ESP8266 LUA: Is it possible to operate server and client simultaneously?
panbosman 2781 3
  • #1 16481240
    panbosman
    I am setting up a mixed mode of operation:
    Code: Lua
    I start the server:
    Code: Lua
    Server operation
    server:
    Code: Lua
    Now I have a question. Can I add client support to this configuration:
    Code: Lua
  • #2 16491726
    Piotrek_I
    There are not many examples on the web for the ESP8266 in LUA, which is a shame. I'm struggling with similarly simple things myself because the documentation is there, but the examples are extremely laconically written. But it's nice that someone is trying to do something in lua, because using Arduino or Raspberry for ESP8266 is often too much.
    Your code doesn't work for me, but I have an ESP that works both as an http server (switching on relays) and also connects to other ESPs by downloading the temperature (actually a page with the temperature written on it) from them (from the http server). The download is done via tmr.alarm .
    The readout is something like this:
    Code: Lua
    This is not my code, I even downloaded it from I don't know where but it was the output code for what I carved;)
    EDIT:
    Or this code:
    Code: Lua
    from here: Link
  • #3 16492256
    henryxxl
    Help: 32
    Rate: 104
    How do you gentlemen rate Lua against the arduino ide? I personally am not too fond of arduino.
  • #4 16492546
    Piotrek_I
    I use the Arduino IDE often for AVRs and for some small projects it is ok, but for ESP/LUA the ESPlorer is without comparison better.
