Quad Bashan 200 - No Spark on Candle, Seeking Diagram & Help for Ignition Coil Repair
Kamil 1919o 17772 3
  • #1 16923489
    Kamil 1919o
    I have a problem with starting the Chinese quad "Bashan 200", I am looking for a diagram or help in repair.
    I have replaced the spark plug, ignition coil and have no idea what to do next.
    Please help.
  • #2 16923537
    Pedros050
    Help: 2471
    Rate: 3921
    See if the coil gets a pulse from the module, if not then either the CDI module or the sensor on the shaft to be replaced.
  • #3 16944545
    RafalGT2
    Help: 77
    Rate: 223
    Best, fastest advice, depending on what kind of DC or AC ignition you have. If AC, disconnect the black and white cable from the module (most often) it is from the extinguishing system, then you will exclude a failure of the installation. If there is still no spark then look on the engine-module circuit, if it appears, then the fault is module-quad.
    mitsu7
    Rate: 12
    You need to check the voltage output from the magnet to the power supply of the module. If the AC is about 35-70V and the voltage output from the pulser is about 0.2V, the module should be checked or replaced.
