Passat B6 2.0 2007: External Light Indicator & AFS Inoperative Issues with Bi-xenon Lamps
dawser00131 6648 3
  • #1 16439531
    dawser00131
    I have recently got the Passat B6 2.0. 2007
    I have a problem with the external light indicator. Once it blinks and once it lights up all the time.
    And also with the message "AFS inoperative! See owner's manual"
    If the car stops for 1 hour and I start without turning on the lights, the indicator does not come on.
    And after turning on and driving, the piece turns on again.
    I have bi-xenon lamps.
    I noticed a burned out light bulb, I replaced it, but the problem remained.
    After connecting the computer, the following errors popped up:
    Can someone please help or direct what may be the cause, where to look, etc.
    Best regards.
  • #2 16439580
    adam7009
    Help: 656
    Rate: 1631
    the complete headlamp must be replaced.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #3 16440099
    dawser00131
    Why is that ? after all, it is functional, not steamy, something more specifically what is broken in it?
  • #4 16440210
    adam7009
    Help: 656
    Rate: 1631
    there is a broken position sensor ....
