iPhone 5s Touch Screen Issue: Inaccurate Touch Response after Screen Replacement
basal77 3300 5
  • #1 16421081
    basal77
    Hello, I have a problem with the iPhone 5s. The point is that the touch works badly, I changed the screen, but it did not work, for example when I press y on the screen keyboard, then you press t or u, it is like that in several places.
    All pins from the connector are clean, the board was not flooded, maybe someone had a similar problem ??
  • #2 16421112
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    And do a hard resecik Home + Sleep until it restarts. Sometimes it helps.
    If that doesn't help and the touch is rice, I have to worry you.
  • #3 16421469
    basal77
    I did a hard reset and uploaded new software, but nothing helped.
  • #4 16423382
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    It happened to me several times and in one case the reset helped, but in the second, unfortunately, the digitizer had to be replaced with another (also a rice one) :) ). Such a life...
  • #5 16423749
    basal77
    As I wrote earlier, the fault is not in the digitizer because it works normally on another disc.
  • #6 16432257
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    Cumullus or Meson to be replaced (or both)
