[Solved] HP Compaq 8200 Elite SFF: Low Profile Graphics Card for GTA 5 & The Witcher 3 Compatibility
sonqo 8985 12
Can I install a low-profile graphics card in an HP Compaq 8200 Elite SFF to play GTA 5 and The Witcher 3?
Yes — you need a low-profile PCIe x16 card, and in this SFF case the safest choice is a card that does not need extra power from the PSU [#16855421][#16855624] The thread recommends the GT 1030 Low Profile as the cheapest, no-modification option, but it is only good for some games and may need reduced resolution for Witcher 3 [#16855624][#16855804][#16861096] If you want better performance, low-profile GTX 1050 or GTX 1050 Ti cards also fit and are reported to run GTA V and even Witcher 3; one user says a GTX 1050 LP works flawlessly in an HP 8300 SFF with a 240 W PSU [#16861096][#16946268] A GTX 745 low-profile can fit too, but it draws more power and is slower than the GT 1030 [#16856157][#16856902] Also note that the GT 1030 suggestion assumes a monitor with digital input, not only VGA/DSUB [#16855804]
  • #1 16855381
    sonqo
    Hello, I bought a computer set (HP Compaq 8200 Elite SFF) without a graphics card, because I did not need it, I thought. I emailed the lady to the site where I had ordered the equipment but they were not very helpful. They just told me that I needed a graphics card, which would be in the name Low Profile, I don't know anything about it and I counted on some precise help. I will just add that I would like to play GTA 5 and The Witcher 3.
  • #3 16855451
    quinty
    Help: 111
    Rate: 158
    Yeah .. low profile is one thing, and the power supply is another problem.
    Not only does not any additional 4-6pin plug for graphic acts come out of the power supply, it also has only approx.
    240W from what I remember, so any sensible card will not work with this computer.
  • #4 16855493
    sonqo
    so do you propose to replace the power supply? won't it help too? So I have games from the browser; (
  • #6 16855624
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    The linked topic is a bit old.
    It was a mistake to buy an office computer in an SFF case and focus on games. Total shot in the foot. Now you will be rocking with rather low-performance cards, because you won't pack anything interesting with this equipment.
    People can put GT1030 into this equipment and you can consider such a card, there are LOW PROFILE versions of these cards. GT1030 does not consume much electricity and requires no additional power supply:
    https://www.youtube.com/watch?v=8NSocVEYPJE
    Proposed cards:
    https://www.ceneo.pl/51874782 (Gigabyte, DVI-D + HDMI, GPU: 1257/1506, MEM: 6008)
    https://www.ceneo.pl/51874812 (MSI, HDMI + DisplayPort, GPU: 1265/1518, MEM: 6008)
    Both are slightly tweaked, very slight differences in their timing have practically no effect on overall performance (differences below 1%).
    Since poverty could be combined with higher card models, you need to find out if the PCI-e slot has no limitations in terms of current efficiency (some SFF computers were not able to deliver 75W). Then you can think of some low profile version of the GTX1050.
  • #7 16855779
    sonqo
    Thank you very much for your help, the computer was supposed to be used in my office only for work but there is some free time so why not spend it on gaming. Best regards and thank you.
  • #8 16855804
    dt1
    Help: 7315
    Rate: 8292
    On the GT1030, you can run some games and even play them, although the game machine does not make it. On the plus side, the card is cheap and does not require power modification, so I think it should be just right. Just note that you need a monitor with digital input for such a card. If you only have a VGA / DSUB monitor, this is an additional problem.
  • Low-profile GT 1030 to GTX 1050 Ti options
    #11 16861096
    kangur88
    New low profile cards matching this HP are in turn from the least efficient (approximate prices)
    GT1030 (PLN 300) - GTX1050 (PLN 500) - GTX 1050TI (PLN 650)
    You can even play witmina 3 on them (although in the case of gt1030 in lower resolution than fullhd).
    Anything you can look for in the network will work, the power supply will not be a limitation.
    The board, as you can see, can provide 75W because the cards work, and those given in the 25W specification or in other 50W models, are often because manufacturers in factory configurations did not install stronger ones, and the specifications given in the documents are more suitable for ordering new configurations and sometimes they do not correspond to reality.
    I have a Dell 7010 SFF myself with a GTX 1050 LP. How do you feel like reading his review is on the blogs of good programs (I am not able to include a link).
  • #12 16946268
    keisha1982
    It is correct. Personally, I installed the GeForce GTX 1050 Low Profile in the HP 8300 SFF computer and with a 240w power supply. It's flawless, games like GTA V or Beatllefield 1 work even at full details without clipping.
  • #13 17394249
    sonqo
    I bought a 1050 TI low profile, but my monitor started to dim.
    problem solved best regards
The discussion revolves around selecting a low-profile graphics card for the HP Compaq 8200 Elite SFF to enable gaming for titles like GTA 5 and The Witcher 3. Users highlight the importance of the PCIe x16 slot and the limitations of the 240W power supply. Recommended graphics cards include the GT1030, which is low power and does not require additional power connectors, and the GTX 1050 and GTX 1050 TI, which can also fit but may require careful consideration of power supply capabilities. Users share experiences with these cards, noting that the GTX 1050 performs well even at high settings for demanding games. Compatibility with monitors is also discussed, emphasizing the need for digital inputs for certain cards.
TL;DR: For HP Compaq 8200 Elite SFF, use a Low Profile PCIe x16 GPU; the 240W PSU and no 6‑pin limit choices. “GT1030 does not consume much electricity and requires no additional power supply.” One slot delivers up to 75W. [Elektroda, dt1, post #16855624]
Why it matters: This helps you pick a plug‑and‑play low‑profile card that actually runs GTA V or The Witcher 3 on an office SFF PC.
Quick‑Facts:
What low‑profile GPU actually fits the HP Compaq 8200 Elite SFF?
Choose a Low Profile (short bracket) graphics card that uses the motherboard’s PCIe x16 slot. This physical format and interface ensure clearance in the SFF chassis and compatibility with the board. Look for retail boxes that include the low‑profile bracket. [Elektroda, Anonymous, post #16855421]
Do I need to replace the 240W power supply to add a GPU?
No, for cards that draw power only from the slot. The stock ~240W PSU has no 4/6‑pin GPU connectors, so pick a card that does not need auxiliary power. This keeps installation simple and avoids adapters. [Elektroda, quinty, post #16855451]
Which specific low‑profile cards are recommended for light gaming?
Users report success with GT 1030 LP and GTX 1050/1050 Ti LP. These options run from the slot and fit the case. GT 1030 works without extra power and suits eSports or reduced settings. GTX 1050/1050 Ti LP provide clearly higher frame rates. [Elektroda, kangur88, post #16861096]
Will GTA V or The Witcher 3 run on this SFF build?
Yes. One user ran GTA V at full details on a sibling 8300 SFF with a GTX 1050 LP and 240W PSU. Another noted The Witcher 3 is playable on a GT 1030 at sub‑1080p resolution. Expect to tune settings for stability. [Elektroda, keisha1982, post #16946268]
Is the PCIe slot limited below 75W on this platform?
Community experience indicates the board can supply the standard 75W. Users run GTX 1050/1050 Ti Low Profile models, which rely on slot power only, without PSU mods. This confirms adequate current delivery for these GPUs. [Elektroda, kangur88, post #16861096]
Is a GTX 745 Low Profile a good budget option?
It can work, but it’s slower than a GT 1030 despite drawing about 55W. The appeal is low cost, not performance. If you care about modern game playability, the GT 1030 LP remains the faster, more efficient choice. [Elektroda, dt1, post #16856902]
What does “Low Profile” actually mean for graphics cards?
Low Profile describes a shorter PCB and bracket height that fits small‑form‑factor cases. Your 8200 SFF requires this size and a PCIe x16 interface. Buy a card that ships with the LP bracket or includes one in the box. [Elektroda, Anonymous, post #16855421]
Will the stock power supply’s missing 6‑pin connector be a problem?
Not if you choose a card that runs entirely from the slot. The PSU lacks additional GPU power leads. Avoid GPUs that require 6‑pin connectors. This prevents unstable power and keeps installation straightforward. [Elektroda, quinty, post #16855451]
How do I install a Low Profile GPU in the 8200 SFF?
  1. Swap to the included low‑profile bracket and seat the card into the PCIe x16 slot.
  2. Secure the bracket, then connect your monitor to the card’s digital output.
  3. Boot, install drivers, and set the GPU as the primary display in settings. “GT1030 does not consume much electricity and requires no additional power supply.” [Elektroda, dt1, post #16855624]
My screen dims or flickers after installing a 1050 Ti LP—what happened?
A user reported display dimming after moving to a 1050 Ti LP, then resolved it. Causes include cable, adapter, or monitor compatibility. Use the GPU’s digital port (HDMI/DP/DVI‑D) and a quality cable. Avoid VGA adapters when possible. [Elektroda, sonqo, post #17394249]
Do I need a digital‑input monitor for these cards?
Yes, plan on HDMI, DisplayPort, or DVI‑D. One expert noted that if your monitor is VGA‑only, you face extra hurdles. Budget for an appropriate monitor or an active converter to avoid signal issues. [Elektroda, dt1, post #16855804]
Can a GT 1030 really handle modern titles at all?
It runs lighter games and older AAA titles with reduced settings. “You can run some games and even play them,” but it’s not a full gaming rig. Expect 720p–900p and medium‑low settings for smoother results. [Elektroda, dt1, post #16855804]
Is upgrading the PSU the only way to get better performance?
Not necessarily. The community confirmed slot‑powered GTX 1050/1050 Ti LP cards work in similar SFF systems. These provide a substantial uplift without replacing the 240W PSU. Keep thermals in check with clean airflow. [Elektroda, kangur88, post #16861096]
What is PCIe x16, in simple terms?
PCIe x16 is the primary graphics expansion slot on modern desktops. It offers the electrical lanes and bandwidth for GPUs. Your 8200 SFF board exposes a PCIe x16 slot compatible with low‑profile graphics cards. [Elektroda, Anonymous, post #16855421]
Any edge cases I should watch for with these SFF upgrades?
Yes. Avoid GPUs that require 6‑pin power, confirm clearance for dual‑slot coolers, and ensure digital monitor connections. A reported failure symptom was screen dimming after a 1050 Ti LP upgrade, later resolved by the user. [Elektroda, sonqo, post #17394249]
What’s a realistic performance step from GT 1030 to GTX 1050 Ti LP?
Expect a clear uplift moving to GTX 1050 Ti LP within the 75W slot power limit. Community members list 1050 Ti LP among viable choices for this SFF class, enabling higher details and resolutions than GT 1030. [Elektroda, kangur88, post #16861096]
