Changing Power Supply on HP Compaq 8200 Elite SFF: 12V 240W to 450W, Compatible Models & Plugs
5406 9
How can I replace the PSU in an HP Compaq 8200 Elite SFF with a higher-power unit, and what connector type do I need?
You can use a standard ATX power supply, but it must be connected to the HP motherboard through an adapter cable, because these HP SFF boards do not use a normal direct PSU plug [#16457953] For this kind of HP Pro SFF motherboard, the important part is the adapter from the ATX 24-pin output to the HP-specific connector, not a special 450 W HP model [#16457953] If your goal is to run a graphics card, the built-in PCIe slot is described as supplying only 25 W, so a card with its own external 6-pin power socket is the safer choice [#16458618] Even then, the small BTX/SFF case and card length/height limits can still be a problem, and some contributors warn that these office SFF systems are poor candidates for major upgrades [#16458618][#16458744]
  • #1 16457520
  • #2 16457949
    iron64
    Help: 648
    Rate: 313
    Maybe first write for what purpose you want to change this power supply? Besides how green are you, never plugged the PSU to the board, or are you just having trouble choosing the PSU?
  • #3 16457953
    zen3x
    Help: 231
    Rate: 291
    Any atx power supply available on the market can be used. It only needs to be plugged into such an adapter to power this series of hp computers.
    What does the adapter look like https://pl.aliexpress.com/item/Hot-24pin-to-6...upply-Cable-Cord-for-HP-Z220/32809296818.html
    How does such an adapter work https://www.youtube.com/watch?v=UED6CKd7iWk
    Schemes of such an adapter
    • hp.psu.zip (274.83 KB) You must be logged in to download this attachment.
  • #4 16457972
    r103
    Level 37  
    Help: 283
    Rate: 968
    The reason is given in the adjacent thread https://www.elektroda.pl/rtvforum/topic3337777.html
    that is the planned purchase of the GTX750ti card.
    Judging by the picture, the low-profile card with a low herring, even a two-slot card, should somehow get there / measure the max dimensions with a ruler and check /:
    But it is not possible not only the power supply, because its power is sufficient - as is the motherboard - see the manual http://h10032.www1.hp.com/ctg/Manual/c02778024
    table 2-1 - the load of the PCIEx socket is planned 25W, maybe it will go with the 55W card, but maybe what will burn ???
    In general, the issue of modernizing tiny SFF computers is a problematic matter :-)
  • #5 16458017
  • #6 16458313
    zen3x
    Help: 231
    Rate: 291
    It doesn't matter, the adapter powers each hp pro SFF series motherboard. Contrary to appearances, its construction is not complicated.
  • #7 16458427
  • #8 16458618
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Generally, these types of office computers are not suitable for major modernization. They were not intended for such use.
    There is I3 / i5 / i7 2gen in this hardware, so up to 95W. On the stubborn GTX750Ti it should be pulled by the current power supply, but since the slot is able to provide 25W, it would be appropriate to buy a card with an external power socket (6pin) and connect the power there.
    In general, there is still a question whether such a set in a small tight housing will not overheat a little at full load. These kits were not designed for long-term loads, and they are unlikely to occur in office work.
    If you have not bought this computer yet, I would consider a different approach, because buying an office sff with the hope of modernizing it for games is such a plan.
  • #9 16458701
  • #10 16458744
    dt1
    Help: 7315
    Rate: 8292
    The housing in this case matters quite a lot, because it is BTX and you cannot count on putting these guts into the standard housing.
    I have not seen any GTX750Ti in the Low Profile version and with an additional power socket (all I had in my hand did not have this socket).
    You have one more problem - looking at the drawing thrown in by my colleague r103, it looks like this card is not only low, it should not be too long.
    If I were you, I would return this computer and approach it correctly (think first, then buy, not the other way around). You will lose a lot on adapting this computer to your needs, and in addition you will be forced to make a few weak compromises (limitations in the availability of elements).
The discussion revolves around upgrading the power supply of an HP Compaq 8200 Elite Small Form Factor (SFF) computer from a 12V 240W unit to a 450W model to support a GTX750Ti graphics card. Users suggest that any ATX power supply can be used with an appropriate adapter to connect to the HP motherboard. Concerns are raised about the limitations of SFF computers for gaming upgrades, including potential overheating and space constraints. The original poster clarifies that they are willing to modify the housing to accommodate the new components. Recommendations include considering external power supplies for the graphics card and ensuring compatibility with the motherboard's power requirements.
