Drive for 300mm Wide Posts: Nice Wingo 2024 Compatibility with Double-Leaf Gate (2x2000mm)
kamo502 6546 9
Can a Nice Wingo 2024 linear actuator fit a double-leaf gate with 300 mm wide posts, or should I use another Nice model?
Wingo 2024 is only a standard 30 cm extension, so for 300 mm wide posts the safer choice is a model made for wide posts, such as Nice 3524 or the 5000 series [#16428468] The 3524 has an elongated body with a 40 cm extension, similar to the 5000, and is intended for wide posts [#16428468] The main difference is that 3524 is 24 V while 5000 is 230 V, so they need different control boards [#16428468] If you do not want or cannot cut/undercut the post, the advice was to avoid forcing Wingo 2024 and instead choose a 5000-series solution [#16428434] An arm-type system like HOPP/POP was also suggested for wide posts; it is easy to install and silent, but more expensive than linear actuators [#16428468]
  • #1 16428043
    kamo502
    Help: 24
    Rate: 140
    I need a drive for wide posts.
    Post 300mm. Gate mounted on the axis. 150mm from the hinge axis to the wall edge, 160mm in the second.
    Double-leaf gate (2 x 2000mm) Approx. 100 kg.
    The gate is made of horizontal profiles
    Nice Wingo 2024 exceeds dimensions?
  • #2 16428434
    Marek J.
    Help: 526
    Rate: 951
    Without undercutting the post - yes.
    If you don't want / can't cut and you want something similar and Nice, choose something from the 5000 series.
  • #3 16428442
    kamo502
    Help: 24
    Rate: 140
    Wingo 5000 will come out like Hoppe?
    Set 3524 similar dimensions as 2024?
    kotbury
    Gantry automation specialist
    Help: 2104
    Rate: 3639
    2024 has a standard extension of 30 cm, 3524 has an elongated body (extension 40 cm) similar to 5000 (suitable for wide posts), the difference between them - 3524 is for 24 V and 5000 for 230 V and thus - other switchboards.
    HOPP (and POP) is an arm frame, of course, it is for wide posts and it will cope with your gate (besides, it is very easy to install - you do not need any anchors, only ordinary wall plugs are enough, and it works completely silently) but the set is a bit more expensive than actuators linear.
  • #5 16433408
    kamo502
    Help: 24
    Rate: 140
    For dimension C 150mm and 160mm
    Opening angle 100-110 degrees
    Dimension B 215mm
    A dimension 130mm
  • #6 16441647
    kamo502
    Help: 24
    Rate: 140
    Someone will suggest
    Drive for 300mm Wide Posts: Nice Wingo 2024 Compatibility with Double-Leaf Gate (2x2000mm) Drive for 300mm Wide Posts: Nice Wingo 2024 Compatibility with Double-Leaf Gate (2x2000mm)
    Is this a table from 3524?
    Because I think I've seen another one recently.
    EDIT:
    I think it is correct because it is up to 5000 where the stroke is also 460mm
    So:
    For dimension C 160mm and an angle of about 100 °
    A and B 220mm?
  • #7 18070654
    mkania777
    Rate: 29
    I have a question. Regarding the protection of the main 230V electrical installation going to the NICE WINGO 2024 drive controller.
    The power cord is YKY 3x1.5mm2 with nap. 230V.
    The overcurrent circuit breaker with what characteristics can the installation be protected? B6A, B10A or B16A ???
    I want it as a single power switch on this line.
  • #8 18070688
    Marek J.
    Help: 526
    Rate: 951
    Even B3A is enough
  • #9 18070761
    mkania777
    Rate: 29
    Thank you very much!
    Added after 5 [hours] 10 [minutes]:
    Is it possible to lead a 2x1.5mm2 cable (instead of a 3-wire one) to the NICE WINGO 2024 controller? Theoretically, I do not have a third grounding wire. Will the kit work?
  • #10 18071501
    Marek J.
    Help: 526
    Rate: 951
    mkania777 wrote:
    Will the kit work?
    Yes. It will work, but since the manufacturer has provided for "grounding", it should be connected. This is probably due to the fact that in the event of a transformer failure, the mains voltage will be supplied to the actuators by the control panel. Although in this case the transformer is not toroidal and it seems to me that "grounding" the transformer core would be enough ...
The discussion revolves around the compatibility of the Nice Wingo 2024 drive with a double-leaf gate mounted on 300mm wide posts. Users confirm that the Wingo 2024 can be used without undercutting the posts, and alternatives from the 5000 series are suggested for those who prefer not to modify the posts. The Wingo 2024 has a standard extension of 30 cm, while the 3524 model offers a 40 cm extension and is designed for 24V systems, contrasting with the 5000 series which operates on 230V. Users also discuss the necessary electrical protection for the Wingo 2024 controller, suggesting various circuit breaker ratings and addressing grounding concerns when using a 2x1.5mm2 cable instead of a 3-wire cable.
