Repairing Damaged Gutmann Mega Macs 50 Main Cable for Ford Engine Controller J1850 PWM
Daro122 12807 8
  • #1 16422731
    Daro122
    Help: 165
    Rate: 751
    The cable was damaged and it was manifested by the lack of connection with the engine controller of the Ford brand, supported by the J1850 PWM protocol. The path inside the laminate, from pin 2 B + to the overvoltage protection diodes, has been burnt. The arrow shows where the damage is inside the laminate. The repair consists in repairing the connection, I made such a connection with one wire from a thin wire in insulation. It works as it should now, the cable number 8PZ 010 603-161 costs just over PLN 1,200, so it was worth it.
    • Repairing Damaged Gutmann Mega Macs 50 Main Cable for Ford Engine Controller J1850 PWM Naprawa.JPG (1.15 MB) You must be logged in to download this attachment.
    • Repairing Damaged Gutmann Mega Macs 50 Main Cable for Ford Engine Controller J1850 PWM Uszkodzenie.JPG (3.21 MB) You must be logged in to download this attachment.
  • #2 16423127
    Alfred_92
    Help: 148
    Rate: 706
    I will ask out of curiosity if these veins were already so "soldered" or is it your work? :)
  • #3 16468197
    Daro122
    Help: 165
    Rate: 751
    My cable had one more fault, it also did not connect to the BMW E46, including the engine control unit and ABS. Until there was a car where I could check it, I was not sure of the effectiveness of the repair. So it works with Fords and BMWs now.
  • #4 17320339
    endurasek
    Rate: 17
    I wanted to ask if my colleague can have a set of wires, because my colleague is just repairing this cable and I cannot locate all the wires in the db26 plug, because someone poured hot glue on it. I mean the pin:
    db26 pin 6 plug -> it seems to be a green wire
    db26 pin 21 plug -> here it seems orange
    db26 plug pins 1, 9, 10, 19, 26 are connected together with black, gray, white-brown, white-gray, white-black.
  • #5 17320580
    Daro122
    Help: 165
    Rate: 751
    It's in the forum somewhere, if you need it please.
    • Belegung OBD2.pdf (152.2 KB) You must be logged in to download this attachment.
  • #6 17320599
    endurasek
    Rate: 17
    Thanks a lot, that's what I meant !!!
  • #7 17320939
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    And someone will repair the cable for Mega Macs 42, because I have one to repair?
  • #8 19832381
    moki1972
    I have such a problem with my gutmann 66 cable, I attach a photo, maybe someone will help me.
  • #9 19834402
    moki1972
    Cables repaired, loose.
    Repaired cables at an electrical connector. Connector with repaired wires on patterned background.
The discussion revolves around the repair of a damaged main cable for the Gutmann Mega Macs 50, specifically related to the Ford engine controller using the J1850 PWM protocol. The original issue was a burnt connection from pin 2 B+ to the overvoltage protection diodes, which was successfully repaired using a thin insulated wire. The author confirmed that the cable now functions correctly with both Ford and BMW vehicles. Other participants inquired about wiring details for the DB26 plug and expressed interest in repairs for similar cables, including the Mega Macs 42 and Gutmann 66 models.
