Books with examples of home automation implementation on PLC and 24V installation?
ienecode 3633 3
  • #1 16501299
    ienecode
    Rate: 96
    As I am going to do the electrical installation in my house myself I am also going to do the 24V control installation at the same time.
    Mainly I want a cupboard with a PLC to be next to my switchboard and the control wires from the individual points from the house to go into it.
    Are there any interesting books with examples or proposals for building my own home automation ?
  • #2 16502375
    ditomek
    Help: 24
    Rate: 230
    Oceans of text have been poured over this topic on the electrode. Have you read it?
  • #3 16514083
    Voldi123
    Rate: 12
    Damian7546 wrote:
    Are there any interesting books with example implementations or proposals for building your own home automation ?
    If you know how to program a PLC, are familiar with automation etc. then you know in your own head what you can do and how to layout it. From roller shutter automation to sprinklers in the garden. The problem should be in the choice of controller or devices, programming or installation. If the problem is the idea of something, then that's no problem. Have a look at home automation websites and you will figure out for yourself what you can use at your home.
    https://www.moeller.pl/Documentation/Poradniki/poradnik.pdf
    Here you have the electrical installer's guide. The following sections show how you can use a PLC in your home.
  • #4 16528991
    ienecode
    Rate: 96
    Ok, thanks for the info.
