Optimizing Cyfrowy Polsat Antenna Positioning with QUAD Satellite Converter & TV INVERTO 0.2dB
szymon189 31797 16
How should I set my satellite dish for Cyfrowy Polsat, and which channel or signal screen should I use to check the signal?
Set the dish on Hotbird and check the signal on the receiver’s signal parameters, not on one special channel; if you use a Cyfrowy Polsat box, Polsat HD, TVP1 HD, TVN HD and BBC Brit are suggested test channels. [#16909526][#16909529] The minimum MER is about 13 dB, but a better target is 14–15 dB with quality around 80–100%. [#16909526][#16909556][#16909751] Quality below 50–60% is only a minimum; the proper result is 80% or more. [#16909529][#16909556] If TVP Sport HD or other channels freeze, the antenna is still likely misaligned, and on a 90 cm dish you should normally see near 100% quality on most channels. [#17889281][#17889359] Use a real satellite meter and the TV/receiver signal menu to align it properly; a cheap DVB-T finder is for terrestrial TV, not satellite, and the receiver can show all parameters from the red-button menu. [#17898482][#16909751][#16911026]
  • #1 16909520
    szymon189
    Rate: 90
    I have such a QUAD satellite converter with TV INVERTO signal adder 0,2dB /
    Sometimes I have problems with watching some programs on Polsat. How should the antenna be set? On which channel to check the signal?
  • #2 16909526
  • #3 16909529
    Krzychu7
    Level 40  
    Help: 695
    Rate: 530
    If you have a set-top box for Cyfrowy Polsat, check it out on Polsat HD, TVP1HD, TVN HD and BBC Brit.
    The quality must be at least 50 ÷ 60%.
  • #4 16909536
    szymon189
    Rate: 90
    mihal2002 wrote:
    The meter is checked.
    What meter do you recommend?
    Krzychu7 wrote:
    Polsat HD
  • #5 16909556
  • #6 16909565
    szymon189
    Rate: 90
    So probably a badly set antenna?
  • #7 16909597
  • #8 16909601
    szymon189
    Rate: 90
    Alone anetna? Bowl?
    So what meter to buy?
  • #9 16909623
  • #10 16909637
    szymon189
    Rate: 90
    mihal2002 wrote:
    szymon189 wrote:
    Alone anetna? Bowl?
    Yes. And you gave what you have.
    I have 90.
    mihal2002 wrote:
    And it pays to spend a minimum of PLN 700.
    I thought it was about something like. TZU 22 signal meter DVB-T Finder Code of goods: R10122. And this is supposed to be something similar? Schwaiger SF9002 signal indicator with satellite identification, built-in battery
  • #11 16909685
  • #12 16909751
    _kli_
    Help: 755
    Rate: 1031
    This is a pointer for setting terrestrial TV!
    szymon189 wrote:
    I have 90
    With a cloudless sky on most frequencies you should have MER 14-15 dB (80-100% quality).
    https://youtu.be/CWuRGXpqzH8?t=183
  • #13 16911026
    LeDy
    Help: 1984
    Rate: 2916
    A little. Hold the red button on the remote control and then you have all the parameters.
  • #14 17889203
    szymon189
    Rate: 90
    I'm renewing the topic. Recently, when I watched TVP Sport HD, it suspended the picture.
    Optimizing Cyfrowy Polsat Antenna Positioning with QUAD Satellite Converter & TV INVERTO 0.2dB Optimizing Cyfrowy Polsat Antenna Positioning with QUAD Satellite Converter & TV INVERTO 0.2dB
  • #15 17889281
    andpol 33
    Help: 507
    Rate: 1137
    The antenna is still wrong. On a 90 cm antenna should be 100% quality on most channels.
  • #16 17889359
    LeDy
    Help: 1984
    Rate: 2916
    The strength should be ? 80 and similarly the quality, i.e. closer to 100%. Farther still. MER at least 12 is still something wrong.
  • #17 17898482
    markostka
    Rate: 57
    Using the meter for these few zlotys, you must ... be able to.
    Be able to use it, for example, to know if we will definitely find a satellite.
    It is simpler to use the menu with tv, using the method of trial and error.
✨ The discussion revolves around optimizing the positioning of a Cyfrowy Polsat antenna equipped with a QUAD satellite converter and a TV INVERTO 0.2dB signal adder. Users suggest checking signal quality on channels such as Polsat HD, TVP1HD, TVN HD, and BBC Brit, aiming for a minimum quality of 50-60%, ideally 80% or higher. Recommendations include using a signal meter for accurate antenna alignment, with suggestions for specific models like the TZU 22 and Schwaiger SF9002. Users emphasize the importance of proper antenna setup, noting that a 90 cm antenna should achieve close to 100% quality on most channels. Issues with signal strength and quality are attributed to potential misalignment or inadequate equipment.
TL;DR: For Cyfrowy Polsat on Hot Bird, target MER ≥13 dB and 80–100% quality; “MER is to be at 13 min.” [Elektroda, 1098678, post #16909526] Why it matters: This FAQ helps Polsat users fix pixelation/freezes by dialing in dish, LNB, and meter settings.
Which satellite should I point the antenna at for Cyfrowy Polsat?
Point the dish at Hot Bird to receive Cyfrowy Polsat services. Align azimuth and elevation for Hot Bird, then fine‑tune skew. Use a meter or your decoder’s signal screen while adjusting. This ensures consistent lock across Polsat transponders. [Elektroda, 1098678, post #16909526]
What signal levels are considered good for stable HD viewing?
Aim for MER at least 13 dB and quality in the 80–100% range. In clear weather, many frequencies show about 14–15 dB MER. Higher MER and quality reduce errors and prevent freezes. Treat strength as secondary to quality. [Elektroda, kli, post #16909751]
Which channels should I use to check alignment on a Polsat set‑top box?
Use Polsat HD, TVP1 HD, TVN HD, and BBC Brit to verify quality. These services let you confirm stability across different transponders. Watch for steady quality without swings. If quality dips below mid‑range, refine alignment. [Elektroda, Krzychu7, post #16909529]
My 90 cm dish isn’t hitting 100% quality—what does that indicate?
It indicates misalignment or installation issues. A 90 cm dish should deliver 100% quality on most channels when set correctly. “On a 90 cm antenna should be 100% quality on most channels.” Re‑aim and fine‑tune the LNB skew. [Elektroda, andpol 33, post #17889281]
Is 50–60% quality enough to watch?
It works as a minimum, but expect occasional glitches. Use it only to get a picture, then keep optimizing. For stable HD, push quality higher and confirm MER is comfortably above the threshold. [Elektroda, Krzychu7, post #16909529]
Do I really need a satellite meter, and what should I spend?
A meter makes precise alignment faster and more reliable. Budget at least PLN 700 for a worthwhile unit. Cheaper tools can help, but they trade accuracy and features. Consider it an investment in stability. [Elektroda, 1098678, post #16909623]
Can I align without a pro meter?
Yes. Use the decoder’s signal menu and a slow, methodical approach. Move the dish in tiny steps and pause for readings. This trial‑and‑error method works if you stay patient and precise. [Elektroda, markostka, post #17898482]
Is a DVB‑T meter like TZU 22 suitable for satellite alignment?
No. That pointer is for terrestrial TV, not satellite. Use a satellite‑capable meter or your decoder’s signal screen. Mixing tools causes misreads and wasted time. [Elektroda, kli, post #16909751]
How do I view detailed signal parameters on a Cyfrowy Polsat decoder?
Hold the red button on the remote to display full signal parameters. Use that screen while adjusting the dish and LNB. It provides immediate feedback on quality. [Elektroda, LeDy, post #16911026]
TVP Sport HD freezes while others work—what should I check?
Check MER and quality. Borderline MER around 12 dB and mid strength often means errors and freezes. Raise quality toward 100% by refining aim and skew. Confirm stability on multiple HD channels. [Elektroda, LeDy, post #17889359]
Does dish size matter for headroom in poor weather?
Yes. A well‑aligned 90 cm dish offers strong quality and margin. If quality isn’t near 100%, alignment or hardware needs attention, not just size. [Elektroda, andpol 33, post #17889281]
Is my QUAD LNB okay for Cyfrowy Polsat?
Yes. Users successfully operate a QUAD converter with Polsat; alignment and quality are the main issues. Focus on Hot Bird pointing, LNB skew, and cable integrity. [Elektroda, szymon189, post #16909520]
Could the dish or hardware itself be the problem?
Yes. The antenna’s condition and build affect achievable quality. If alignment seems right but readings stay low, inspect dish shape, mount rigidity, and LNB seating. Replace damaged parts. [Elektroda, 1098678, post #16909597]
Are low‑cost sat finders like Schwaiger SF9002 usable?
They can help, but expectations vary. Installers use what they bought and report mixed results. If precision matters, a mid‑range meter is the safer choice. [Elektroda, 1098678, post #16909685]
What quick 3‑step method should I follow to fine‑tune alignment?
  1. Lock onto Hot Bird, then tighten bolts lightly.
  2. Nudge azimuth/elevation in tiny steps, maximizing quality and MER.
  3. Rotate LNB a few degrees each way to peak quality, then fully tighten. [Elektroda, 1098678, post #16909526]
