MZ ETZ 250: CDI Ignition Installation Dimensions, Components & Stator Stand Info
abuhamza 10326 13
How do I adapt a CDI ignition to fit an MZ ETZ 250, and what dimensions or extra parts are needed for the flywheel, stator stand, and trigger setup?
No exact dimensions were given in the thread; the main advice was that if you want to fit the CDI you already have, you must measure the motorcycle and design the spacer/stand yourself [#16489309] Several replies also warned that a scooter-style CDI may be a poor choice for the ETZ 250 because it can reduce charging power and make the lighting worse; one suggestion was to use a dedicated electronic ignition made for this model instead [#16489309][#16490639] If you want a cleaner conversion, alternatives mentioned were LFK, Ducati Energy, MVT Millennium, or VAPE, and one reply noted that the ETZ’s stock ignition/charging can already work well when the charging and bearings are correct [#16489340][#16490666]
  • Request for ETZ 250 CDI mounting dimensions
    #1 16489127
    abuhamza
    Home appliances specialist
    Help: 384
    Rate: 1034
    Does anyone of you have the dimensions, what exactly needs to be added to the ignition to fit the ETZ 250? I have the ignition
    I have a module, regulator, coil, I know how to connect it, but does anyone have any specific dimensions? I know that something needs to be added to the magnet so that it comes out higher and the stand for the stator.
    Regards
  • #2 16489174
  • #3 16489202
    jack63
    Help: 851
    Rate: 2825
    And what fungus do you want to change the ignition to CDI when ETZ has about 200W alternator ???
    I would sooner go in a TCI with a variable advance angle.
    Strange...
  • #4 16489254
    abuhamza
    Help: 384
    Rate: 1034
    After that, he wants to have a normal ignition and not the DDRowski prototype of 87. He wants stable lights and does not want to set these flaps, besides, he wants to burn without a battery and throw this unreliable ignition. I wrote to you for help and you continue to direct me to the starting point.
  • #5 16489309
  • #6 16489340
    TheGolibroda
    Rate: 14
    I don't know if it's worth assembling something like this. Rather, I would think of lfk, ducati energy or mvt millennium. If you want to pack it, only the base should run in or / and the song in the magnet may be too small.
  • #7 16489366
    jack63
    Help: 851
    Rate: 2825
    He replaced his uncle with a hatchet on a stick ...
    So 200W alternator for ... Approx 60 W
    ETZ with a vibration regulator could be fired even without electronic ignition. The latter is not a prototype but a decent TCI.
  • #8 16490633
    abuhamza
    Help: 384
    Rate: 1034
    There is a membrane and a welder in the plan and I think that such ignition would improve performance even if it has a larger range of rotation and has a lighter flywheel. They are the same ignition on olx but they have something extra for the magnet and a different stand for the stator and the pulse generator, I thought that someone would have and provided wider pictures dimensions ...
  • #9 16490639
    BANANvanDYK
    Help: 1169
    Rate: 2611
    Ignition from old scooters Yamaha 50 2T. Basically the same as the currently used copies of this ignition in the Chinese 2T, known as "CDI ignition" which people sell matching everything, even diesel.
    The efficiency of this ignition is a good argument. The Yamaha alternator has a maximum output of 90W, but separated into alternating current and direct current. In practice, the use of H4 on this ignition in ETZ will not be pleasant.
    A better idea is an alternator with a three-phase winding + AC-CDI, only with this will be a greater problem with availability and price.
  • #10 16490644
    abuhamza
    Help: 384
    Rate: 1034
    Well, it could be used winding from rs 125 rotax 123, external pulse generator, magneto in such a set definitely stronger coil than in 50.
  • #11 16490666
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6433
    abuhamza wrote:
    I want stable lights and I don't want to keep setting these plates
    Ignition is not unreliable if you do not have loose bearings, secondly, the lights are also good if charging is correct.
  • #12 16490678
    TheGolibroda
    Rate: 14
    If you want to set up a welder then I would think about mvt millennium, ducati energetics, lfk or vape. Then you will get what you are looking for.
  • #13 16491174
    abuhamza
    Help: 384
    Rate: 1034
    MVT Millenium, LFK or VAPE is only a tad stronger than Ducati Energy that I have attached in the picture has about 55-60w and mvt has about 75 and two independent coils one inside and the other charging
  • #14 21118524
    skutki
    Gentlemen, I need an ignition for a glowworm has anyone
The discussion revolves around the installation of CDI ignition for the MZ ETZ 250 motorcycle. The original poster seeks specific dimensions and components needed to adapt the ignition system, including modifications to the magnet and stator stand. Responses highlight concerns about the suitability of CDI ignition given the ETZ's 200W alternator capacity, suggesting alternatives like TCI ignition for better performance. Various users recommend considering electronic ignition modules specifically designed for the ETZ model, and mention brands such as MVT, Ducati Energy, and LFK as potential options for improved ignition systems. The conversation emphasizes the importance of proper measurements and compatibility with existing components to ensure reliable operation.
