Maximizing UPC Horizon Wi-Fi Download Speed with Fiber Power 60 Mbps & uTorrent Settings
sahajdak 4482 10
  • #1 16458346
    sahajdak
    Hello everyone,
    I recently switched to internet (Fiber power 60 Mb / s) and TV with UPC. I got a Horizon set-top box that also functions as a router. I have a problem downloading uTorrent via wi-fi. My maximum speed is 1.1-1.2 MB / s. The situation changes when the computer is connected to the Horizon via a cable - the speed jumps to 7-10 MB / s depending on the seeds. I know that the speed on the cable will always be higher than on wi-fi, but it seems to me that maybe there is some limitation on the part of Horizon on Wi-Fi download? Possibly something in uTorrent settings need to change? The situation is strange, because when I start a new download, the speed spins to the aforementioned 1.2 MB / s max, then drops to e.g. 800 kB / s and increases again to 1.2 and so on.
    Maybe it's a port problem? I don't have a green arrow in uTorrent, but when it comes to ports, I'm completely green.
    What could be the reason for this? Someone help? :)
    best regards
    sahajdak
  • #2 16458415
    bogiebog
    Help: 2569
    Rate: 1528
    Scan the WIFI network with inssider 2.x, show the results.
  • #3 16458601
    sahajdak
    Below are the results of the program:
    Maximizing UPC Horizon Wi-Fi Download Speed with Fiber Power 60 Mbps & uTorrent Settings Maximizing UPC Horizon Wi-Fi Download Speed with Fiber Power 60 Mbps & uTorrent Settings
    PS. Units corrected, I hope fine :)
  • #4 16458607
    bogiebog
    Help: 2569
    Rate: 1528
    Show all networks, do not uncheck _Nothing_.
  • #5 16458690
    sahajdak
    this is what it looks like:
  • #6 16458822
    bogiebog
    Help: 2569
    Rate: 1528
    A piston in ether is confirmed by measurements.
    Maybe 5ghz is better, it should be checked with a computer with a 5ghz card.
  • #7 16458848
    sahajdak
    then why previously Vectra flashed differently, ie faster?
    Can you explain it to me somehow, but at the same time blatantly? :)
  • #8 16458875
    bogiebog
    Help: 2569
    Rate: 1528
    Same computer?
    Maybe you had 5ghz WIFI?
    What model of WIFI card do you have?
    > faster
    does 1.5mbs mean instead of 1.2?
  • #9 16458893
    sahajdak
    bogiebog wrote:
    Same computer?
    > faster
    the same computer
    network card - Qualcomm Atheros AR9285 Wireless Network Adapter
    faster, i.e. 3-4 MB / s
    bogiebog
    Help: 2569
    Rate: 1528
    There had to be fewer other networks.
    Try to force a different WIFI channel in the router, e.g. 1, and then try another.
  • #11 16458931
    sahajdak
    I changed the channel and the speed increased to 2MB / s :)
    I will play with it a little longer and look for the optimal one.
    I wonder what Vectra worked on.
    thank you so much for help ;)
    health
✨ The discussion revolves around optimizing Wi-Fi download speeds for uTorrent while using a UPC Horizon set-top box/router with a Fiber Power 60 Mbps internet connection. The user experiences significantly lower download speeds (1.1-1.2 MB/s) over Wi-Fi compared to wired connections (7-10 MB/s). Suggestions include scanning the Wi-Fi network for interference, changing the router's Wi-Fi channel, and considering the use of a 5 GHz band for better performance. The user reports an improvement to 2 MB/s after changing the channel and is encouraged to continue experimenting for optimal settings.
