Bashan 250 ATV - No Fire Issue: Replaced Ignition Coil, Module, Regulator & Spark Plug
bashan250michal 12276 10
Why does my Bashan 250 ATV have spark and fuel but still not start after replacing the ignition coil, module, regulator, and spark plug?
The fault was the engine stator; after the other common causes were checked, the stator in the engine was identified as the culprit [#16921104] Earlier suggestions focused on valve adjustment, compression, timing, fresh fuel, and possible ground or wire breakdowns [#16912308][#16912427][#16912503][#16912915] The spark plug was also checked and replaced, so it was not the cause [#16913359]
  • Weak spark and 20 V AC charging coil reading
    #1 16903648
    bashan250michal
    Rate: 14
    Good morning, I have a problem with my Bashan. The problem is that I drove it and everything was OK but after switching off the ignition did not fire again. I replaced the ignition coil, ignition module, regulator, and spark plug. And I have a problem because there is a spark, the fuel comes in and still does not ignite which may be the reason. The spark is such an average I measured the current from the charging coil of the feeder in the module is about 20V AC. After attempting to light the quad, when I wring out the candles, there is some smoke in the head. Regards bashan250michal.
  • #2 16912190
    bashan250michal
    Rate: 14
    what could be the reason
    Added after 12 [minutes]:
    please help
    E8600
    Help: 529
    Rate: 2520
    The valves were checked for support. Maybe they need adjustment.
  • #4 16912396
    bashan250michal
    Rate: 14
    adjusted
    E8600
    Help: 529
    Rate: 2520
    Have you measured the compressions? Perhaps the rings have run out or the timing has jumped.
  • #6 16912446
    bashan250michal
    Rate: 14
    compression is good rings recently replaced the whole new cylinder
    E8600
    Help: 529
    Rate: 2520
    Fresh fuel? You can try the spray starter to squeeze into the air filter or poster as you have.
  • #8 16912786
    bashan250michal
    Rate: 14
    I tried with my dad
    Added after 55 [seconds]:
    and what could be the reason for the disappearance of the spark?
  • #9 16912915
    E8600
    Help: 529
    Rate: 2520
    Ground problems or breakthrough cables somewhere. Even the candle itself can be guilty.
  • #10 16913359
    bashan250michal
    Rate: 14
    I also checked a new candle and I know that the mower works efficiently
  • #11 16921104
    bashan250michal
    Rate: 14
    guilty stator in the engine
The discussion revolves around a Bashan 250 ATV that fails to start after being turned off, despite having replaced the ignition coil, ignition module, regulator, and spark plug. The user reports having a spark and fuel flow, but the engine does not ignite. Suggestions from other users include checking valve adjustments, measuring compression, ensuring fresh fuel, and using starter spray. Grounding issues, faulty cables, or a defective spark plug are also considered potential causes. Ultimately, a user suspects the stator in the engine may be the culprit.
