How to Power DC LED Lights on Yamaha YZ250 With Only AC Output and No Battery?
621 11
How can I power DC LED lights on a Yamaha YZ250 that only has AC output without using a battery?
Use a lower-voltage AC feed from the magneto/stator, not the high-voltage ignition coil circuit, because loading the ignition side will kill the spark [#21683682] If the brown wire gives you both spark and lights when you wire it through a bridge rectifier, that is the right direction, and the LEDs should not affect spark much because they draw very little power [#21683684] To reduce the pulsing, put a capacitor of about 1000 µF across the rectifier output, but first measure the voltage and choose a capacitor rated at least twice that voltage [#21683684] Make sure the rectified voltage is not too high for the LEDs, and if needed regulate it to about 12 V [#21683682][#21683684] For the rectifier, a small 1 A or 2 A unit is usually enough for LED lighting; a 50 A bridge will work but is overkill [#21683686][#21683688]
  • Need separate lighting coil from ignition circuit
    #1 21683681
    Silverfox Racing
  • Use magneto output, not ignition coil voltage
    #2 21683682
    David Ashton
  • Bridge rectifier on brown wire preserves spark and lights
    #3 21683683
    Silverfox Racing
  • Add a smoothing capacitor after the bridge rectifier
    #4 21683684
    David Ashton
  • #5 21683685
    Silverfox Racing
  • #6 21683686
    David Ashton
  • #7 21683687
    Silverfox Racing
  • #8 21683688
    David Ashton
  • #9 21683689
    Silverfox Racing
  • Skepticism about misleading YouTube LED demos
    #10 21683690
    Eric Richards
  • #11 21683691
    Silverfox Racing
  • #12 21683692
    Emma wilson
A Yamaha YZ250 motocross bike (1987 T model) lacks a battery and provides only AC output from the magneto for ignition and lighting. The user attempted to power DC LED lights by tapping the AC output and using a bridge rectifier, but connecting the LED circuit caused loss of engine spark, likely due to grounding issues. The ignition coil output is high voltage but unsuitable for powering LEDs directly as it draws excessive current and disrupts spark. Alternative magneto wires (brown, red, white) may provide lower voltage AC more suitable for rectification and LED use. Adding a bridge rectifier with a smoothing capacitor (e.g., 1000 µF rated for twice the voltage) can convert and stabilize the AC to DC for LEDs, reducing flicker. Bridge rectifiers rated for at least 1–2 A are sufficient for typical LED loads; the user’s 50 A rectifier is overkill but functional. The LED circuit must not interfere with the ignition earth to maintain spark. Commercial kits exist but are costly. The LEDs run continuously with the engine as breaking the circuit or earth disrupts ignition. The solution involves careful selection of magneto output wires, proper rectification, smoothing, and ensuring the LED load does not affect ignition grounding.
TL;DR: Power YZ250 LEDs by tapping the stator’s lighting lead, then rectify, smooth, and regulate to ~12 V; “2A at 12V is 24W.” [Elektroda, Anonymous, post #21683686]
Why it matters: Riders without a battery need a simple, reliable way to run DC LED lights from an AC-only dirt bike.
Can I power DC LED lights on a Yamaha YZ250 that only outputs AC?
Yes. Tap the stator’s lighting lead (brown/red), feed a bridge rectifier, smooth with a capacitor, and regulate to about 12 V for LEDs. Avoid the high-voltage ignition wire. [Elektroda, Anonymous, post #21683682]
Why did I lose spark when I grounded the rectifier?
You tied the LED circuit into the ignition path. Grounding or loading that path removed spark. Keep the lighting tap isolated from the ignition and route it only through your rectifier and DC side. “Edge case: earthing the tap killed spark in testing.” [Elektroda, Anonymous, post #21683683]
Which wires should I tap from the magneto/stator?
Use the thicker lighting leads, commonly brown/red on this bike. They carry usable AC power. Confirm with a multimeter before wiring. If your loom colors differ, identify by measurement, not color alone. [Elektroda, Anonymous, post #21683682]
Do I need a battery to run LED lights on this YZ250?
No. A forum user reported successful LED operation without a battery by rectifying the stator output. The lights ran whenever the engine ran. [Elektroda, Anonymous, post #21683691]
How do I cut the LED flicker after rectifying AC?
Place about a 1000 µF electrolytic across the bridge rectifier’s + and − outputs. Choose a voltage rating at least 2× your measured DC. Verify the resulting voltage suits your LEDs. [Elektroda, Anonymous, post #21683684]
What size bridge rectifier should I choose?
For typical bike LEDs, select a 1–2 A bridge. As noted, 2 A at 12 V equals 24 W, which is plenty for many LED setups. “2A at 12V is 24W.” [Elektroda, Anonymous, post #21683686]
Is a 50 A GBPC5010 bridge rectifier okay to use?
Yes, it works but is excessive for LED loads. It’s physically larger and unnecessary unless you need its form factor. A smaller 1–2 A unit is adequate. [Elektroda, Anonymous, post #21683688]
Will adding a bridge rectifier reduce engine spark strength?
Not when wired off the lighting lead and isolated from ignition. A user ran LEDs with spark intact. “LEDs don’t draw much power.” [Elektroda, Anonymous, post #21683684]
My LEDs stay on whenever the engine runs. Can I switch them off?
In the reported build, breaking the tapped line or earthing it killed spark, so the lights stayed on. Plan switching on the DC side only, leaving the stator-rectifier path intact. [Elektroda, Anonymous, post #21683691]
How do I wire this in three steps?
  1. Identify the lighting lead (brown/red) from the magneto with a meter.
  2. Feed that AC into a bridge rectifier and add smoothing.
  3. Regulate to ~12 V DC and connect your LED light. [Elektroda, Anonymous, post #21683682]
What capacitor voltage rating should I use?
Measure your DC after rectification, then choose a capacitor rated at least double that voltage. This provides headroom and reliability under rev changes. [Elektroda, Anonymous, post #21683684]
How much power can I expect for LEDs from this setup?
Plan around 1–2 A at ~12 V for common LED lights. That’s up to about 24 W available for lighting on many builds. Size components to that current. [Elektroda, Anonymous, post #21683686]
Are YouTube hacks showing coil-powered LEDs trustworthy?
Be cautious. Some videos hide internal batteries in emergency lights, misleading viewers about coil output. Verify with proper wiring and measurement. [Elektroda, Anonymous, post #21683690]
Can I buy a ready-made kit instead of DIY?
Yes. Kits exist around this mod, but one user avoided a roughly $300 option and succeeded DIY with rectification and smoothing. [Elektroda, Anonymous, post #21683691]
How do I find the most powerful stator lead without a diagram?
Use a multimeter to identify AC outputs and note that thicker wires generally carry more power. Confirm voltage before rectifying and regulating. [Elektroda, Anonymous, post #21683682]
