Technaxx Webcam TX-23: Issues Connecting to WiFi, LAN Cable Works Fine, WiFi Configuration
7er 12831 7
  • #1 16430368
    7er
    Hello. I bought a Technaxx webcam, model TX-23.
    The problem is when I want to view via wifi, the connection from the LAN cable works and the preview is ok, but when I want to configure it with wifi, it looks and searches and nothing.
  • #2 16430516
    jimasek
    Help: 3783
    Rate: 2682
    Do you configure via the browser? Should a list of wireless networks be available? There you choose your home network and enter the password that protects it.
  • #3 16430749
    7er
    I do configuration via the MySecure Technaxx app. Finds no signal. I think I'm doing something wrong ...
  • #4 16430759
    jimasek
    Help: 3783
    Rate: 2682
    Check the configuration via a web browser. Of course, cable connection to the camera during configuration.
  • #5 16431294
    7er
    That's what I did. Launching must be via cable and laptop. But ... I did everything and wifi works ... only where I count down from the electricity and mount it on the roof or actually under the roof, it does not work when connected to the electricity ... I have to buy 20m of this cable and connect it to the configuration and disconnect it otherwise there is no chance?
  • #6 16431308
    jimasek
    Help: 3783
    Rate: 2682
    The basic question is whether at this point you have coverage from the router that is probably somewhere in the apartment? Am I right?
  • #7 16431589
    kiko80
    Help: 67
    Rate: 164
    Use your phone to check the wifi range
  • #8 16431745
    7er
    Bravo gentlemen! wifi coverage causing the problem. I changed the place and the game but it could be better. I have to think about changing the router so that the range is greater and stronger.
The discussion revolves around connectivity issues with the Technaxx TX-23 webcam when attempting to configure it via WiFi. The user successfully connects through a LAN cable but encounters difficulties when trying to set up the WiFi connection using the MySecure Technaxx app. Responses suggest checking the configuration through a web browser and ensuring a stable WiFi signal from the router. The user later identifies that poor WiFi coverage is the root of the problem and considers relocating the router for better signal strength.
