    Temperature management system - Keeps the battery at the perfect temperature to ensure maximum life
    Individual target monitoring - ensures optimal charging and discharging for maximum life
    Discharge protection - protects cells against excessive discharge
    Up to 3X more working time *, 20% more strength *, up to 2X more charges *
    * Compared to other lithium-ion technologies and / or previous Milwaukee(R) batteries. The result depends on voltage, machine and application. "
  • Burned 8.1 ohm resistor before TOP256EN
    #3 16861657
    rsv6
    Rate: 285
    You're doing an ad! These chargers are faulty. Only the FC version is good. Already working, it turned out that the 8.1ohm resistor burned before Top256en I still have 5 chargers with a similar problem. However, the processor itself fell in 3.
  • #4 16861682
    aaanteka
    Help: 729
    Rate: 1193
    Buddy, think about it? You started the topic about her. I suspect you have no idea what you are using. The instructions for use must be read!
    On the other hand, why do you ask a question if you know better? Do you not provide details about the batteries being charged?
  • #5 16861742
    rsv6
    Rate: 285
    I gave the topic for diagnosis. It turned out that the voltage has inverter disappears. Just enter on YouTube the model of the charger is the mass of damaged these chargers. The moral is that Milwaukee M12-18C is flawed.
  • Need battery model and series identification
    #6 16861776
    aaanteka
    Help: 729
    Rate: 1193
    Just read the forum rules and advertisement and then place the topic correctly.
    You should also understand the texts written by others.
    The text two posts above is a fragment of the user's manual for the battery of the power tools of this manufacturer.
    Neither of us nor the search engine will overtake us what model of rechargeable batteries is used, what generation, from what year of production and series.
    St. Andrew's are over :D .
  • #7 16862264
    rsv6
    Rate: 285
    I have these chargers to repair a large amount of the same type. Each model is the same for the letters.
The Milwaukee M12-18C charger is experiencing issues with a flashing red LED, indicating it is not charging. Users suggest that the problem may stem from compatibility issues with certain battery series or internal faults within the charger itself. Some users report that the M12-18C model is prone to failure, with common issues including burned resistors and inverter voltage loss. Recommendations include consulting the user manual for compatibility and considering repairs for faulty chargers, as many users have encountered similar problems with this model.
