HP Compaq 8200 Elite SSF: Can 240W PSU Handle Geforce GT730 2GB Card?
mate7 10041 12
Can an HP Compaq 8200 Elite SSF with a 240 W power supply run a GeForce GT 730 2 GB graphics card?
Yes, a 240 W PSU is enough for a GT730 as long as the card does not need a 6- or 8-pin auxiliary power connector; cards that do need extra power may require around 400 W or more [#16688200][#16688280] The thread also says GT730 is generally a poor buy and recommends a GT1030 instead, which is about three times faster and draws only about 35 W [#16688280] For a GT1030, make sure your monitor has a digital input such as HDMI, DVI, or DP [#16688280][#16688346] The GT1030 low-profile versions mentioned in the thread come with DVI and/or the low-profile bracket, which fits small-form-factor systems better [#16688346] There is a small chance a given card may not start in this machine, so buying from a seller with an easy return policy was advised [#16688372]
  • #1 16688174
    mate7
    Hello. I have an HP Compaq 8200 Elite SSF computer and I would like to buy a graphics card for it, unfortunately my PC has a 240 W power supply and my question is whether it can handle a 2 GB GT730 card.
    CPU Intel Core i5 (2nd Gen) 2400 / 3.1 GHz
    Max Turbo Speed 3.4 GHz
    Number of Cores Quad-Core
    8 GB RAM HP Compaq 8200 Elite SSF: Can 240W PSU Handle Geforce GT730 2GB Card?
  • #2 16688200
    qs300
    Help: 242
    Rate: 362
    It depends, if the card requires additional power supply (6 or 8 pin connector), then this power supply may not be able to do it, such cards require a power supply min. 400Watt.
  • #4 16688267
    Kasek21
    Help: 4981
    Rate: 3547
    The power supply is only worse with compatibility with the motherboard!
    If the card is to be bought for games, this is not a good choice!
  • #5 16688280
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Poor cards, generally GT730 is unprofitable. At a similar price you can buy the GT1030, and this one has slightly lower performance than the GTX750Ti (it is three times faster than the GT730) and gets a modest 35W. Except that for GT1030 it would be good to have a monitor with digital input (HDMI, DP, DVI).
    For GT730 (and GT1030) 240W power supply is enough.
    Seriously? Cards requiring about 100W already require 6 pin power. The new generation quad-core processor needs 65W. Here we have an old generation, so let's count 100W. Even adding 50W of supply, 250W is required, not 400W (and even less with the new generation). The power supply requirements are based on the power demand of the individual components, not on the presence of a power outlet.
  • #6 16688284
    mate7
    So what can I do about this problem? When it comes to games, I have WoT installed and I play on minimal settings. I just wanted to fix it with this card.
  • #7 16688293
    dt1
    Help: 7315
    Rate: 8292
    I found a video in which the guy installed the GTX1050, so with compatibility it may not be that bad, at least with the nv cards: https://www.youtube.com/watch?v=PKIxgtztoGk - although with the GT1030 I did not manage such a set found.
    What is your monitor model? If it has DVI / HDMI / DP then you can buy GT1030 (from some reasonable store, where you can do a refund without any problems).
  • #8 16688317
    mate7
    Monitor to BenQ G2010W.
  • #9 16688346
    dt1
    Help: 7315
    Rate: 8292
    I have bought DVI-D, i.e. GT1030 in a low profile version, for example:
    http://www.zadowolenie.pl/podzespoly-komputer...-1030-2gb-gddr5-64bit-hdmi-dvi-hdcp-lite-pack (free shipping) or https: // www.morele.net/karta-graficzna-zotac-gt-1030-lp-2gb-gddr5-64-bit-dvi-d-hdmi-box-zt-p10300a-10l-1293090/
    The ZOTAC card has DVI and has a low profile bracket included (according to information on the manufacturer's website).
    For this DVI-DVI cable.
    Or a version with a slightly faster clocking (overclocked) - minimal, but it will always be a bit faster: https://www.morele.net/karta-graficzna-gigabyte-geforce-gt-1030-2gb-gddr5-64-bit-dvi- d-hdmi-box-gv-n1030d5-2gl-1256983 / or https://www.komputronik.pl/product/388512/gigabyte-geforce-gt-1030-2g.html or http://www.zadowolenie.pl / computer-components / graphics-cards / gigabyte-geforce-gt-1030-2gb-gddr5-64bit-pci-e-hdmi-dvi (free shipping) and the same DVI-DVI cable to the monitor if you don't have one. This card also has a low profile herring included.
  • #10 16688356
    mate7
    This is all known. I will choose one of those that you recommended to me. Thank you very much for this information and help because I couldn't do it myself.
    Best regards and thank you again.
  • #11 16688372
    dt1
    Help: 7315
    Rate: 8292
    There is a small chance that such a card will not move, so buy online, open it without destroying the packaging too much and use the return if necessary. But 80% should start, since 1050 can be started.
  • #12 16688855
    qs300
    Help: 242
    Rate: 362
    It is not about the fact that the card itself needs so much power, but the manufacturer calculates that since the card itself consumes 100 or more Watt and added other components to it, it stated that a power supply of at least 400W or more should be used. I have access to various electronic wholesalers, in which I buy goods for the store and such information is provided in the graphics card specifications, in online stores there is no such information.
  • #13 16689342
    dt1
    Help: 7315
    Rate: 8292
    I know the manufacturer estimates that. However, there is nothing to take into account of this nonsense. The card manufacturer has no information about the equipment in which the card will work (so apart from the power supply load generated by the card, there is no knowledge about the load on the rest of the components). The card manufacturer also does not know whether it will be a lofty power supply, which under the 500W sticker has a performance of 280W at 12V, of which at 200W the power supply burns, or is it a decent 500W power supply with 480W real capacity on the 12V line.
    So, most often the value estimated by the graphics manufacturer is greatly exaggerated - and it's worth counting the power supply performance you need instead, instead of suggesting nonsense data of this type.
The discussion revolves around the compatibility of a 240W power supply unit (PSU) in the HP Compaq 8200 Elite SSF with a GeForce GT730 2GB graphics card. Users express concerns about the power requirements, noting that cards needing additional power connectors typically require a minimum of 400W. However, it is suggested that the GT730 can operate within the 240W limit, especially since it does not require additional power connectors. Alternatives like the GT1030 are recommended for better performance and lower power consumption (35W). Users also discuss the importance of monitor compatibility, particularly with digital inputs for the GT1030. The conversation highlights the need for careful consideration of PSU specifications and the potential for using higher-performance cards like the GTX1050, albeit with caution regarding power supply limitations.
TL;DR: Yes—HP Compaq 8200 Elite SFF with a 240W PSU can run GT730 or, better, GT1030. GT1030 draws 35W and is ~3× faster than GT730; power needs are “based on the power demand of the individual components.” [Elektroda, dt1, post #16688280]
Why it matters: This helps small‑form‑factor owners choose a safe, worthwhile GPU upgrade without replacing the proprietary PSU.
Will a 240W PSU in the HP Compaq 8200 Elite SFF run a GeForce GT730 2GB?
Yes. Users report the 240W OEM unit is enough for GT730. However, the GT730 offers poor value. A GT1030 performs far better within the same power envelope. Consider GT1030 for a noticeable uplift at similar cost and lower power. [Elektroda, dt1, post #16688280]
Is a GT1030 a better upgrade than a GT730 for light games like World of Tanks?
Yes. The GT1030 is about three times faster than the GT730 and uses roughly 35W. It fits small‑form‑factor needs and keeps power demands low. For best results, pair it with a monitor using DVI, HDMI, or DisplayPort. [Elektroda, dt1, post #16688280]
Do I need a 6‑pin or 8‑pin power connector for these cards?
Most GT730 and GT1030 low‑profile models do not need extra power connectors. Cards that require 6‑pin or 8‑pin inputs often list a 400W minimum PSU, which the 240W OEM unit may not satisfy. [Elektroda, qs300, post #16688200]
What display connection should I use with a GT1030 in this PC?
Use digital video. Choose a low‑profile GT1030 that includes DVI‑D, then connect with a DVI‑D to DVI‑D cable. Models from ZOTAC or Gigabyte often include a low‑profile bracket, simplifying the fit in SFF cases. [Elektroda, dt1, post #16688346]
Are there BIOS or compatibility issues with the 8200 Elite SFF and newer GPUs?
Compatibility is generally good. A similar system has run a GTX1050, and low‑power cards like GT1030 usually work. There’s a small chance a card won’t POST; buying online helps you leverage return policies. Expect roughly 80% success. [Elektroda, dt1, post #16688372]
How should I estimate if my power supply is enough without trusting box labels?
Add up component draws. Example: i5‑2400 ~100W, GT1030 ~35W, rest ~50W. That totals ~185W, which is under 240W. As one expert notes, requirements are based on component demand, not marketing labels. “Count the components.” [Elektroda, dt1, post #16689342]
Can I swap the HP 8200 SFF power supply for a bigger one?
It’s difficult. The SFF design and motherboard connections limit aftermarket options. Users report PSU replacement is more about proprietary compatibility than raw wattage. Plan upgrades around the stock 240W unit instead. [Elektroda, Kasek21, post #16688267]
Which low‑profile GT1030 models fit the 8200 Elite SFF best?
Look for low‑profile (LP) cards that include the LP bracket and DVI‑D output. Examples noted include ZOTAC and Gigabyte GT1030 LP variants. Pair with a DVI‑D cable for straightforward setup. [Elektroda, dt1, post #16688346]
My monitor is VGA‑only. Will a GT1030 still work?
GT1030 cards typically drop VGA. Use a monitor with DVI/HDMI/DP, or an active VGA converter. The thread advice favors using digital outputs for a clean, compatible signal path. [Elektroda, dt1, post #16688280]
Should I trust GPU vendor “minimum 400W PSU” recommendations?
Treat them as broad, often inflated guidelines. Vendors don’t know your exact components or PSU quality. Calculate your real load and margin instead of relying on sticker wattage alone. [Elektroda, dt1, post #16689342]
What’s a safe power budget for i5‑2400 plus GT1030 on the 240W PSU?
Approximate total is ~185W under load: CPU ~100W, GPU ~35W, and ~50W for the rest. That leaves headroom within 240W for this platform. Keep the card low‑power and avoid extra connectors. [Elektroda, dt1, post #16688280]
How do I install a low‑profile GT1030 in the 8200 Elite SFF?
  1. Choose an LP GT1030 that includes the low‑profile bracket and DVI‑D port.
  2. Swap the bracket if needed, insert the card, and secure it.
  3. Connect a DVI‑D cable to the monitor, then install drivers and test. [Elektroda, dt1, post #16688346]
What’s the risk the new GPU won’t start, and what should I do?
There’s a small failure risk where the card won’t POST. Buy from an online retailer offering easy returns. Open the box carefully so you can return it if needed. Reported success is about 80%. [Elektroda, dt1, post #16688372]
Is the GT730 ever worth buying for this system?
Not recommended. The GT730 is considered poor value compared to the GT1030. At similar prices, GT1030 offers much higher performance and lower power. Choose GT1030 unless a specific legacy need demands the GT730. [Elektroda, dt1, post #16688280]
