ZTE MF283+ Router: Need Replacement Power Supply - Model ZTE STC A20120150C55-A, 12V 1.5A, Tip Size
sliwa01 18462 5
  • Confirming 5.5/2.1 mm tip and 12 V supply requirements
    #1 16420592
    sliwa01
    I need to buy a new power supply for the ZTE MF283 + router. The old one has the following data, model ZTE STC A20120150C55-A. Input 0.8A Output 12V 1.5A. Nowhere can I find information about the size of the tip going into the router. At some archival auction there is information 5.5 / 2.1 but I am not able to confirm it. By the way: do I need to buy a new power supply with exactly the same out-out data?
    Thanks
  • #2 16420641
    wzielonymgaju18
    Help: 32
    Rate: 110
    Certainly, the power supply must have an output voltage of 12V and an output current of 1.5A or higher (it can be e.g. 2A)
    Regarding the plug, buy a 12V power supply with any plug and buy a DC 2.1 / 5.5 plug and just cut the old one and solder the new one.
  • Affordable 12V supplies with 5.5×2.1 mm plugs are readily available
    #3 16421090
    dt1
    Admin of Computers group
    Help: 7319
    Rate: 8299
  • #4 16421104
    sliwa01
    Ok, thank you, I thought that this number of amps could be limited by the router, but as I understand it, the number of amps in the output in this case is so important for the router that it is not less than 1.5A and of course 12V. Thanks. I also assume the 5.5 / 2.1 size is appropriate for this router model.
  • Higher-current PSU is safe if voltage and polarity match
    #5 16421113
    dt1
    Help: 7319
    Rate: 8299
    At some German auction I found your PSU model and it was described as 5.5x2.1, but unfortunately I can't be sure either.
    1.5A is the current efficiency of the power supply. When loading the power supply, we cannot (should not) consume more current than its current capacity. The router can charge up to 1.5A (since such a power supply was delivered with it at the factory), if we give a power supply with a higher capacity (2 or 3A or even more) - nothing bad will happen, it will have a slightly larger reserve.
    Of course, the tension has to match.
    Take a look at the polarity of the power supply you are buying. In 95% of cases, the plus is inside, but it's worth checking before buying and connecting. Appropriate symbols should be on the power supply.
  • #6 16423348
    sliwa01
    Very helpful. Thanks!
